[petsc-users] Understanding index sets for PCGASM
Thu May 4 17:01:04 CDT 2023
On Thu, May 4, 2023 at 1:43 PM LEONARDO MUTTI <
leonardo.mutti01 at universitadipavia.it> wrote:
> Of course, I'll try to explain.
> I am solving a parabolic equation with space-time FEM and I want an
> efficient solver/preconditioner for the resulting system.
> The corresponding matrix, call it X, has an e.g. block bi-diagonal
> structure, if the cG(1)-dG(0) method is used (i.e. implicit Euler solved in
> batch).
> Every block-row of X corresponds to a time instant.
> I want to introduce parallelism in time by subdividing X into overlapping
> submatrices of e.g 2x2 or 3x3 blocks, along the block diagonal.
> For instance, call X_i the individual blocks. The submatrices would be,
> for various i, (X_{i-1,i-1},X_{i-1,i};X_{i,i-1},X_{i,i}).
> I'd like each submatrix to be solved in parallel, to combine the various
> results together in an ASM like fashion.
> Every submatrix has thus a predecessor and a successor, and it overlaps
> with both, so that as far as I could understand, GASM has to be used in
> place of ASM.
Yes, ordered that way you need GASM. I wonder if inverting the ordering
would be useful, namely putting the time index on the inside.
Then the blocks would be over all time, but limited space, which is more
the spirit of ASM I think.
Have you considered waveform relaxation for this problem?
     Matt
> Hope this helps.
> Best,
> Leonardo
> Il giorno gio 4 mag 2023 alle ore 18:05 Matthew Knepley <knepley at gmail.com>
> ha scritto:
>> On Thu, May 4, 2023 at 11:24 AM LEONARDO MUTTI <
>>> Thank you for the help.
>>> Adding to my example:
>>> *      call PCGASMSetSubdomains(pc,NSub, subdomains_IS,
>>> inflated_IS,ierr)      call
>>> PCGASMDestroySubdomains(NSub,subdomains_IS,inflated_IS,ierr)*
>>> results in:
>>> *      Error LNK2019 unresolved external symbol PCGASMDESTROYSUBDOMAINS
>>> referenced in function ...  *
>>> *      Error LNK2019 unresolved external symbol PCGASMSETSUBDOMAINS
>>> I'm not sure if the interfaces are missing or if I have a compilation
>>> problem.
>> I just want to make sure you really want GASM. It sounded like you might
>> able to do what you want just with ASM.
>> Can you tell me again what you want to do overall?
>>   Thanks,
>>     Matt
>>> Thank you again.
>>> Best,
>>> Leonardo
>>> Il giorno sab 29 apr 2023 alle ore 20:30 Barry Smith <bsmith at petsc.dev>
>>> ha scritto:
>>>>    Thank you for the test code. I have a fix in the branch
>>>> barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>> <https://gitlab.com/petsc/petsc/-/commits/barry/2023-04-29/fix-pcasmcreatesubdomains2d> with
>>>> merge request https://gitlab.com/petsc/petsc/-/merge_requests/6394
>>>>    The functions did not have proper Fortran stubs and interfaces so I
>>>> had to provide them manually in the new branch.
>>>>    Use
>>>>    git fetch
>>>>    git checkout barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>    ./configure etc
>>>>    Your now working test code is in src/ksp/ksp/tests/ex71f.F90  I had
>>>> to change things slightly and I updated the error handling for the latest
>>>> version.
>>>>    Please let us know if you have any later questions.
>>>>   Barry
>>>> On Apr 28, 2023, at 12:07 PM, LEONARDO MUTTI <
>>>> Hello. I am having a hard time understanding the index sets to feed
>>>> PCGASMSetSubdomains, and I am working in Fortran (as a PETSc novice). To
>>>> get more intuition on how the IS objects behave I tried the following
>>>> minimal (non) working example, which should tile a 16x16 matrix into 16
>>>> square, non-overlapping submatrices:
>>>> #include <petsc/finclude/petscmat.h>
>>>> #include <petsc/finclude/petscksp.h>
>>>> #include <petsc/finclude/petscpc.h>
>>>>       USE petscmat
>>>>       USE petscksp
>>>>       USE petscpc
>>>>       Mat   :: A
>>>>       PetscInt :: M, NSubx, dof, overlap, NSub
>>>>       INTEGER :: I,J
>>>>       PetscErrorCode      :: ierr
>>>>       PetscScalar :: v
>>>>       KSP            :: ksp
>>>>       PC             :: pc
>>>>       IS :: subdomains_IS, inflated_IS
>>>>       call PetscInitialize(PETSC_NULL_CHARACTER , ierr)
>>>> !-----Create a dummy matrix
>>>>       M = 16
>>>>       call MatCreateAIJ(MPI_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>>>      & M, M,
>>>>      & PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,
>>>>      & A, ierr)
>>>>       DO I=1,M
>>>>          DO J=1,M
>>>>             v = I*J
>>>>             CALL MatSetValue (A,I-1,J-1,v,
>>>>      &                     INSERT_VALUES , ierr)
>>>>          END DO
>>>>       END DO
>>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY , ierr)
>>>> !-----Create KSP and PC
>>>>       call KSPCreate(PETSC_COMM_WORLD,ksp, ierr)
>>>>       call KSPSetOperators(ksp,A,A, ierr)
>>>>       call KSPSetType(ksp,"bcgs",ierr)
>>>>       call KSPGetPC(ksp,pc,ierr)
>>>>       call KSPSetUp(ksp, ierr)
>>>>       call PCSetType(pc,PCGASM, ierr)
>>>>       call PCSetUp(pc , ierr)
>>>> !-----GASM setup
>>>>       NSubx = 4
>>>>       dof = 1
>>>>       overlap = 0
>>>>       call PCGASMCreateSubdomains2D(pc,
>>>>      &      M, M,
>>>>      &      NSubx, NSubx,
>>>>      &      dof, overlap,
>>>>      &      NSub, subdomains_IS, inflated_IS, ierr)
>>>>       call ISView(subdomains_IS, PETSC_VIEWER_STDOUT_WORLD, ierr)
>>>>       call KSPDestroy(ksp, ierr)
>>>>       call PetscFinalize(ierr)
>>>> Running this on one processor, I get NSub = 4.
>>>> If PCASM and PCASMCreateSubdomains2D are used instead, I get NSub = 16
>>>> as expected.
>>>> Moreover, I get in the end "forrtl: severe (157): Program Exception -
>>>> access violation". So:
>>>> 1) why do I get two different results with ASM, and GASM?
>>>> 2) why do I get access violation and how can I solve this?
>>>> In fact, in C, subdomains_IS, inflated_IS should pointers to IS
>>>> objects. As I see on the Fortran interface, the arguments to
>>>> PCGASMCreateSubdomains2D are IS objects:
>>>>        subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
>>>>        import tPC,tIS
>>>>        PC a ! PC
>>>>        PetscInt b ! PetscInt
>>>>        PetscInt c ! PetscInt
>>>>        PetscInt d ! PetscInt
>>>>        PetscInt e ! PetscInt
>>>>        PetscInt f ! PetscInt
>>>>        PetscInt g ! PetscInt
>>>>        PetscInt h ! PetscInt
>>>>        IS i ! IS
>>>>        IS j ! IS
>>>>        PetscErrorCode z
>>>>        end subroutine PCGASMCreateSubdomains2D
>>>> Thus:
>>>> 3) what should be inside e.g., subdomains_IS? I expect it to contain,
>>>> for every created subdomain, the list of rows and columns defining the
>>>> subblock in the matrix, am I right?
>>>> Context: I have a block-tridiagonal system arising from space-time
>>>> finite elements, and I want to solve it with GMRES+PCGASM preconditioner,
>>>> where each overlapping submatrix is on the diagonal and of size 3x3 blocks
>>>> (and spanning multiple processes). This is PETSc 3.17.1 on Windows.
>>>> Thanks in advance,
>>>> Leonardo
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/1ccaf966/attachment.html>
