[petsc-users] Error while checking with ex19 after intallation
Barry Smith bsmith at petsc.dev
Sun Jun 25 22:03:03 CDT 2023
   Googling these messages find other people who have received similar messages while working Microsoft Windows  and MPI but nothing particularly helpful I could find.
   I am guessing an incompatibility between the Microsoft MPI and cl compiler you are using. I suggest installing the very latest of these both and see if the problem persists.
  Barry
> On Jun 25, 2023, at 10:43 PM, 冯上玮 <fengshw3 at mail2.sysu.edu.cn> wrote:
> Hi,
> Recently, I finally installed PETSc with Cygwin and obtained library files. However, the test of Ex19 was failed, both with 1 MPI and 2 MPI. The MPI used is MSMPI. The detailed message printed is
> $ make PETSC_DIR=/cygdrive/d/mypetsc PETSC_ARCH="" check
> Running check examples to verify correct installation
> Using PETSC_DIR=/cygdrive/d/mypetsc and PETSC_ARCH=
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See https://petsc.org/release/faq/
> job aborted:
> [ranks] message
> [0] process exited without calling finalize
> ---- error analysis -----
> [0] on LAPTOP-4FSVP96B
> ./ex19 ended prematurely and may have crashed. exit code 0xc00000fd
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> job aborted:
> [ranks] message
> [1] terminated
> Completed test examples
> Could you give any suggestions?
> Btw, my configuration command is
> ./configure --prefix=/cygdrive/d/mypetsc --with-cc='win32fe cl' --with-fc=0 --with-cxx=0 --download-f2cblaslapack --with-shared-libraries=0 --with-mpi-include='[/cygdrive/d/MicrosoftSDKs/MPI/Include,/cygdrive/d/MicrosoftSDKs/MPI/Include/x64]' --with-mpi-lib='[/cygdrive/d/MicrosoftSDKs/MPI/Lib/x64/msmpi.lib,/cygdrive/d/MicrosoftSDKs/MPI/Lib/x64/msmpifec.lib]' --with-mpiexec=/cygdrive/d/MicrosoftMPI/Bin/mpiexec
> Waiting for your reply and thanks very much,
> FENG
