[petsc-users] Fortran alternative for DMDAGetElements?
Fri Jun 30 08:08:30 CDT 2023
On Fri, Jun 30, 2023 at 8:38 AM Ngoc Mai Monica Huynh <
ngocmaimonica.huynh at unipv.it> wrote:
> Yes, it compiles and run correctly
Okay, then we try to alter that example until it looks like your test.
One thing is the #include at the top. Do you have that in your code? If
Fortran does not find the interface,
then it will just SEGV.
    Matt
> Monica
> On 30 Jun 2023, at 12:50, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 30, 2023 at 6:47 AM Ngoc Mai Monica Huynh <
>> Hi,
>> I have no problem now in compiling, thank you for providing the Fortran
>> interface.
>> I have a follow up question.
>> When running the code, I get this error, which I’m pretty sure it is
>> related to DMDAGetElements(), since up to that line everything works fine.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
>> [0]PETSC ERROR: ---------------------  Stack Frames
>> [0]PETSC ERROR: No error traceback is available, the problem could be in
>> the main program.
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> The lines of code I’m working on are the following:
>>       integer ierr
>>       MPI_Comm comm
>>       DM da3d
>>       ISLocalToGlobalMapping map
>>       PetscInt nel,nen
>>       PetscInt, pointer :: e_loc(:)
>>       call DMDACreate3d(comm,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,
>>      &                  DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,433,41,29,
>>      &                  8,2,1,3,1,PETSC_NULL_INTEGER,
>>      &                  PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
>>      &                  da3d,ierr)
>>       call DMSetMatType(da3d,MATIS,ierr)
>>       call DMSetFromOptions(da3d,ierr)
>>       call DMDASetElementType(da3d,DMDA_ELEMENT_Q1,ierr)
>>       call DMSetUp(da3d,ierr)
>>       call DMGetLocalToGlobalMapping(da3d,map,ierr)
>>       call DMDAGetElements(da3d,nel,nen,e_loc,ierr)
>> By printing in a dummy way any kind of message before and after
>> DMDAGetElements(), I cannot pass over it.
>> Unfortunately, I cannot run with the debug option on this machine.
>> Am I calling the routine in a wrong way?
> Does
>   src/dm/tutorials/ex11f90.F90
> run for you?
>   Thanks,
>      Matt
>> Thanks,
>> Monica
>> On 29 Jun 2023, at 21:09, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 29, 2023 at 3:05 PM Ngoc Mai Monica Huynh <
>>> Thank you.
>>> Does this mean that DMDARestoreElements() is supported as well now?
>> Yes.
>>  Thanks,
>>     Matt
>>> Monica
>>> Il giorno 29 giu 2023, alle ore 20:17, Barry Smith <bsmith at petsc.dev>
>>> ha scritto:
>>>   The code is ready in the branch
>>> *barry/2023-06-29/add-dmdagetelements-fortran *
>>> https://gitlab.com/petsc/petsc/-/merge_requests/6647
>>>   Barry
>>> On Jun 29, 2023, at 12:41 PM, Ngoc Mai Monica Huynh <
>>> That would be amazing, thank you very much!
>>> Monica
>>> On 29 Jun 2023, at 18:38, Barry Smith <bsmith at petsc.dev> wrote:
>>> I can provide the Fortran interface this afternoon.
>>>  Barry
>>> On Jun 29, 2023, at 10:48 AM, Ngoc Mai Monica Huynh <
>>> Hi everyone,
>>> I would need to use the routine DMDAGetElements() in our Fortran code.
>>> However, as I read from the manual, there is no Fortran support for this
>>> routine.
>>> Is there any similar alternative there?
>>> Many thanks!
>>> Best regards,
>>> Monica Huynh
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/203bf0c4/attachment-0001.html>
