[petsc-users] Smaller assemble time with increasing processors
Barry Smith bsmith at petsc.dev
Sat Jul 1 11:16:36 CDT 2023
   I see no reason not to trust the times below, they seem reasonable. You get more than 2 times speed from 64 to 128 and then about 1.38 from 128 to 256.
   The total amount of data moved (number of messages moved times average length) goes from 7.0e+03 * 2.8e+05  1.9600e+09 to 2.1060e+09 to 2.3000e+09. A pretty moderate amount of data increase, but note that each time you double the number of ranks, you also increase substantially the network's hardware to move data, so one would hope for a good speed up.
   Also, the load balance is very good, near 1. Often with assembly, we see very out-of-balance, and it is difficult to get good speedup when the balance is really off.
   It looks like over 90% of the entire run time is coming from setting and assembling the values? Also the setting values time dominates assembly time more with more ranks.  Are you setting a single value at a time or a collection of them? How big are the vectors?
   Run all three cases with -info :vec to see some information about how many mallocs where move to hold the stashed vector entries.
> On Jun 30, 2023, at 10:25 PM, Runfeng Jin <jsfaraway at gmail.com> wrote:
> Hi,
>     Thanks for your reply. I try to use PetscLogEvent(), and the result shows same conclusion.
>     What I have done is :
>     PetscLogEvent Mat_assemble_event, Mat_setvalue_event, Mat_setAsse_event;
>     PetscClassId classid;
>     PetscLogDouble user_event_flops;
>     PetscClassIdRegister("Test assemble and set value", &classid);
>     PetscLogEventRegister("Test only assemble", classid, &Mat_assemble_event);
>     PetscLogEventRegister("Test only set values", classid, &Mat_setvalue_event);
>     PetscLogEventRegister("Test both assemble and set values", classid, &Mat_setAsse_event);
>     PetscLogEventBegin(Mat_setAsse_event, 0, 0, 0, 0);
>     PetscLogEventBegin(Mat_setvalue_event, 0, 0, 0, 0);
>     ...compute elements and use MatSetValues. No call for assembly
>     PetscLogEventEnd(Mat_setvalue_event, 0, 0, 0, 0);
>     PetscLogEventBegin(Mat_assemble_event, 0, 0, 0, 0);
>     MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>     PetscLogEventEnd(Mat_assemble_event, 0, 0, 0, 0);
>     PetscLogEventEnd(Mat_setAsse_event, 0, 0, 0, 0);
>     And the output as follows. By the way, dose petsc recorde all time between PetscLogEventBegin and PetscLogEventEnd? or just test the time of petsc API?
   It is all of the time.
> Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> 64new               1 1.0 2.3775e+02 1.0 0.00e+00 0.0 6.2e+03 2.3e+04 9.0e+00 52  0  1  1  2  52  0  1  1  2     0
> 128new              1 1.0 6.9945e+01 1.0 0.00e+00 0.0 2.5e+04 1.1e+04 9.0e+00 30  0  1  1  2  30  0  1  1  2     0
> 256new              1 1.0 1.7445e+01 1.0 0.00e+00 0.0 9.9e+04 5.2e+03 9.0e+00 10  0  1  1  2  10  0  1  1  2     0
> 64:
> only assemble       1 1.0 2.6596e+02 1.0 0.00e+00 0.0 7.0e+03 2.8e+05 1.1e+01 55  0  1  8  3  55  0  1  8  3     0
> only setvalues      1 1.0 1.9987e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 41  0  0  0  0  41  0  0  0  0     0
> Test both           1 1.0 4.6580e+02 1.0 0.00e+00 0.0 7.0e+03 2.8e+05 1.5e+01 96  0  1  8  4  96  0  1  8  4     0
> 128:
>  only assemble      1 1.0 6.9718e+01 1.0 0.00e+00 0.0 2.6e+04 8.1e+04 1.1e+01 30  0  1  4  3  30  0  1  4  3     0
> only setvalues      1 1.0 1.4438e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 60  0  0  0  0  60  0  0  0  0     0
> Test both           1 1.0 2.1417e+02 1.0 0.00e+00 0.0 2.6e+04 8.1e+04 1.5e+01 91  0  1  4  4  91  0  1  4  4     0
> 256:
> only assemble       1 1.0 1.7482e+01 1.0 0.00e+00 0.0 1.0e+05 2.3e+04 1.1e+01 10  0  1  3  3  10  0  1  3  3     0
> only setvalues      1 1.0 1.3717e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 78  0  0  0  0  78  0  0  0  0     0
> Test both           1 1.0 1.5475e+02 1.0 0.00e+00 0.0 1.0e+05 2.3e+04 1.5e+01 91  0  1  3  4  91  0  1  3  4     0
> Runfeng
> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> 于2023年6月30日周五 23:35写道:
>>    You cannot look just at the VecAssemblyEnd() time, that will very likely give the wrong impression of the total time it takes to put the values in.
>>    You need to register a new Event and put a PetscLogEvent() just before you start generating the vector entries and calling VecSetValues() and put the PetscLogEventEnd() just after the VecAssemblyEnd() this is the only way to get an accurate accounting of the time.
>>   Barry
>> > On Jun 30, 2023, at 11:21 AM, Runfeng Jin <jsfaraway at gmail.com <mailto:jsfaraway at gmail.com>> wrote:
>> > Hello!
>> > When I use PETSc build a sbaij matrix, I find a strange thing. When I increase the number of processors, the assemble time become smaller. All these are totally same matrix. The assemble time mainly arouse from message passing, which because I use dynamic workload that it is random for which elements are computed by which processor.
>> > But from instinct, if use more processors, then more possible that the processor computes elements storing in other processors. But from the output of log_view, It seems when use more processors, the processors compute more elements storing in its local(infer from that, with more processors, less total amount of passed messages).
>> > What could cause this happened? Thank you!
>> >  Following is the output of log_view for 64\128\256 processors. Every row is time profiler of VecAssemblyEnd.
>> > processors                Count                      Time (sec)                                      Flop                                                               --- Global ---                               --- Stage ----                Total
>> > 64                            1     1.0            2.3775e+02      1.0                   0.00e+00 0.0      6.2e+03    2.3e+04     9.0e+00                 52  0      1    1    2             52   0    1      1     2             0
>> > 128                          1     1.0            6.9945e+01      1.0                   0.00e+00 0.0      2.5e+04    1.1e+04     9.0e+00                30   0      1     1  2              30   0    1       1    2             0
>> > 256                          1     1.0           1.7445e+01        1.0                  0.00e+00 0.0      9.9e+04     5.2e+03    9.0e+00                10   0      1     1  2              10   0    1        1   2             0
>> > Runfeng Jin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230701/6f7694cc/attachment-0002.html>
