[petsc-users] issue with multiple versions of mpi
Tue Aug 15 15:51:25 CDT 2023
Do you get this error when you compile a PETSc example [with the
corresponding PETSc makefile]?
If not - you'll have to check the difference in compiler options
between this example compile - and your application.
Satish
On Tue, 15 Aug 2023, maitri ksh wrote:
> I was earlier using petsc with real-built, i tried configuring it for a
> complex environment using the same procedure (at least I think so) but with
> the addition of '--with-scalar-type=complex'. There appears to be no
> problem during the configuration process and its checks ('*configure.log*'
> is attached). But while compiling code, I ran into an error message
> concerning conflicts due to multiple versions of mpi. How do I resolve
> this?
