[petsc-users] How to efficiently fill in, in parallel, a PETSc matrix from a COO sparse matrix?
Barry Smith bsmith at petsc.dev
Wed Jun 21 13:23:09 CDT 2023
  These routines are marked as collective in their manual pages and must be called by all MPI processes that share the matrix A.
 PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
        PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
        PetscCall(MatView(A, PETSC_VIEWER_STDERR_WORLD));
> On Jun 21, 2023, at 2:16 PM, Diego Magela Lemos via petsc-users <petsc-users at mcs.anl.gov> wrote:
> So far, I've tried this:
> // fill_in_matrix.cc
> static char help[] = "Fill in a parallel COO format sparse matrix.";
> #include <petsc.h>
> #include <vector>
> int main(int argc, char **args)
>     MPI_Comm comm;
>     Mat A;
>     PetscInt m = 5;
>     PetscMPIInt rank, size;
>     PetscCall(PetscInitialize(&argc, &args, NULL, help));
>     comm = PETSC_COMM_WORLD;
>     PetscCallMPI(MPI_Comm_rank(comm, &rank));
>     PetscCallMPI(MPI_Comm_size(comm, &size));
>     PetscCall(MatCreate(comm, &A));
>     PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, m, m));
>     PetscCall(MatSetFromOptions(A));
>     PetscCall(MatSetUp(A));
>     std::vector<PetscInt> coo_i{0, 0, 1, 2, 3, 4};
>     std::vector<PetscInt> coo_j{0, 0, 1, 2, 3, 4};
>     std::vector<PetscScalar> coo_v{2, -1, 2, 3, 4, 5};
>     if (rank == 0)
>         for (size_t j = 0; j < coo_i.size(); j++)
>             PetscCall(MatSetValues(A,
>                                    1, &coo_i.at <http://coo_i.at/>(j),
>                                    1, &coo_j.at <http://coo_j.at/>(j),
>                                    &coo_v.at <http://coo_v.at/>(j),
>                                    ADD_VALUES));
>     PetscCall(MatDestroy(&A));
>     PetscCall(PetscFinalize());
>     return 0;
> When running with 1 process, it runs like a charm, but when running with more than one process, the code does not finish. Somehow it gets stuck forever.
> Em qua., 21 de jun. de 2023 às 14:12, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> escreveu:
>> On Wed, Jun 21, 2023 at 12:57 PM Diego Magela Lemos <diegomagela at usp.br <mailto:diegomagela at usp.br>> wrote:
>>> Unfortunately, I can modify ex2 to perform the matrix fill in using only one rank, although I have understood how it works.
>>> Is it so hard to do that?
>> It should not be. Maybe describe what is not clear? ex2 runs in parallel now.
>>   Thanks,
>>     Matt
>>> Thank you.
>>> Em qua., 21 de jun. de 2023 às 12:20, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> escreveu:
>>>> ex2 looks the same as the code at the beginning of the thread, which looks fine to me, yet fails.
>>>> (the only thing I can think of is that &v.at <http://v.at/>(i) is not doing what one wants)
>>>> Diego: I would start with this ex2.c, add your view statement, verify; incrementally change ex2 to your syntax and see where it breaks.
>>>> Mark
>>>> On Wed, Jun 21, 2023 at 9:50 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>> On Wed, Jun 21, 2023 at 9:22 AM Diego Magela Lemos <diegomagela at usp.br <mailto:diegomagela at usp.br>> wrote:
>>>>>> Please, could you provide a minimal working example (or link) of how to do this?
>>>>> You can see here
>>>>>   https://petsc.org/main/src/ksp/ksp/tutorials/ex2.c.html
>>>>> that each process only sets values for the rows it owns.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thank you.
>>>>>> Em ter., 20 de jun. de 2023 às 15:08, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> escreveu:
>>>>>>> On Tue, Jun 20, 2023 at 2:02 PM Diego Magela Lemos <diegomagela at usp.br <mailto:diegomagela at usp.br>> wrote:
>>>>>>>> So... what do I need to do, please?
>>>>>>>> Why am I getting wrong results when solving the linear system if the matrix is filled in with MatSetPreallocationCOO and MatSetValuesCOO?
>>>>>>> It appears that you have _all_ processes submit _all_ triples (i, j, v). Each triple can only be submitted by a single process. You can fix this in many ways. For example, an easy but suboptimal way is just to have process 0 submit them all, and all other processes submit nothing.
>>>>>>>   Thanks,
>>>>>>>   Matt
>>>>>>>> Em ter., 20 de jun. de 2023 às 14:56, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> escreveu:
>>>>>>>>> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
>>>>>>>>> >> The matrix entries are multiplied by 2, that is, the number of processes
>>>>>>>>> >> used to execute the code.
>>>>>>>>> > No. This was mostly intended for GPUs, where there is 1 process. If you
>>>>>>>>> > want to use multiple MPI processes, then each process can only introduce
>>>>>>>>> > some disjoint subset of the values. This is also how MatSetValues() works,
>>>>>>>>> > but it might not be as obvious.
>>>>>>>>> They need not be disjoint, just sum to the expected values. This interface is very convenient for FE and FV methods. MatSetValues with ADD_VALUES has similar semantics without the intermediate storage, but it forces you to submit one element matrix at a time. Classic parallelism granularity versus memory use tradeoff with MatSetValuesCOO being a clear win on GPUs and more nuanced for CPUs.
>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>>>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230621/810b53f8/attachment.html>
