[petsc-users] Scalable Solver for Incompressible Flow
Tue May 2 14:33:31 CDT 2023
On Tue, May 2, 2023 at 2:29 PM Jed Brown <jed at jedbrown.org> wrote:
> Sebastian Blauth <sebastian.blauth at itwm.fraunhofer.de> writes:
> > I agree with your comment for the Stokes equations - for these, I have
> > already tried and used the pressure mass matrix as part of a (additive)
> > block preconditioner and it gave mesh independent results.
> > However, for the Navier Stokes equations, is the Schur complement really
> > spectrally equivalent to the pressure mass matrix?
> No, it's not. You'd want something like PCD (better, but not algebraic) or
> LSC.
I think you can do a better job than that using something like
  https://arxiv.org/abs/1810.03315
Basically, you use an augmented Lagrangian thing to make the Schur
complement well-conditioned,
and then use a special smoother to handle that perturbation.
> > And even if it is, the convergence is only good for small Reynolds
> numbers, for moderately high ones the convergence really deteriorates. This
> is why I am trying to make fieldsplit_schur_precondition selfp work better
> (this is, if I understand it correctly, a SIMPLE type preconditioner).
> SIMPLE is for short time steps (not too far from resolving CFL) and bad
> for steady. This taxonomy is useful, though the problems are super academic
> and they don't use high aspect ratio.
> https://doi.org/10.1016/j.jcp.2007.09.026
      Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230502/f607366b/attachment-0001.html>
