[petsc-users] Using Sundials from PETSc
    Vanella, Marcos (Fed)
    marcos.vanella at nist.gov
    Mon Oct 16 15:07:58 CDT 2023
Hi Mathew, we have code that time splits the combustion step from the chemical species transport, so on each computational cell for each fluid flow time step, once transport is done we have the mixture chemical composition as initial condition. We are looking into doing finite rate chemistry with skeletal combustion models (20+ equations) in each cell for each fluid time step. Sundials provides the CVODE solver for the time integration of these, and would be interesting to see if we can make use of GPU acceleration. From their User Guide for Version 6.6.0 there are several GPU implementations for building RHS and using linear, nonlinear and stiff ODE solvers.
Thank you Satish for the comment. Might be better at this point to first get an idea on what the implementation in our code using Sundials directly would look like. Then, we can see if it is possible and makes sense to access it through PETSc.
We have things working in CPU making use of and older version of CVODE.
BTW after some changes in our code we are starting running larger cases using GPU accelerated iterative solvers from PETSc, so we have PETSc interfaced already.
Thanks!
Sent: Monday, October 16, 2023 3:03 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Paul, Chandan (IntlAssoc) <chandan.paul at nist.gov>
Subject: Re: [petsc-users] Using Sundials from PETSc
On Mon, Oct 16, 2023 at 2:29 PM Vanella, Marcos (Fed) via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi, we were wondering if it would be possible to call the latest version of Sundials from PETSc?
The short answer is, no. We are at v2.5 and they are at v6.5. There were no dates on the version history page, so I do not know how out of date we are. There have not been any requests for update until now.
We would be happy to get an MR for the updates if you want to try it.
We are interested in doing chemistry using GPUs and already have interfaces to PETSc from our code.
How does the GPU interest interact with the SUNDIALS version?
     Matt
Marcos
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231016/0e00a677/attachment-0001.html>
