[petsc-users] Smaller assemble time with increasing processors
Mon Jul 3 09:03:45 CDT 2023
On Mon, Jul 3, 2023 at 9:56 AM Runfeng Jin <jsfaraway at gmail.com> wrote:
> Hi, impressive performance!
>   I use the newest version of petsc(release branch), and it almost deletes
> all assembly and stash time in large processors (assembly time
> 64-4s/128-2s/256-0.2s, stash time all below 2s). For the zero programming
> cost, it really incredible.
>   The order code has a regular arrangement of the number of
> nonzero-elements across rows, so I can have a good rough preallocation. And
> from the data, dedicatedly arrange data and roughly acquiring the max
> number of non-zero elements in rows can have a better performance than the
> new version without preallocation. However, in reality, I will use the
> newer version without preallocation for:1)less effort in programming and
> also nearly the same good performance 2) good memory usage(I see no
> unneeded memory after assembly) 3) dedicated preallocation is usually not
> very easy and cause extra time cost.
>    Maybe it will be better that leave some space for the user to do a
> slight direction for the preallocation and thus acquire better performance.
> But have no idea how to direct it.
>    And I am very curious about how petsc achieves this. How can it not
> know anything but achieve so good performance, and no wasted memory? May
> you have an explanation about this?
We use a hash table to store the nonzeros on the fly, and then convert to
packed storage on assembly.
     Matt
> assemble time:
> version\processors               4            8        16         32
>      64        128         256
>      old                             14677s   4694s   1124s     572s
>   38s         8s          2s
>      new                                50s      28s       15s
> 7.8s         4s          2s        0.4s
>      older                              27s       24s        19s
>  12s         14s         -              -
> stash time(max among all processors):
>      64        128         256
>      old                                 3145s   2554s   673s     329s
>    201s     142s     138s
>      new                                2s         1s        ~0s
> ~0s         ~0s          ~0s       ~0s
>      older                              10s       73s        18s       5s
>           1s         -              -
> old: my poor preallocation
> new: newest version of petsc that do not preallocation
> older: the best preallocation version of my code.
> Runfeng
> Barry Smith <bsmith at petsc.dev> 于2023年7月3日周一 12:19写道:
>>    The main branch of PETSc now supports filling sparse matrices without
>> providing any preallocation information.
>>    You can give it a try. Use your current fastest code but just remove
>> ALL the preallocation calls. I would be interested in what kind of
>> performance you get compared to your best current performance.
>>   Barry
>> On Jul 2, 2023, at 11:24 PM, Runfeng Jin <jsfaraway at gmail.com> wrote:
>> Hi! Good advice!
>>     I set value with MatSetValues() API, which sets one part of a row at
>> a time(I use a kind of tiling technology so I cannot get all values of a
>> row at a time).
>>     I tested the number of malloc in these three cases.  The number of
>> mallocs is decreasing with the increase of processors, and all these are
>> very large(the matrix is 283234*283234, as can see in the following). This
>> should be due to the unqualified preallocation. I use a rough
>> preallocation, that every processor counts the number of nonzero elements
>> for the first 10 rows, and uses the largest one to preallocate memory for
>> all local rows. It seems that not work well.
>> number_of_processors   number_of_max_mallocs_among_all_processors
>> 64                                     20000
>> 128                                   17000
>> 256                                   11000
>>     I change my way to preallocate. I evenly take 100 rows in every local
>> matrix and take the largest one to preallocate memory for all local rows.
>> Now the assemble time is reduced to a very small time.
>> 64                                     3000
>> 128                                   700
>> 256                                   500
>> Event                Count          Time (sec)            Flop
>>                                                   --- Global ---
>>       --- Stage ----              Total
>>                    Max Ratio        Max     Ratio       Max  Ratio  Mess
>>           AvgLen  Reduct  %T %F %M %L %R        %T %F %M %L %R    Mflop/s
>> 64                 1    1.0       3.8999e+01 1.0     0.00e+00 0.0
>> 7.1e+03     2.9e+05 1.1e+01 15  0  1  8  3                     15  0  1  8
>>  3                  0
>> 128               1    1.0       8.5714e+00 1.0     0.00e+00 0.0 2.6e+04
>>    8.1e+04 1.1e+01  5  0  1  4  3                       5  0  1  4  3
>>              0
>> 256               1    1.0        2.5512e+00 1.0    0.00e+00 0.0 1.0e+05
>>    2.3e+04 1.1e+01  2  0  1  3  3                       2  0  1  3  3
>>              0
>> So the reason "why assemble time is smaller with the increasing number of
>> processors " may be because more processors divide the malloc job so that
>> total time is reduced?
>>  If so, I still have some questions:
>>     1. If preallocation is not accurate, will the performance of the
>> assembly be affected? I mean, when processors receive the elements that
>> should be stored in their local by MPI, then will the new mallocs  happen
>> at this time point?
>>     2. I can not give an accurate preallocation for the large cost, so is
>> there any better way to preallocate for my situation?
>> Barry Smith <bsmith at petsc.dev> 于2023年7月2日周日 00:16写道:
>>>    I see no reason not to trust the times below, they seem reasonable.
>>> You get more than 2 times speed from 64 to 128 and then about 1.38 from 128
>>> to 256.
>>>    The total amount of data moved (number of messages moved times
>>> average length) goes from 7.0e+03 * 2.8e+05  1.9600e+09 to 2.1060e+09
>>> to 2.3000e+09. A pretty moderate amount of data increase, but note that
>>> each time you double the number of ranks, you also increase substantially
>>> the network's hardware to move data, so one would hope for a good speed up.
>>>    Also, the load balance is very good, near 1. Often with assembly, we
>>> see very out-of-balance, and it is difficult to get good speedup when the
>>> balance is really off.
>>>    It looks like over 90% of the entire run time is coming from setting
>>> and assembling the values? Also the setting values time dominates assembly
>>> time more with more ranks.  Are you setting a single value at a time or a
>>> collection of them? How big are the vectors?
>>>    Run all three cases with -info :vec to see some information about how
>>> many mallocs where move to hold the stashed vector entries.
>>> On Jun 30, 2023, at 10:25 PM, Runfeng Jin <jsfaraway at gmail.com> wrote:
>>> Hi,
>>>     Thanks for your reply. I try to use PetscLogEvent(), and the result
>>> shows same conclusion.
>>>     What I have done is :
>>>     PetscLogEvent Mat_assemble_event, Mat_setvalue_event,
>>> Mat_setAsse_event;
>>>     PetscClassId classid;
>>>     PetscLogDouble user_event_flops;
>>>     PetscClassIdRegister("Test assemble and set value", &classid);
>>>     PetscLogEventRegister("Test only assemble", classid,
>>> &Mat_assemble_event);
>>>     PetscLogEventRegister("Test only set values", classid,
>>> &Mat_setvalue_event);
>>>     PetscLogEventRegister("Test both assemble and set values", classid,
>>> &Mat_setAsse_event);
>>>     PetscLogEventBegin(Mat_setAsse_event, 0, 0, 0, 0);
>>>     PetscLogEventBegin(Mat_setvalue_event, 0, 0, 0, 0);
>>>     ...compute elements and use MatSetValues. No call for assembly
>>>     PetscLogEventEnd(Mat_setvalue_event, 0, 0, 0, 0);
>>>     PetscLogEventBegin(Mat_assemble_event, 0, 0, 0, 0);
>>>     MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>>>     MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>>>     PetscLogEventEnd(Mat_assemble_event, 0, 0, 0, 0);
>>>     PetscLogEventEnd(Mat_setAsse_event, 0, 0, 0, 0);
>>>     And the output as follows. By the way, dose petsc recorde all time
>>> between PetscLogEventBegin and PetscLogEventEnd? or just test the time of
>>> petsc API?
>>>    It is all of the time.
>>>          --- Global ---  --- Stage ----  Total
>>>                    Max Ratio  *Max*     Ratio   Max  Ratio  Mess
>>> 64new               1 1.0 *2.3775e+02* 1.0 0.00e+00 0.0 6.2e+03 2.3e+04
>>> 9.0e+00 52  0  1  1  2  52  0  1  1  2     0
>>> 128new              1 1.0* 6.9945e+01* 1.0 0.00e+00 0.0 2.5e+04 1.1e+04
>>> 9.0e+00 30  0  1  1  2  30  0  1  1  2     0
>>> 256new              1 1.0 *1.7445e+01* 1.0 0.00e+00 0.0 9.9e+04 5.2e+03
>>> 9.0e+00 10  0  1  1  2  10  0  1  1  2     0
>>> 64:
>>> only assemble       1 1.0 *2.6596e+02 *1.0 0.00e+00 0.0 7.0e+03 2.8e+05
>>> 1.1e+01 55  0  1  8  3  55  0  1  8  3     0
>>> only setvalues      1 1.0 *1.9987e+02* 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00 41  0  0  0  0  41  0  0  0  0     0
>>> Test both           1 1.0 4.*6580e+02* 1.0 0.00e+00 0.0 7.0e+03 2.8e+05
>>> 1.5e+01 96  0  1  8  4  96  0  1  8  4     0
>>> 128:
>>>  only assemble      1 1.0 *6.9718e+01* 1.0 0.00e+00 0.0 2.6e+04 8.1e+04
>>> 1.1e+01 30  0  1  4  3  30  0  1  4  3     0
>>> only setvalues      1 1.0 *1.4438e+02* 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00 60  0  0  0  0  60  0  0  0  0     0
>>> Test both           1 1.0 *2.1417e+02* 1.0 0.00e+00 0.0 2.6e+04 8.1e+04
>>> 1.5e+01 91  0  1  4  4  91  0  1  4  4     0
>>> 256:
>>> only assemble       1 1.0 *1.7482e+01* 1.0 0.00e+00 0.0 1.0e+05 2.3e+04
>>> 1.1e+01 10  0  1  3  3  10  0  1  3  3     0
>>> only setvalues      1 1.0 *1.3717e+02* 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00 78  0  0  0  0  78  0  0  0  0     0
>>> Test both           1 1.0 *1.5475e+02* 1.0 0.00e+00 0.0 1.0e+05 2.3e+04
>>> 1.5e+01 91  0  1  3  4  91  0  1  3  4     0
>>> Runfeng
>>> Barry Smith <bsmith at petsc.dev> 于2023年6月30日周五 23:35写道:
>>>>    You cannot look just at the VecAssemblyEnd() time, that will very
>>>> likely give the wrong impression of the total time it takes to put the
>>>> values in.
>>>>    You need to register a new Event and put a PetscLogEvent() just
>>>> before you start generating the vector entries and calling VecSetValues()
>>>> and put the PetscLogEventEnd() just after the VecAssemblyEnd() this is the
>>>> only way to get an accurate accounting of the time.
>>>>   Barry
>>>> > On Jun 30, 2023, at 11:21 AM, Runfeng Jin <jsfaraway at gmail.com>
>>>> wrote:
>>>> > Hello!
>>>> > When I use PETSc build a sbaij matrix, I find a strange thing. When I
>>>> increase the number of processors, the assemble time become smaller. All
>>>> these are totally same matrix. The assemble time mainly arouse from message
>>>> passing, which because I use dynamic workload that it is random for which
>>>> elements are computed by which processor.
>>>> > But from instinct, if use more processors, then more possible that
>>>> the processor computes elements storing in other processors. But from the
>>>> output of log_view, It seems when use more processors, the processors
>>>> compute more elements storing in its local(infer from that, with more
>>>> processors, less total amount of passed messages).
>>>> > What could cause this happened? Thank you!
>>>> >  Following is the output of log_view for 64\128\256 processors. Every
>>>> row is time profiler of VecAssemblyEnd.
>>>> > processors                Count                      Time (sec)
>>>>                                 Flop
>>>>                        --- Global ---                               ---
>>>> Stage ----                Total
>>>> >                               Max    Ratio         Max
>>>>   Ratio                 Max  Ratio      Mess        AvgLen         Reduct
>>>> > 64                            1     1.0            2.3775e+02
>>>> 1.0                   0.00e+00 0.0      6.2e+03    2.3e+04     9.0e+00
>>>>        0
>>>> > 128                          1     1.0            6.9945e+01
>>>> 1.0                   0.00e+00 0.0      2.5e+04    1.1e+04     9.0e+00
>>>>        0
>>>> > 256                          1     1.0           1.7445e+01
>>>> 1.0                  0.00e+00 0.0      9.9e+04     5.2e+03    9.0e+00
>>>>        0
>>>> > Runfeng Jin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230703/ddb188e3/attachment-0001.html>
