[petsc-users] unable to distribute rows of a matrix across processors while loading
Sun Aug 27 08:04:51 CDT 2023
On Sun, Aug 27, 2023 at 8:30 AM maitri ksh <maitri.ksh at gmail.com> wrote:
> Hi,
> I am using MatSetSizes() followed by MatLoad() to distribute the rows of a
> *sparse* matrix (*480000x480000*) across the processors. But it seems
> like the entire matrix is getting loaded in each of the processors instead
> of distributing it. What am I missing here?
> *code snippet:*
>     Mat         Js;
>     MatType     type = MATMPIAIJ;
>     PetscViewer viewerJ;
>     PetscCall(PetscViewerBinaryOpen(PETSC_COMM_WORLD, "Js.dat",
> FILE_MODE_READ, &viewerJ));
>     PetscCall(MatCreate(PETSC_COMM_WORLD, &Js));
>     PetscCall(MatSetSizes(Js, PETSC_DECIDE, PETSC_DECIDE, N, N));
>     PetscCall(MatSetType(Js, type));
>     PetscCall(MatLoad(Js, viewerJ));
>     PetscCall(PetscViewerDestroy(&viewerJ));
>     PetscCall(MatGetLocalSize(Js, &m, &n));
>     PetscCall(MatGetSize(Js, &M, &N));
>     PetscPrintf(PETSC_COMM_WORLD, "Js,Local rows: %d, Local columns:
> %d\n", m, n);
If this was really PETSC_COMM_WORLD, then this print statement would only
output once, but you have 4 lines. Therefore, MPI is messed up. I am
guessing you used an 'mpirun' or 'mpiexec' that is from a different MPI,
and therefore the launch did not work correctly. If you had PETSc install
MPI, then the correct one is in
  ${PETSC_DIR}/${PETSC_ARCH}/bin/mpiexec
     Matt
> *Output *of  'mpiexec -n 4 ./check':
> Js,Local rows: 480000, Local columns: 480000
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230827/06a9dc00/attachment-0001.html>
