[petsc-users] Smaller assemble time with increasing processors
Runfeng Jin jsfaraway at gmail.com
Mon Jul 3 09:05:25 CDT 2023
Thank you for all your help!
Runfeng
Matthew Knepley <knepley at gmail.com> 于2023年7月3日周一 22:03写道:
> On Mon, Jul 3, 2023 at 9:56 AM Runfeng Jin <jsfaraway at gmail.com> wrote:
>> Hi, impressive performance!
>>   I use the newest version of petsc(release branch), and it almost
>> deletes all assembly and stash time in large processors (assembly time
>> 64-4s/128-2s/256-0.2s, stash time all below 2s). For the zero programming
>> cost, it really incredible.
>>   The order code has a regular arrangement of the number of
>> nonzero-elements across rows, so I can have a good rough preallocation. And
>> from the data, dedicatedly arrange data and roughly acquiring the max
>> number of non-zero elements in rows can have a better performance than the
>> new version without preallocation. However, in reality, I will use the
>> newer version without preallocation for:1)less effort in programming and
>> also nearly the same good performance 2) good memory usage(I see no
>> unneeded memory after assembly) 3) dedicated preallocation is usually not
>> very easy and cause extra time cost.
>>    Maybe it will be better that leave some space for the user to do a
>> slight direction for the preallocation and thus acquire better performance.
>> But have no idea how to direct it.
>>    And I am very curious about how petsc achieves this. How can it not
>> know anything but achieve so good performance, and no wasted memory? May
>> you have an explanation about this?
> We use a hash table to store the nonzeros on the fly, and then convert to
> packed storage on assembly.
>   Thanks,
>      Matt
>> assemble time:
>> version\processors               4            8        16         32
>>      64        128         256
>>      old                             14677s   4694s   1124s     572s
>>   38s         8s          2s
>>      new                                50s      28s       15s
>> 7.8s         4s          2s        0.4s
>>      older                              27s       24s        19s
>>  12s         14s         -              -
>> stash time(max among all processors):
>>      64        128         256
>>      old                                 3145s   2554s   673s     329s
>>    201s     142s     138s
>>      new                                2s         1s        ~0s
>> ~0s         ~0s          ~0s       ~0s
>>      older                              10s       73s        18s
>>  5s            1s         -              -
>> old: my poor preallocation
>> new: newest version of petsc that do not preallocation
>> older: the best preallocation version of my code.
>> Runfeng
>> Barry Smith <bsmith at petsc.dev> 于2023年7月3日周一 12:19写道:
>>>    The main branch of PETSc now supports filling sparse matrices without
>>> providing any preallocation information.
>>>    You can give it a try. Use your current fastest code but just remove
>>> ALL the preallocation calls. I would be interested in what kind of
>>> performance you get compared to your best current performance.
>>>   Barry
>>> On Jul 2, 2023, at 11:24 PM, Runfeng Jin <jsfaraway at gmail.com> wrote:
>>> Hi! Good advice!
>>>     I set value with MatSetValues() API, which sets one part of a row at
>>> a time(I use a kind of tiling technology so I cannot get all values of a
>>> row at a time).
>>>     I tested the number of malloc in these three cases.  The number of
>>> mallocs is decreasing with the increase of processors, and all these are
>>> very large(the matrix is 283234*283234, as can see in the following). This
>>> should be due to the unqualified preallocation. I use a rough
>>> preallocation, that every processor counts the number of nonzero elements
>>> for the first 10 rows, and uses the largest one to preallocate memory for
>>> all local rows. It seems that not work well.
>>> number_of_processors   number_of_max_mallocs_among_all_processors
>>> 64                                     20000
>>> 128                                   17000
>>> 256                                   11000
>>>     I change my way to preallocate. I evenly take 100 rows in every
>>> local matrix and take the largest one to preallocate memory for all local
>>> rows. Now the assemble time is reduced to a very small time.
>>> 64                                     3000
>>> 128                                   700
>>> 256                                   500
>>> Event                Count          Time (sec)            Flop
>>>                                                     --- Global ---
>>>         --- Stage ----              Total
>>>                    Max Ratio        Max     Ratio       Max  Ratio
>>>  Mess            AvgLen  Reduct  %T %F %M %L %R        %T %F %M %L %R
>>> Mflop/s
>>> 64                 1    1.0       3.8999e+01 1.0     0.00e+00 0.0
>>> 7.1e+03     2.9e+05 1.1e+01 15  0  1  8  3                     15  0  1  8
>>>  3                  0
>>> 128               1    1.0       8.5714e+00 1.0     0.00e+00 0.0
>>> 2.6e+04     8.1e+04 1.1e+01  5  0  1  4  3                       5  0  1  4
>>>  3                   0
>>> 256               1    1.0        2.5512e+00 1.0    0.00e+00 0.0
>>> 1.0e+05     2.3e+04 1.1e+01  2  0  1  3  3                       2  0  1  3
>>>  3                   0
>>> So the reason "why assemble time is smaller with the increasing number
>>> of processors " may be because more processors divide the malloc job so
>>> that total time is reduced?
>>>  If so, I still have some questions:
>>>     1. If preallocation is not accurate, will the performance of the
>>> assembly be affected? I mean, when processors receive the elements that
>>> should be stored in their local by MPI, then will the new mallocs  happen
>>> at this time point?
>>>     2. I can not give an accurate preallocation for the large cost, so
>>> is there any better way to preallocate for my situation?
>>> Barry Smith <bsmith at petsc.dev> 于2023年7月2日周日 00:16写道:
>>>>    I see no reason not to trust the times below, they seem reasonable.
>>>> You get more than 2 times speed from 64 to 128 and then about 1.38 from 128
>>>> to 256.
>>>>    The total amount of data moved (number of messages moved times
>>>> average length) goes from 7.0e+03 * 2.8e+05  1.9600e+09 to 2.1060e+09
>>>> to 2.3000e+09. A pretty moderate amount of data increase, but note that
>>>> each time you double the number of ranks, you also increase substantially
>>>> the network's hardware to move data, so one would hope for a good speed up.
>>>>    Also, the load balance is very good, near 1. Often with assembly, we
>>>> see very out-of-balance, and it is difficult to get good speedup when the
>>>> balance is really off.
>>>>    It looks like over 90% of the entire run time is coming from setting
>>>> and assembling the values? Also the setting values time dominates assembly
>>>> time more with more ranks.  Are you setting a single value at a time or a
>>>> collection of them? How big are the vectors?
>>>>    Run all three cases with -info :vec to see some information about
>>>> how many mallocs where move to hold the stashed vector entries.
>>>> On Jun 30, 2023, at 10:25 PM, Runfeng Jin <jsfaraway at gmail.com> wrote:
>>>> Hi,
>>>>     Thanks for your reply. I try to use PetscLogEvent(), and the result
>>>> shows same conclusion.
>>>>     What I have done is :
>>>>     PetscLogEvent Mat_assemble_event, Mat_setvalue_event,
>>>> Mat_setAsse_event;
>>>>     PetscClassId classid;
>>>>     PetscLogDouble user_event_flops;
>>>>     PetscClassIdRegister("Test assemble and set value", &classid);
>>>>     PetscLogEventRegister("Test only assemble", classid,
>>>> &Mat_assemble_event);
>>>>     PetscLogEventRegister("Test only set values", classid,
>>>> &Mat_setvalue_event);
>>>>     PetscLogEventRegister("Test both assemble and set values", classid,
>>>> &Mat_setAsse_event);
>>>>     PetscLogEventBegin(Mat_setAsse_event, 0, 0, 0, 0);
>>>>     PetscLogEventBegin(Mat_setvalue_event, 0, 0, 0, 0);
>>>>     ...compute elements and use MatSetValues. No call for assembly
>>>>     PetscLogEventEnd(Mat_setvalue_event, 0, 0, 0, 0);
>>>>     PetscLogEventBegin(Mat_assemble_event, 0, 0, 0, 0);
>>>>     MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>>>>     MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>>>>     PetscLogEventEnd(Mat_assemble_event, 0, 0, 0, 0);
>>>>     PetscLogEventEnd(Mat_setAsse_event, 0, 0, 0, 0);
>>>>     And the output as follows. By the way, dose petsc recorde all time
>>>> between PetscLogEventBegin and PetscLogEventEnd? or just test the time of
>>>> petsc API?
>>>>    It is all of the time.
>>>>          --- Global ---  --- Stage ----  Total
>>>>                    Max Ratio  *Max*     Ratio   Max  Ratio  Mess
>>>> AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>> 64new               1 1.0 *2.3775e+02* 1.0 0.00e+00 0.0 6.2e+03
>>>> 2.3e+04 9.0e+00 52  0  1  1  2  52  0  1  1  2     0
>>>> 128new              1 1.0* 6.9945e+01* 1.0 0.00e+00 0.0 2.5e+04
>>>> 1.1e+04 9.0e+00 30  0  1  1  2  30  0  1  1  2     0
>>>> 256new              1 1.0 *1.7445e+01* 1.0 0.00e+00 0.0 9.9e+04
>>>> 5.2e+03 9.0e+00 10  0  1  1  2  10  0  1  1  2     0
>>>> 64:
>>>> only assemble       1 1.0 *2.6596e+02 *1.0 0.00e+00 0.0 7.0e+03
>>>> 2.8e+05 1.1e+01 55  0  1  8  3  55  0  1  8  3     0
>>>> only setvalues      1 1.0 *1.9987e+02* 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00 41  0  0  0  0  41  0  0  0  0     0
>>>> Test both           1 1.0 4.*6580e+02* 1.0 0.00e+00 0.0 7.0e+03
>>>> 2.8e+05 1.5e+01 96  0  1  8  4  96  0  1  8  4     0
>>>> 128:
>>>>  only assemble      1 1.0 *6.9718e+01* 1.0 0.00e+00 0.0 2.6e+04
>>>> 8.1e+04 1.1e+01 30  0  1  4  3  30  0  1  4  3     0
>>>> only setvalues      1 1.0 *1.4438e+02* 1.1 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00 60  0  0  0  0  60  0  0  0  0     0
>>>> Test both           1 1.0 *2.1417e+02* 1.0 0.00e+00 0.0 2.6e+04
>>>> 8.1e+04 1.5e+01 91  0  1  4  4  91  0  1  4  4     0
>>>> 256:
>>>> only assemble       1 1.0 *1.7482e+01* 1.0 0.00e+00 0.0 1.0e+05
>>>> 2.3e+04 1.1e+01 10  0  1  3  3  10  0  1  3  3     0
>>>> only setvalues      1 1.0 *1.3717e+02* 1.1 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00 78  0  0  0  0  78  0  0  0  0     0
>>>> Test both           1 1.0 *1.5475e+02* 1.0 0.00e+00 0.0 1.0e+05
>>>> 2.3e+04 1.5e+01 91  0  1  3  4  91  0  1  3  4     0
>>>> Runfeng
>>>> Barry Smith <bsmith at petsc.dev> 于2023年6月30日周五 23:35写道:
>>>>>    You cannot look just at the VecAssemblyEnd() time, that will very
>>>>> likely give the wrong impression of the total time it takes to put the
>>>>> values in.
>>>>>    You need to register a new Event and put a PetscLogEvent() just
>>>>> before you start generating the vector entries and calling VecSetValues()
>>>>> and put the PetscLogEventEnd() just after the VecAssemblyEnd() this is the
>>>>> only way to get an accurate accounting of the time.
>>>>>   Barry
>>>>> > On Jun 30, 2023, at 11:21 AM, Runfeng Jin <jsfaraway at gmail.com>
>>>>> wrote:
>>>>> > Hello!
>>>>> > When I use PETSc build a sbaij matrix, I find a strange thing. When
>>>>> I increase the number of processors, the assemble time become smaller. All
>>>>> these are totally same matrix. The assemble time mainly arouse from message
>>>>> passing, which because I use dynamic workload that it is random for which
>>>>> elements are computed by which processor.
>>>>> > But from instinct, if use more processors, then more possible that
>>>>> the processor computes elements storing in other processors. But from the
>>>>> output of log_view, It seems when use more processors, the processors
>>>>> compute more elements storing in its local(infer from that, with more
>>>>> processors, less total amount of passed messages).
>>>>> > What could cause this happened? Thank you!
>>>>> >  Following is the output of log_view for 64\128\256 processors.
>>>>> Every row is time profiler of VecAssemblyEnd.
>>>>> > processors                Count                      Time (sec)
>>>>>                                 Flop
>>>>>                        --- Global ---                               ---
>>>>> Stage ----                Total
>>>>> >                               Max    Ratio         Max
>>>>>     Ratio                 Max  Ratio      Mess        AvgLen
>>>>> > 64                            1     1.0            2.3775e+02
>>>>> 1.0                   0.00e+00 0.0      6.2e+03    2.3e+04     9.0e+00
>>>>>        0
>>>>> > 128                          1     1.0            6.9945e+01
>>>>> 1.0                   0.00e+00 0.0      2.5e+04    1.1e+04     9.0e+00
>>>>>        0
>>>>> > 256                          1     1.0           1.7445e+01
>>>>> 1.0                  0.00e+00 0.0      9.9e+04     5.2e+03    9.0e+00
>>>>>        0
>>>>> > Runfeng Jin
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230703/56f8375e/attachment-0001.html>
