[petsc-users] Fortran alternative for DMDAGetElements?
Ngoc Mai Monica Huynh ngocmaimonica.huynh at unipv.it
Fri Jun 30 07:38:38 CDT 2023
Yes, it compiles and run correctly
	Monica
> On 30 Jun 2023, at 12:50, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 30, 2023 at 6:47 AM Ngoc Mai Monica Huynh <ngocmaimonica.huynh at unipv.it <mailto:ngocmaimonica.huynh at unipv.it>> wrote:
> Hi,
> I have no problem now in compiling, thank you for providing the Fortran interface.
> I have a follow up question.
> When running the code, I get this error, which I’m pretty sure it is related to DMDAGetElements(), since up to that line everything works fine.
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind <https://petsc.org/release/faq/#valgrind> and https://petsc.org/release/faq/ <https://petsc.org/release/faq/>
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: No error traceback is available, the problem could be in the main program.
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> The lines of code I’m working on are the following:
>       integer ierr
>       MPI_Comm comm
>       DM da3d
>       ISLocalToGlobalMapping map
>       PetscInt nel,nen
>       PetscInt, pointer :: e_loc(:)
>       call DMDACreate3d(comm,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,
>      &                  DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,433,41,29,
>      &                  8,2,1,3,1,PETSC_NULL_INTEGER,
>      &                  PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
>      &                  da3d,ierr)
>       call DMSetMatType(da3d,MATIS,ierr)
>       call DMSetFromOptions(da3d,ierr)
>       call DMDASetElementType(da3d,DMDA_ELEMENT_Q1,ierr)
>       call DMSetUp(da3d,ierr)
>       call DMGetLocalToGlobalMapping(da3d,map,ierr)
>       call DMDAGetElements(da3d,nel,nen,e_loc,ierr)
> By printing in a dummy way any kind of message before and after DMDAGetElements(), I cannot pass over it.
> Unfortunately, I cannot run with the debug option on this machine.
> Am I calling the routine in a wrong way?
> Does
>   src/dm/tutorials/ex11f90.F90
> run for you?
>   Thanks,
>      Matt
> Thanks,
> 	Monica
>> On 29 Jun 2023, at 21:09, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Thu, Jun 29, 2023 at 3:05 PM Ngoc Mai Monica Huynh <ngocmaimonica.huynh at unipv.it <mailto:ngocmaimonica.huynh at unipv.it>> wrote:
>> Thank you.
>> Does this mean that DMDARestoreElements() is supported as well now?
>> Yes.
>>  Thanks,
>>     Matt
>> Monica
>>> Il giorno 29 giu 2023, alle ore 20:17, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> ha scritto:
>>>   The code is ready in the branch barry/2023-06-29/add-dmdagetelements-fortran https://gitlab.com/petsc/petsc/-/merge_requests/6647 <https://gitlab.com/petsc/petsc/-/merge_requests/6647>
>>>   Barry
>>>> On Jun 29, 2023, at 12:41 PM, Ngoc Mai Monica Huynh <ngocmaimonica.huynh at unipv.it <mailto:ngocmaimonica.huynh at unipv.it>> wrote:
>>>> That would be amazing, thank you very much!
>>>> 	Monica
>>>>> On 29 Jun 2023, at 18:38, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>> I can provide the Fortran interface this afternoon.
>>>>>  Barry
>>>>>> On Jun 29, 2023, at 10:48 AM, Ngoc Mai Monica Huynh <ngocmaimonica.huynh at unipv.it <mailto:ngocmaimonica.huynh at unipv.it>> wrote:
>>>>>> Hi everyone,
>>>>>> I would need to use the routine DMDAGetElements() in our Fortran code.
>>>>>> However, as I read from the manual, there is no Fortran support for this routine.
>>>>>> Is there any similar alternative there?
>>>>>> Many thanks!
>>>>>> Best regards,
>>>>>> 	Monica Huynh
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/60462b62/attachment.html>
