[petsc-users] Bug in log_view printing
Jared Crean jcrean01 at gmail.com
Sun Jul 16 12:38:43 CDT 2023
Neat, I didn't know about the XML output.
   Jared Crean
On 7/16/2023 11:35 AM, Matthew Knepley wrote:
> On Sun, Jul 16, 2023 at 11:45 AM Jared Crean <jcrean01 at gmail.com> wrote:
>     Hello,
>        I stumbled upon a small bug in the printing of the data when
>     running
>     Petsc with -log_view.  The entire table is attached, but here is an
>     example row:
> Yes, we prescribe the exact number of spaces for each output, instead
> of allowing it to grow,
> so if the number exceeds the size, we lose our space. We wanted to
> keep the line length fixed.
> We do not recommend this form for processing. We usually use either
> the XML output for flame
> graphs since it does nesting, or the CSV output for processing with
> Pandas.
>   Thanks,
>      Matt
>     Event                Count      Time (sec)
>     Flop                              --- Global ---  --- Stage ---- Total
>                         Max Ratio  Max     Ratio   Max  Ratio Mess AvgLen
>     Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>     --- Event Stage 0: Main Stage
>     BuildTwoSided          7 1.0 1.3282e-0271.6 0.00e+00 0.0 6.0e+01
>     4.0e+00
>     5.0e+00  0  0  0  0  0   0  0  0  0  0     0
>        Notice how the Time Max and Time Ratio values are missing a space
>     separator (the other rows have only two digits for the exponents, I
>     think there should be a space after the e-02 and before the 7).
>        Configuration details:
>          * Petsc 3.17
>          * Arm64 architecture (and AWS c7g.xlarge instance, which use the
>     new Graviton3 processor)
>          * ubuntu 22.04
>          * MPICH MPI (version 4.0, I think, whatever apt-get install
>     mpich
>     gives)
>          * clang-15 compiler
>        Jared Crean
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230716/1fb2d706/attachment.html>
