[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Sun May 14 15:24:31 CDT 2023
On Sun, May 14, 2023 at 12:27 PM Zongze Yang <yangzongze at gmail.com> wrote:
> On Sun, 14 May 2023 at 23:54, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, May 14, 2023 at 9:21 AM Zongze Yang <yangzongze at gmail.com> wrote:
>>> Hi, Matt,
>>> The issue has been resolved while testing on the latest version of
>>> PETSc. It seems that the problem has been fixed in the following merge
>>> request:  https://gitlab.com/petsc/petsc/-/merge_requests/5970
>> No problem. Glad it is working.
>>> I sincerely apologize for any inconvenience caused by my previous
>>> message. However, I would like to provide you with additional information
>>> regarding the test files. Attached to this email, you will find two Gmsh
>>> files: "square_2rd.msh" and "square_3rd.msh." These files contain
>>> high-order triangulated mesh data for the unit square.
>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
>>> -dm_plex_gmsh_project
>>> -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true
>>> -dm_plex_gmsh_project_fe_view -volume 1
>>> PetscFE Object: P2 1 MPI process
>>>   type: basic
>>>   Basic Finite Element in 2 dimensions with 2 components
>>>   PetscSpace Object: P2 1 MPI process
>>>     type: sum
>>>     Space in 2 variables with 2 components, size 12
>>>     Sum space of 2 concatenated subspaces (all identical)
>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI process
>>>         type: poly
>>>         Space in 2 variables with 1 components, size 6
>>>         Polynomial space of degree 2
>>>   PetscDualSpace Object: P2 1 MPI process
>>>     type: lagrange
>>>     Dual space with 2 components, size 12
>>>     Continuous Lagrange dual space
>>>     Quadrature on a triangle of order 5 on 9 points (dim 2)
>>> Volume: 1.
>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
>>> PetscFE Object: P3 1 MPI process
>>>   type: basic
>>>   PetscSpace Object: P3 1 MPI process
>>>     type: sum
>>>     Space in 2 variables with 2 components, size 20
>>>         type: poly
>>>         Space in 2 variables with 1 components, size 10
>>>         Polynomial space of degree 3
>>>   PetscDualSpace Object: P3 1 MPI process
>>>     type: lagrange
>>>     Dual space with 2 components, size 20
>>>     Quadrature on a triangle of order 7 on 16 points (dim 2)
>>> Volume: 1.
>>> Thank you for your attention and understanding. I apologize once again
>>> for my previous oversight.
>> Great! If you make an MR for this, you will be included on the next list
>> of PETSc contributors. Otherwise, I can do it.
> I appreciate your offer to handle the MR. Please go ahead and take care of
> it. Thank you!
I have created the MR with your tests. They are working for me:
  https://gitlab.com/petsc/petsc/-/merge_requests/6463
     Matt
> Best Wishes,
> Zongze
>>   Thanks,
>>      Matt
>>> Best wishes,
>>> Zongze
>>> On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com>
>>>> wrote:
>>>>> Hi, Matt,
>>>>> There seem to be ongoing issues with projecting high-order coordinates
>>>>> from a gmsh file to other spaces. I would like to inquire whether there are
>>>>> any plans to resolve this problem.
>>>>> Thank you for your attention to this matter.
>>>> Yes, I will look at it. The important thing is to have a good test.
>>>> Here are the higher order geometry tests
>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
>>>> I take shapes with known volume, mesh them with higher order geometry,
>>>> and look at the convergence to the true volume. Could you add a GMsh test,
>>>> meaning the .msh file and known volume, and I will fix it?
>>>>   Thanks,
>>>>      Matt
>>>>> Best wishes,
>>>>> Zongze
>>>>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com>
>>>>> wrote:
>>>>>> Thank you for your reply. May I ask for some references on the order
>>>>>> of the dofs on PETSc's FE Space (especially high order elements)?
>>>>>> Thanks,
>>>>>>  Zongze
>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>> wrote:
>>>>>>>> In order to check if I made mistakes in the python code, I try to
>>>>>>>> use c code to show the issue on DMProjectCoordinates. The code and mesh
>>>>>>>> file is attached.
>>>>>>>> If the code is correct, there must be something wrong with
>>>>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>>>>> Something is definitely wrong with high order, periodic simplices
>>>>>>> from Gmsh. We had not tested that case. I am at a conference and cannot
>>>>>>> look at it for a week.
>>>>>>> My suspicion is that the space we make when reading in the Gmsh
>>>>>>> coordinates does not match the values (wrong order).
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>> The command and the output are listed below: (Obviously the
>>>>>>>> bounding box is changed.)
>>>>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view
>>>>>>>> -new_fe_view
>>>>>>>> Old Bounding Box:
>>>>>>>>   0: lo = 0. hi = 1.
>>>>>>>>   1: lo = 0. hi = 1.
>>>>>>>>   2: lo = 0. hi = 1.
>>>>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>>>>   type: basic
>>>>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>>>>     type: sum
>>>>>>>>     Space in 3 variables with 3 components, size 30
>>>>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>>>>         type: poly
>>>>>>>>         Space in 3 variables with 1 components, size 10
>>>>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>>>>     type: lagrange
>>>>>>>>     Dual space with 3 components, size 30
>>>>>>>>     Discontinuous Lagrange dual space
>>>>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>>>>   type: basic
>>>>>>>>     type: sum
>>>>>>>>         type: poly
>>>>>>>>     type: lagrange
>>>>>>>> New Bounding Box:
>>>>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>>>>> Thanks,
>>>>>>>> Zongze
>>>>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>>>>> I tried the projection operation. However, it seems that the
>>>>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>>>>> changed! See logs below.
>>>>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>>>>          PetscINCREF(c.obj)
>>>>>>>>>          return c
>>>>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>>>>> +        if fe is None:
>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>>>>> +        else:
>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>>>>      def getBoundingBox(self):
>>>>>>>>>          cdef PetscInt i,dim=0
>>>>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>> index 514b6fa472..c778e39884 100644
>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>>>>      int DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>>>>> Then in python, I load a mesh and project the coordinates to P2:
>>>>>>>>> import firedrake as fd
>>>>>>>>> from firedrake.petsc import PETSc
>>>>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>>>>> dim = plex.getDimension()
>>>>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>>>>  qorder, comm=None)
>>>>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>>>>> PETSc.DETERMINE)
>>>>>>>>> plex.projectCoordinates(fe_new)
>>>>>>>>> fe_new.view()
>>>>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>>>>> The output is (The bounding box is changed!)
>>>>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>>>>   type: basic
>>>>>>>>>     type: sum
>>>>>>>>>         type: poly
>>>>>>>>>     type: lagrange
>>>>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>>>>> Thanks!
>>>>>>>>>   Zongze
>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <
>>>>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <
>>>>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements, the
>>>>>>>>>>>> coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>>>>> I checked the coordinates vector, and found the dogs only
>>>>>>>>>>> defined on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>>>>> the coordinates in lex order.
>>>>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>; /*
>>>>>>>>>>> XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
>>>>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>>>>> The continuity is set to false for simplex.
>>>>>>>>>> Oh, yes. That needs to be fixed. For now, you can just project it
>>>>>>>>>> to P2 if you want using
>>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Zongze
>>>>>>>>>>> You can ask for the coordinates of a vertex or an edge directly
>>>>>>>>>>> using
>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>>>>> by giving the vertex or edge point. You can get all the
>>>>>>>>>>> coordinates on a cell, in the closure order, using
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Below is some code load the gmsh file, I want to know the
>>>>>>>>>>>> relation between `cl` and `cell_coords`.
>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>>>>     print(f'coordinates for cell {i}
>>>>>>>>>>>> :\n{cell_coords.reshape([-1, 3])}')
>>>>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>>>>     print('closure:', cl)
>>>>>>>>>>>>     break
>>>>>>>>>>>> Best wishes,
>>>>>>>>>>>> Zongze
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230514/6674c8c7/attachment-0001.html>
