[petsc-users] issue with multiple versions of mpi
maitri ksh maitri.ksh at gmail.com
Tue Aug 15 15:37:05 CDT 2023
I was earlier using petsc with real-built, i tried configuring it for a
complex environment using the same procedure (at least I think so) but with
the addition of '--with-scalar-type=complex'. There appears to be no
problem during the configuration process and its checks ('*configure.log*'
is attached). But while compiling code, I ran into an error message
concerning conflicts due to multiple versions of mpi. How do I resolve
this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230815/8aa8a681/attachment-0001.html>
/bin/ld: warning: libmpi.so.12, needed by /home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so, may conflict with libmpi.so.40
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_comm_create_multiplex'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_indexed_block_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Allreduce_enqueue_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Allreduce_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_recv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gather_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_set_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Intercomm_create_from_groups'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_get_num_psets'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stop_progress_thread'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gather_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Issend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Igather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgatherv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Pack_external_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Rput_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Pready'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_progress'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Start_progress_thread'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Isendrecv_replace_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_recv'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallw_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Unpack_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_send_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stream_free'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_GPU_query_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iallgather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_get_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Barrier_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_get_envelope_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ireduce_scatter_block_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ibsend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgatherv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Bsend_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Delete_error_string'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_isend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Exscan_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Buffer_detach_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Rsend_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Delete_error_code'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgatherv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Win_get_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_get_nth_pset'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Accumulate_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_hindexed_block_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Query_ze_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_create_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_get_pset_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Delete_error_string'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Igatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Win_allocate_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_indexed_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allreduce_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Irecv_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Query_ze_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoall_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Wait_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Rget_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Imrecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Isend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_get_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Type_set_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallw_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Get_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatter_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Precv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallw_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scan_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Parrived'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_irecv'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Bcast_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Register_datarep_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ssend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatter_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_hindexed_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Unpack_external_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_contiguous_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Pready'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Wait_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgatherv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Delete_error_code'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stream_comm_create_multiplex'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Group_from_session_pset'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Comm_get_failed'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Send_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Exscan_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Comm_set_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Query_cuda_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Irecv_enqueue_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iscan_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoall_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Rsend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Info_create_env'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ialltoallw_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ineighbor_alltoall_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Bcast_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatter_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stream_create'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_irecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Recv_enqueue_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_set_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Grequest_set_lang_f77'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Isendrecv_replace'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Get_count_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatterv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Bsend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatterv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_hvector_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Waitall_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stream_comm_create'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Bcast_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Comm_idup_with_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Parrived'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_struct_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Recv_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Raccumulate_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Intercomm_create_from_groups'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ineighbor_alltoallw_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scan_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_get_num_psets'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoall_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Rget_accumulate_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Win_create_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_call_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_GPU_query_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Win_set_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Comm_get_failed'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Info_get_string'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allreduce_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_block_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Recv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Pready_range'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Buffer_attach_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Info_get_string'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Waitall_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Pack_external_size_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_call_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgather_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_subarray_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoall_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ssend_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ireduce_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Get_accumulate_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_send'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Keyval_set_proxy'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_block_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Irsend_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Type_get_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Start_progress_thread'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallw_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Put_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allreduce_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Get_elements_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Pack_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scatterv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_get_contents_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Query_hip_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_block_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_create_darray_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Status_set_elements_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stop_progress_thread'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Op_create_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgather_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Info_set_hex'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoall_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ineighbor_allgatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_get_nth_pset'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_vector_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallw_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Send_enqueue_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ineighbor_alltoallv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_create'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_get_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iexscan_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Exscan_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Isend_enqueue_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Stream_progress'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPII_Comm_get_attr'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Alltoallv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iscatterv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Delete_error_class'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Sendrecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Isend_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gatherv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_local_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Isendrecv'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPIX_Comm_get_stream'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Recv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Psend_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_get_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Sendrecv_replace_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallw_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iscatter_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Isendrecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Send_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Pready_list'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Comm_create_from_group'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iallgatherv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Gatherv_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoallv_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Type_size_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_free'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_allgather_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Pack_size_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Scan_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Send_enqueue'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_finalize'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Group_from_session_pset'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Pready_range'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Allgather_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ibcast_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Neighbor_alltoall_init_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Mrecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_get_pset_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Info_create_env'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ireduce_scatter_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Iallreduce_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Session_finalize'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Query_hip_support'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ineighbor_allgather_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Session_create_errhandler'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Comm_get_stream'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_comm_create'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Delete_error_class'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Comm_create_from_group'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Win_allocate_shared_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Comm_idup_with_info'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Barrier_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ialltoall_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Win_shared_query_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Irecv_c'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Reduce_scatter_init'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `PMPI_Pready_list'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPIX_Stream_isend'
/home/maitri.ksh/Maitri/petsc/linux-gnu-c-debug/lib/libmpifort.so: undefined reference to `MPI_Ialltoallv_c'
collect2: error: ld returned 1 exit status
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230815/8aa8a681/attachment-0001.obj>
