[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Zongze Yang yangzongze at gmail.com
Sun May 14 18:23:47 CDT 2023
Could you try to project the coordinates into the continuity space by
enabling the option
`-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true`?
Best wishes,
Zongze
On Mon, 15 May 2023 at 04:24, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 14, 2023 at 12:27 PM Zongze Yang <yangzongze at gmail.com> wrote:
>> On Sun, 14 May 2023 at 23:54, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sun, May 14, 2023 at 9:21 AM Zongze Yang <yangzongze at gmail.com>
>>> wrote:
>>>> Hi, Matt,
>>>> The issue has been resolved while testing on the latest version of
>>>> PETSc. It seems that the problem has been fixed in the following merge
>>>> request:  https://gitlab.com/petsc/petsc/-/merge_requests/5970
>>> No problem. Glad it is working.
>>>> I sincerely apologize for any inconvenience caused by my previous
>>>> message. However, I would like to provide you with additional information
>>>> regarding the test files. Attached to this email, you will find two Gmsh
>>>> files: "square_2rd.msh" and "square_3rd.msh." These files contain
>>>> high-order triangulated mesh data for the unit square.
>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
>>>> -dm_plex_gmsh_project_fe_view -volume 1
>>>> PetscFE Object: P2 1 MPI process
>>>>   type: basic
>>>>   Basic Finite Element in 2 dimensions with 2 components
>>>>   PetscSpace Object: P2 1 MPI process
>>>>     type: sum
>>>>     Space in 2 variables with 2 components, size 12
>>>>     Sum space of 2 concatenated subspaces (all identical)
>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI process
>>>>         type: poly
>>>>         Space in 2 variables with 1 components, size 6
>>>>         Polynomial space of degree 2
>>>>   PetscDualSpace Object: P2 1 MPI process
>>>>     type: lagrange
>>>>     Dual space with 2 components, size 12
>>>>     Continuous Lagrange dual space
>>>>     Quadrature on a triangle of order 5 on 9 points (dim 2)
>>>> Volume: 1.
>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
>>>> PetscFE Object: P3 1 MPI process
>>>>   type: basic
>>>>   PetscSpace Object: P3 1 MPI process
>>>>     type: sum
>>>>     Space in 2 variables with 2 components, size 20
>>>>         type: poly
>>>>         Space in 2 variables with 1 components, size 10
>>>>         Polynomial space of degree 3
>>>>   PetscDualSpace Object: P3 1 MPI process
>>>>     type: lagrange
>>>>     Dual space with 2 components, size 20
>>>>     Quadrature on a triangle of order 7 on 16 points (dim 2)
>>>> Volume: 1.
>>>> Thank you for your attention and understanding. I apologize once again
>>>> for my previous oversight.
>>> Great! If you make an MR for this, you will be included on the next list
>>> of PETSc contributors. Otherwise, I can do it.
>> I appreciate your offer to handle the MR. Please go ahead and take care
>> of it. Thank you!
> I have created the MR with your tests. They are working for me:
>   https://gitlab.com/petsc/petsc/-/merge_requests/6463
>   Thanks,
>      Matt
>> Best Wishes,
>> Zongze
>>>   Thanks,
>>>      Matt
>>>> Best wishes,
>>>> Zongze
>>>> On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com>
>>>>> wrote:
>>>>>> Hi, Matt,
>>>>>> There seem to be ongoing issues with projecting high-order
>>>>>> coordinates from a gmsh file to other spaces. I would like to inquire
>>>>>> whether there are any plans to resolve this problem.
>>>>>> Thank you for your attention to this matter.
>>>>> Yes, I will look at it. The important thing is to have a good test.
>>>>> Here are the higher order geometry tests
>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
>>>>> I take shapes with known volume, mesh them with higher order geometry,
>>>>> and look at the convergence to the true volume. Could you add a GMsh test,
>>>>> meaning the .msh file and known volume, and I will fix it?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Best wishes,
>>>>>> Zongze
>>>>>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com>
>>>>>> wrote:
>>>>>>> Thank you for your reply. May I ask for some references on the order
>>>>>>> of the dofs on PETSc's FE Space (especially high order elements)?
>>>>>>> Thanks,
>>>>>>>  Zongze
>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>>>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> In order to check if I made mistakes in the python code, I try to
>>>>>>>>> use c code to show the issue on DMProjectCoordinates. The code and mesh
>>>>>>>>> file is attached.
>>>>>>>>> If the code is correct, there must be something wrong with
>>>>>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>>>>>> Something is definitely wrong with high order, periodic simplices
>>>>>>>> from Gmsh. We had not tested that case. I am at a conference and cannot
>>>>>>>> look at it for a week.
>>>>>>>> My suspicion is that the space we make when reading in the Gmsh
>>>>>>>> coordinates does not match the values (wrong order).
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> The command and the output are listed below: (Obviously the
>>>>>>>>> bounding box is changed.)
>>>>>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view
>>>>>>>>> -new_fe_view
>>>>>>>>> Old Bounding Box:
>>>>>>>>>   0: lo = 0. hi = 1.
>>>>>>>>>   1: lo = 0. hi = 1.
>>>>>>>>>   2: lo = 0. hi = 1.
>>>>>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>>>>>   type: basic
>>>>>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>>>>>     type: sum
>>>>>>>>>     Space in 3 variables with 3 components, size 30
>>>>>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>>>>>         type: poly
>>>>>>>>>         Space in 3 variables with 1 components, size 10
>>>>>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>>>>>     type: lagrange
>>>>>>>>>     Dual space with 3 components, size 30
>>>>>>>>>     Discontinuous Lagrange dual space
>>>>>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>>>>>   type: basic
>>>>>>>>>     type: sum
>>>>>>>>>         type: poly
>>>>>>>>>     type: lagrange
>>>>>>>>> New Bounding Box:
>>>>>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>>>>>> Thanks,
>>>>>>>>> Zongze
>>>>>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>>>>>> I tried the projection operation. However, it seems that the
>>>>>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>>>>>> changed! See logs below.
>>>>>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>>>>>          PetscINCREF(c.obj)
>>>>>>>>>>          return c
>>>>>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>>>>>> +        if fe is None:
>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>>>>>> +        else:
>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>>>>>      def getBoundingBox(self):
>>>>>>>>>>          cdef PetscInt i,dim=0
>>>>>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>> index 514b6fa472..c778e39884 100644
>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>>>>>      int
>>>>>>>>>> DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>>>>>> Then in python, I load a mesh and project the coordinates to P2:
>>>>>>>>>> import firedrake as fd
>>>>>>>>>> from firedrake.petsc import PETSc
>>>>>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>>>>>> dim = plex.getDimension()
>>>>>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>>>>>    qorder, comm=None)
>>>>>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>>>>>> PETSc.DETERMINE)
>>>>>>>>>> plex.projectCoordinates(fe_new)
>>>>>>>>>> fe_new.view()
>>>>>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>>>>>> The output is (The bounding box is changed!)
>>>>>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>>>>>   type: basic
>>>>>>>>>>     type: sum
>>>>>>>>>>         type: poly
>>>>>>>>>>     type: lagrange
>>>>>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>>>>>> Thanks!
>>>>>>>>>>   Zongze
>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <
>>>>>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <
>>>>>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements, the
>>>>>>>>>>>>> coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>>>>>> I checked the coordinates vector, and found the dogs only
>>>>>>>>>>>> defined on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>>>>>> the coordinates in lex order.
>>>>>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>; /*
>>>>>>>>>>>> XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
>>>>>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>>>>>> The continuity is set to false for simplex.
>>>>>>>>>>> Oh, yes. That needs to be fixed. For now, you can just project
>>>>>>>>>>> it to P2 if you want using
>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Zongze
>>>>>>>>>>>> You can ask for the coordinates of a vertex or an edge directly
>>>>>>>>>>>> using
>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>>>>>> by giving the vertex or edge point. You can get all the
>>>>>>>>>>>> coordinates on a cell, in the closure order, using
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Below is some code load the gmsh file, I want to know the
>>>>>>>>>>>>> relation between `cl` and `cell_coords`.
>>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>>>>>     print(f'coordinates for cell {i}
>>>>>>>>>>>>> :\n{cell_coords.reshape([-1, 3])}')
>>>>>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>>>>>     print('closure:', cl)
>>>>>>>>>>>>>     break
>>>>>>>>>>>>> Best wishes,
>>>>>>>>>>>>> Zongze
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230515/3ecc31ed/attachment-0001.html>
