[petsc-users] Error using Metis with PETSc installed with MUMPS
Victoria Rolandi victoria.rolandi93 at gmail.com
Fri Nov 3 13:28:48 CDT 2023
Pierre,
Sure, I have now installed PETSc with MUMPS and  PT-SCHOTCH, I got some
errors at the beginning but then it worked adding
--COPTFLAGS="-D_POSIX_C_SOURCE=199309L"
to the configuration.
Also, I have compilation errors when I try to use newer versions, so I kept
the 3.17.0 for the moment.
Now the parallel ordering works with PT-SCOTCH, however, is it normal that
I do not see any difference in the performance compared to sequential
ordering ?
Also, could the error using Metis/Parmetis be due to the fact that my main
code (to which I linked PETSc) uses a different ParMetis than the one
separately installed by PETSC during the configuration?
Hence should I configure PETSc linking ParMetis to the same library used by
my main code?
Victoria
Il giorno gio 2 nov 2023 alle ore 09:35 Pierre Jolivet <pierre at joliv.et> ha
scritto:
> On 2 Nov 2023, at 5:29 PM, Victoria Rolandi <victoria.rolandi93 at gmail.com>
> wrote:
> Pierre,
> Yes, sorry, I'll keep the list in copy.
> Launching with those options (-mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2)
> I get an error during the analysis step. I also launched increasing the
> memory and I still have the error.
> Oh, OK, that’s bad.
> Would you be willing to give SCOTCH and/or PT-SCOTCH a try?
> You’d need to reconfigure/recompile with --download-ptscotch (and maybe
> --download-bison depending on your system).
> Then, the option would become either -mat_mumps_icntl_28 2
> -mat_mumps_icntl_29 2 (PT-SCOTCH) or -mat_mumps_icntl_7 3 (SCOTCH).
> It may be worth updating PETSc as well (you are using 3.17.0, we are at
> 3.20.1), though I’m not sure we updated the METIS/ParMETIS snapshots since
> then, so it may not fix the present issue.
> Thanks,
> Pierre
> *The calculations stops at :*
> Entering CMUMPS 5.4.1 from C interface with JOB, N =   1      699150
>       executing #MPI =      2, without OMP
>  MUMPS compiled with option -Dmetis
>  MUMPS compiled with option -Dparmetis
> L U Solver for unsymmetric matrices
> Type of parallelism: Working host
>  ****** ANALYSIS STEP ********
>  ** Maximum transversal (ICNTL(6)) not allowed because matrix is
> distributed
>  Using ParMETIS for parallel ordering
>  Structural symmetry is: 90%
> *The error:*
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS
> to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.17.0, unknown
> [0]PETSC ERROR: ./charlin.exe on a  named n1056 by vrolandi Wed Nov  1
> 11:38:28 2023
> [0]PETSC ERROR: Configure options
> --prefix=/u/home/v/vrolandi/CODES/LIBRARY/packages/petsc/installationDir
> --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort CXXOPTFLAGS=-O3
> --with-scalar-type=complex --with-debugging=0 --with-precision=single
> --download-mumps --download-scalapack --download-parmetis --download-metis
> [0]PETSC ERROR: #1 User provided function() at unknown file:0
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
> causing the crash.
> Abort(59) on node 0 (rank 0 in comm 0): application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> Thanks,
> Victoria
> Il giorno mer 1 nov 2023 alle ore 10:33 Pierre Jolivet <pierre at joliv.et>
> ha scritto:
>> Victoria, please keep the list in copy.
>> I am not understanding how can I switch to ParMetis if it does not appear
>> in the options of -mat_mumps_icntl_7.In the options I only have Metis and
>> not ParMetis.
>> You need to use -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2
>> Barry, I don’t think we can programmatically shut off this warning, it’s
>> guarded by a bunch of KEEP() values, see src/dana_driver.F:4707, which are
>> only settable/gettable by people with access to consortium releases.
>> I’ll ask the MUMPS people for confirmation.
>> Note that this warning is only printed to screen with the option
>> -mat_mumps_icntl_4 2 (or higher), so this won’t show up for standard runs.
>> Thanks,
>> Pierre
>> On 1 Nov 2023, at 5:52 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>   Pierre,
>>    Could the PETSc MUMPS interface "turn-off" ICNTL(6) in this situation
>> so as to not trigger the confusing warning message from MUMPS?
>>   Barry
>> On Nov 1, 2023, at 12:17 PM, Pierre Jolivet <pierre at joliv.et> wrote:
>> On 1 Nov 2023, at 3:33 PM, Zhang, Hong via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> Victoria,
>> "** Maximum transversal (ICNTL(6)) not allowed because matrix is
>> distributed
>> Ordering based on METIS"
>> This warning is benign and appears for every run using a sequential
>> partitioner in MUMPS with a MATMPIAIJ.
>> (I’m not saying switching to ParMETIS will not make the issue go away)
>> Thanks,
>> Pierre
>> $ ../../../../arch-darwin-c-debug-real/bin/mpirun -n 2 ./ex2 -pc_type lu
>> Entering DMUMPS 5.6.2 from C interface with JOB, N =   1          56
>>  MUMPS compiled with option -Dpord
>>  MUMPS compiled with option -Dptscotch
>>  MUMPS compiled with option -Dscotch
>> distributed
>>  Processing a graph of size:        56 with           194 edges
>>  Ordering based on AMF
>>  WARNING: Largest root node of size        26 not selected for parallel
>> execution
>> Leaving analysis phase with  ...
>>  INFOG(1)                                       =               0
>>  INFOG(2)                                       =               0
>> Try parmetis.
>> Hong
>> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
>> *Sent:* Tuesday, October 31, 2023 10:30 PM
>> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *Subject:* [petsc-users] Error using Metis with PETSc installed with
>> MUMPS
>> Hi,
>> I'm solving a large sparse linear system in parallel and I am using PETSc
>> with MUMPS. I am trying to test different options, like the ordering of the
>> matrix. Everything works if I use the *-mat_mumps_icntl_7 2  *or *-mat_mumps_icntl_7
>> 0 *options (with the first one, AMF, performing better than AMD),
>> however when I test METIS *-mat_mumps_icntl_7** 5 *I get an error
>> (reported at the end of the email).
>> I have configured PETSc with the following options:
>> and the installation didn't give any problems.
>> Could you help me understand why metis is not working?
>> Thank you in advance,
>> Victoria
>> Error:
>> distributed
>>  Processing a graph of size:    699150 with      69238690 edges
>> 510522 37081376 [100] [10486 699150]
>> Error! Unknown CType: -1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231103/72d07b4a/attachment.html>
