[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Maruthi NH maruthinh at gmail.com
Thu Nov 16 23:57:01 CST 2023
Hi all,
I could successfully compile PETSc on Windows with Intel OneAPI C/C++ and
Fortran compilers, however, when I tried to make a check after the
successful installation, I got the following error message. I have also
attached the configuration file.
make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
Running PETSc check examples to verify correct installation
Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See https://petsc.org/release/faq/
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 13384 RUNNING AT BLRLAP1521
=   EXIT STATUS: -1073741819 (c0000005)
Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
=   RANK 0 PID 20616 RUNNING AT BLRLAP1521
=   RANK 1 PID 16900 RUNNING AT BLRLAP1521
Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
process
forrtl: severe (157): Program Exception - access violation
Image              PC                Routine            Line        Source
ex5f.exe           00007FF661DB569B  Unknown               Unknown  Unknown
ex5f.exe           00007FF661A760AF  Unknown               Unknown  Unknown
ex5f.exe           00007FF6619E6EBD  Unknown               Unknown  Unknown
ex5f.exe           00007FF6619C6294  Unknown               Unknown  Unknown
ex5f.exe           00007FF6619C3152  Unknown               Unknown  Unknown
ex5f.exe           00007FF6619C1051  Unknown               Unknown  Unknown
ex5f.exe           00007FF662C3C16E  Unknown               Unknown  Unknown
ex5f.exe           00007FF662C3CA50  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFB12187344  Unknown               Unknown  Unknown
ntdll.dll          00007FFB140C26B1  Unknown               Unknown  Unknown
Completed PETSc check examples
Error while running make check
make[1]: *** [makefile:132: check] Error 1
make: *** [GNUmakefile:17: check] Error 2
mnh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/310eacdd/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/310eacdd/attachment-0001.py>
