[petsc-users] Galerkin projection using petsc4py
Tue Oct 10 19:26:34 CDT 2023
On Tue, Oct 10, 2023 at 5:34 PM Thanasis Boutsikakis <
thanasis.boutsikakis at corintis.com> wrote:
> Hi all,
> Revisiting my code and the proposed solution from Pierre, I realized this
> works only in sequential. The reason is that PETSc partitions those
> matrices only row-wise, which leads to an error due to the mismatch between
> number of columns of A (non-partitioned) and the number of rows of Phi
> (partitioned).
Are you positive about this? P^T A P is designed to run in this scenario,
so either we have a bug or the diagnosis is wrong.
     Matt
> """Experimenting with PETSc mat-mat multiplication"""
> import time
> import numpy as np
> from colorama import Fore
> from firedrake import COMM_SELF, COMM_WORLD
> from firedrake.petsc import PETSc
> from mpi4py import MPI
> from numpy.testing import assert_array_almost_equal
> from utilities import Print
> nproc = COMM_WORLD.size
> rank = COMM_WORLD.rank
> def create_petsc_matrix(input_array, sparse=True):
> """Create a PETSc matrix from an input_array
> Args:
> input_array (np array): Input array
> partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
> sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
> Returns:
> PETSc mat: PETSc mpi matrix
> # Check if input_array is 1D and reshape if necessary
> assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
> global_rows, global_cols = input_array.shape
> size = ((None, global_rows), (global_cols, global_cols))
> # Create a sparse or dense matrix based on the 'sparse' argument
> if sparse:
> matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
> else:
> matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
> matrix.setUp()
> local_rows_start, local_rows_end = matrix.getOwnershipRange()
> for counter, i in enumerate(range(local_rows_start, local_rows_end)):
> # Calculate the correct row in the array for the current process
> row_in_array = counter + local_rows_start
> matrix.setValues(
> i, range(global_cols), input_array[row_in_array, :], addv=False
> # Assembly the matrix to compute the final structure
> matrix.assemblyBegin()
> matrix.assemblyEnd()
> return matrix
> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc
> matrix Phi
> # A' = Phi.T * A * Phi
> # [k x k] <- [k x m] x [m x m] x [m x k]
> m, k = 100, 7
> # Generate the random numpy matrices
> np.random.seed(0) # sets the seed to 0
> A_np = np.random.randint(low=0, high=6, size=(m, m))
> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
> # TEST: Galerking projection of numpy matrices A_np and Phi_np
> Aprime_np = Phi_np.T @ A_np @ Phi_np
> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
> Print(f"{Aprime_np}")
> # Create A as an mpi matrix distributed on each process
> A = create_petsc_matrix(A_np, sparse=False)
> # Create Phi as an mpi matrix distributed on each process
> Phi = create_petsc_matrix(Phi_np, sparse=False)
> # Create an empty PETSc matrix object to store the result of the PtAP
> operation.
> # This will hold the result A' = Phi.T * A * Phi after the computation.
> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
> # Perform the PtAP (Phi Transpose times A times Phi) operation.
> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
> # A_prime will store the result of the operation.
> A_prime = A.ptap(Phi)
> Here is the error
> MATRIX mpiaij A [100x100]
> Assembled
> Partitioning for A:
>   Rank 0: Rows [0, 34)
>   Rank 1: Rows [34, 67)
>   Rank 2: Rows [67, 100)
> MATRIX mpiaij Phi [100x7]
> Assembled
> Partitioning for Phi:
> Traceback (most recent call last):
>   File "/Users/boutsitron/work/galerkin_projection.py", line 87, in
> <module>
>   File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
> petsc4py.PETSc.Error: error code 60
> [0] MatPtAP() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
> [0] MatProductSetFromOptions() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
> [0] MatProductSetFromOptions_Private() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
> [0] MatProductSetFromOptions_MPIAIJ() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
> [0] MatProductSetFromOptions_MPIAIJ_PtAP() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
> [0] Nonconforming object sizes
> [0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
> Abort(1) on node 0 (rank 0 in comm 496): application called
> MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
> Any thoughts?
> Thanks,
> Thanos
> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <
> This works Pierre. Amazing input, thanks a lot!
> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et> wrote:
> Not a petsc4py expert here, but you may to try instead:
> Thanks,
> Pierre
> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <
> Thanks Pierre! So I tried this and got a segmentation fault. Is this
> supposed to work right off the bat or am I missing sth?
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
> causing the crash.
> Abort(59) on node 0 (rank 0 in comm 0): application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> import time
> import numpy as np
> from utilities import (
> Print,
> create_petsc_matrix,
> print_matrix_partitioning,
> matrix Phi
> m, k = 11, 7
> operation.
> Phi.PtAP(A, A_prime)
> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et> wrote:
> How about using ptap which will use MatPtAP?
> It will be more efficient (and it will help you bypass the issue).
> Thanks,
> Pierre
> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <
> Sorry, forgot function create_petsc_matrix()
> def create_petsc_matrix(input_array sparse=True):
> Args:
> Returns:
> PETSc mat: PETSc matrix
> if sparse:
> else:
> matrix.setUp()
> matrix.setValues(
> return matrix
> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <
> Hi everyone,
> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A,
> A1) work. The error is
>     Phi.transposeMatMult(A, A1)
>   File "petsc4py/PETSc/Mat.pyx", line 1514, in
> petsc4py.PETSc.Mat.transposeMatMult
> petsc4py.PETSc.Error: error code 56
> [0] MatTransposeMatMult() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
> [0] MatProduct_Private() at
> /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
> [0] No support for this operation for this object type
> [0] Call MatProductCreate() first
> Do you know if these exposed to petsc4py or maybe there is another way? I
> cannot get the MFE to work (neither in sequential nor in parallel)
> import time
> import numpy as np
> Print,
> matrix Phi
> m, k = 11, 7
> A = create_petsc_matrix(A_np)
> Phi = create_petsc_matrix(Phi_np)
> A1 = create_petsc_matrix(np.zeros((k, m)))
> # Now A1 contains the result of Phi^T * A
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231010/f97044e1/attachment-0001.html>
