[petsc-users] Large MATMPIAIJ - 32bit integer overflow in nz value
Wed May 17 08:08:37 CDT 2023
On Wed, May 17, 2023 at 9:02 AM Fleischli Benno HSLU T&A <
benno.fleischli at hslu.ch> wrote:
> Dear PETSc developers
> I am creating a very large parallel sparse matrix (MATMPIAIJ) with PETSc.
> I write this matrix to disk.
> The number of non-zeros exceeds the maximum number a 32-bit integer can
> hold.
> When I read the matrix from disk i get an error because there was an
> overflow in the nz number.
> (see petsc-3.18.4/src/mat/impls/aij/seq/aij.c:4977)
> Obviously I could compile PETSc with 64bit integers
> (--with-64-bit-indices).
> But I wanted to ask if there is another way. Because the total number of
> nonzeros nz is the only numer that exceeds the 32bit limit.
> It would not be efficient to use 64bit integers everywhere just because of
> this single number.
Integers tend to be a small part of the overall storage. How much does it
increase the maximum overall storage for your problem?
     Matt
> This how I configured PETSc:
> ./configure --download-fblaslapack --download-hpddm --download-hypre
> --with-debugging=0
> COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native
> -mtune=native'
> FOPTFLAGS='-O3 -march=native -mtune=native' --with-scalar-type=real
> (--with-mpi-dir=/home/benno/Libraries/openMPI)
> Kind Regards
> Benno
> ________________________________
> *Hochschule Luzern Technik & Architektur*
> Institute for Mechanical Engineering and Energy Technology
> Competence Center Fluid Mechanics and Numerical Methods
> *Benno Fleischli*
> MSc in Mechanical Engineering / BSc in Electrical Engineering
> Wissenschaftlicher Mitarbeiter
> <https://webmail.hslu.ch/owa/redir.aspx?C=rM5K5xPd_kKJmyojcJXaG18BaXM9wM8IqSslYJQen5H6HtdiNS2KtWNFL89yfRdRtW-Oa6xCXTk.&URL=mailto%3akatrina.kemp%40hslu.ch>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230517/bc4c787c/attachment-0001.html>
