[petsc-users] Inquiry about PetscDTSimplexQuadrature .
Sat Jun 24 07:54:06 CDT 2023
On Fri, Jun 23, 2023 at 10:12 PM neil liu <liufield at gmail.com> wrote:
> Thanks, Matt.
> It seems DMPlexComputeCellGeometryFEM  works well with the quadrature
> points to deliver Jacobian and inverse one.
> Will it be a good choice ?
Yes, it is intended to compute these quantities for you. Let me know if it
does not do what you want.
     Matt
> Have a good night.
> Thanks,
> On Fri, Jun 23, 2023 at 10:33 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Jun 23, 2023 at 10:28 AM neil liu <liufield at gmail.com> wrote:
>>> Dear Petsc developers,
>>> I am learning  *PetscDTSimplexQuadrature *and plan to use it.
>>> I found that, in the biunit simplex (tetra),
>>> (-1,-1,-1),(1,-1,-1),(-1,1,-1),(-1,-1,1),
>>> degree 1: npoints 4, the sum of weights = 4/3(the volume of this simplex)
>>> degree 2 : npoints 8;
>>> For my previous experience, I used Gauss quadrature rules, (npoints =4 ,
>>> 5, 11, 15).
>>> Then  I am curious what rule is Petsc using ?
>> There are two supported types:
>>   - Stroud Conical Quadrature
>>   - Minimal Symmetric Quadrature
>> I think we prefer symmetric when it is available.
>>> And is *PetscDTSimplexQuadrature *used by PetscFE?
>> Yes.
>>   Thanks,
>>     Matt
>>> Thanks a lot,
>>> Xiaodong
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230624/8898aab7/attachment.html>
