[petsc-users] Galerkin projection using petsc4py
Thanasis Boutsikakis thanasis.boutsikakis at corintis.com
Tue Oct 10 16:33:48 CDT 2023
Hi all,
Revisiting my code and the proposed solution from Pierre, I realized this works only in sequential. The reason is that PETSc partitions those matrices only row-wise, which leads to an error due to the mismatch between number of columns of A (non-partitioned) and the number of rows of Phi (partitioned).
"""Experimenting with PETSc mat-mat multiplication"""
import time
import numpy as np
from colorama import Fore
from firedrake import COMM_SELF, COMM_WORLD
from firedrake.petsc import PETSc
from mpi4py import MPI
from numpy.testing import assert_array_almost_equal
from utilities import Print
nproc = COMM_WORLD.size
rank = COMM_WORLD.rank
def create_petsc_matrix(input_array, sparse=True):
    """Create a PETSc matrix from an input_array
    Args:
        input_array (np array): Input array
        partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
        sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
    Returns:
        PETSc mat: PETSc mpi matrix
    # Check if input_array is 1D and reshape if necessary
    assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
    global_rows, global_cols = input_array.shape
    size = ((None, global_rows), (global_cols, global_cols))
    # Create a sparse or dense matrix based on the 'sparse' argument
    if sparse:
        matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
    else:
        matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
    matrix.setUp()
    local_rows_start, local_rows_end = matrix.getOwnershipRange()
    for counter, i in enumerate(range(local_rows_start, local_rows_end)):
        # Calculate the correct row in the array for the current process
        row_in_array = counter + local_rows_start
        matrix.setValues(
            i, range(global_cols), input_array[row_in_array, :], addv=False
    # Assembly the matrix to compute the final structure
    matrix.assemblyBegin()
    matrix.assemblyEnd()
    return matrix
# EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
#  A' = Phi.T * A * Phi
# [k x k] <- [k x m] x [m x m] x [m x k]
m, k = 100, 7
# Generate the random numpy matrices
np.random.seed(0)  # sets the seed to 0
A_np = np.random.randint(low=0, high=6, size=(m, m))
Phi_np = np.random.randint(low=0, high=6, size=(m, k))
# TEST: Galerking projection of numpy matrices A_np and Phi_np
Aprime_np = Phi_np.T @ A_np @ Phi_np
Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
Print(f"{Aprime_np}")
# Create A as an mpi matrix distributed on each process
A = create_petsc_matrix(A_np, sparse=False)
# Create Phi as an mpi matrix distributed on each process
Phi = create_petsc_matrix(Phi_np, sparse=False)
# Create an empty PETSc matrix object to store the result of the PtAP operation.
# This will hold the result A' = Phi.T * A * Phi after the computation.
A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
# Perform the PtAP (Phi Transpose times A times Phi) operation.
# In mathematical terms, this operation is A' = Phi.T * A * Phi.
# A_prime will store the result of the operation.
A_prime = A.ptap(Phi)
Here is the error
MATRIX mpiaij A [100x100]
Assembled
Partitioning for A:
  Rank 0: Rows [0, 34)
  Rank 1: Rows [34, 67)
  Rank 2: Rows [67, 100)
MATRIX mpiaij Phi [100x7]
Assembled
Partitioning for Phi:
Traceback (most recent call last):
  File "/Users/boutsitron/work/galerkin_projection.py", line 87, in <module>
  File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
petsc4py.PETSc.Error: error code 60
[0] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
[0] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
[0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
[0] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
[0] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
[0] Nonconforming object sizes
[0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
Abort(1) on node 0 (rank 0 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
Any thoughts?
Thanos
> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
> This works Pierre. Amazing input, thanks a lot!
>> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et> wrote:
>> Not a petsc4py expert here, but you may to try instead:
>> Thanks,
>> Pierre
>>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>> [0]PETSC ERROR: to get more information on the crash.
>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>> import time
>>> import numpy as np
>>> from utilities import (
>>>     Print,
>>>     create_petsc_matrix,
>>>     print_matrix_partitioning,
>>> m, k = 11, 7
>>> Phi.PtAP(A, A_prime)
>>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et> wrote:
>>>> How about using ptap which will use MatPtAP?
>>>> It will be more efficient (and it will help you bypass the issue).
>>>> Thanks,
>>>> Pierre
>>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>>> Sorry, forgot function create_petsc_matrix()
>>>>> def create_petsc_matrix(input_array sparse=True):
>>>>>     Args:
>>>>>     Returns:
>>>>>         PETSc mat: PETSc matrix
>>>>>     if sparse:
>>>>>     else:
>>>>>     matrix.setUp()
>>>>>         matrix.setValues(
>>>>>     return matrix
>>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>>>> Hi everyone,
>>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>>>   File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>>> petsc4py.PETSc.Error: error code 56
>>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>>> [0] No support for this operation for this object type
>>>>>> [0] Call MatProductCreate() first
>>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>>> import time
>>>>>> import numpy as np
>>>>>>     Print,
>>>>>> m, k = 11, 7
>>>>>> A = create_petsc_matrix(A_np)
>>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>>> # Now A1 contains the result of Phi^T * A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231010/619a9dde/attachment-0001.html>
