[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Barry Smith bsmith at petsc.dev
Fri Nov 17 09:56:01 CST 2023
  Please do
  cd src/snes/tutorials
  make ex19
  mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
  then with -n 2
  Cut and paste all the output and include it in your email response
   Barry
> On Nov 17, 2023, at 12:57 AM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi all,
> I could successfully compile PETSc on Windows with Intel OneAPI C/C++ and Fortran compilers, however, when I tried to make a check after the successful installation, I got the following error message. I have also attached the configuration file.
> make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
> Running PETSc check examples to verify correct installation
> Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See https://petsc.org/release/faq/
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   RANK 0 PID 13384 RUNNING AT BLRLAP1521
> =   EXIT STATUS: -1073741819 (c0000005)
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> =   RANK 0 PID 20616 RUNNING AT BLRLAP1521
> =   RANK 1 PID 16900 RUNNING AT BLRLAP1521
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
> forrtl: severe (157): Program Exception - access violation
> Image              PC                Routine            Line        Source
> ex5f.exe           00007FF661DB569B  Unknown               Unknown  Unknown
> ex5f.exe           00007FF661A760AF  Unknown               Unknown  Unknown
> ex5f.exe           00007FF6619E6EBD  Unknown               Unknown  Unknown
> ex5f.exe           00007FF6619C6294  Unknown               Unknown  Unknown
> ex5f.exe           00007FF6619C3152  Unknown               Unknown  Unknown
> ex5f.exe           00007FF6619C1051  Unknown               Unknown  Unknown
> ex5f.exe           00007FF662C3C16E  Unknown               Unknown  Unknown
> ex5f.exe           00007FF662C3CA50  Unknown               Unknown  Unknown
> KERNEL32.DLL       00007FFB12187344  Unknown               Unknown  Unknown
> ntdll.dll          00007FFB140C26B1  Unknown               Unknown  Unknown
> Completed PETSc check examples
> Error while running make check
> make[1]: *** [makefile:132: check] Error 1
> make: *** [GNUmakefile:17: check] Error 2
> Regards,
> mnh
> <intel-petsc-tag-v3.20.1.py>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/8d9e8c83/attachment-0001.html>
