[petsc-users] Python PETSc performance vs scipy ZVODE
Niclas Götting ngoetting at itp.uni-bremen.de
Thu Aug 10 04:40:04 CDT 2023
Thank you both for the very quick answer!
So far, I compiled PETSc with debugging turned on, but I think it should
still be faster than standard scipy in both cases. Actually, Stefano's
answer has got me very far already; now I only define the RHS of the ODE
and no Jacobian (I wonder, why the documentation suggests otherwise,
though). I had the following four tries at implementing the RHS:
 1. def rhsfunc1(ts, t, u, F):
         scale = 0.5 * (5 < t < 10)
         (l + scale * pump).mult(u, F)
 2. def rhsfunc2(ts, t, u, F):
         l.mult(u, F)
         (scale * pump).multAdd(u, F, F)
 3. def rhsfunc3(ts, t, u, F):
         l.mult(u, F)
         if scale != 0:
             pump.scale(scale)
             pump.multAdd(u, F, F)
             pump.scale(1/scale)
 4. def rhsfunc4(ts, t, u, F):
         tmp_pump.zeroEntries() # tmp_pump is pump.duplicate()
         l.mult(u, F)
         tmp_pump.axpy(scale, pump,
    structure=PETSc.Mat.Structure.SAME_NONZERO_PATTERN)
         tmp_pump.multAdd(u, F, F)
They all yield the same results, but with 50it/s, 800it/, 2300it/s and
1900it/s, respectively, which is a huge performance boost (almost 7
times as fast as scipy, with PETSc debugging still turned on). As the
scale function will most likely be a gaussian in the future, I think
that option 3 will be become numerically unstable and I'll have to go
with option 4, which is already faster than I expected. If you think it
is possible to speed up the RHS calculation even more, I'd be happy to
hear your suggestions; the -log_view is attached to this message.
One last point: If I didn't misunderstand the documentation at
https://petsc.org/release/manual/ts/#special-cases, should this maybe be
changed?
Best regards
Niclas
On 09.08.23 17:51, Stefano Zampini wrote:
> TSRK is an explicit solver. Unless you are changing the ts type from
> command line,  the explicit  jacobian should not be needed. On top of
> Barry's suggestion, I would suggest you to write the explicit RHS
> instead of assembly a throw away matrix every time that function needs
> to be sampled.
> On Wed, Aug 9, 2023, 17:09 Niclas Götting
> <ngoetting at itp.uni-bremen.de> wrote:
>     Hi all,
>     I'm currently trying to convert a quantum simulation from scipy to
>     PETSc. The problem itself is extremely simple and of the form
>     \dot{u}(t)
>     = (A_const + f(t)*B_const)*u(t), where f(t) in this simple test
>     case is
>     a square function. The matrices A_const and B_const are extremely
>     sparse
>     and therefore I thought, the problem will be well suited for PETSc.
>     Currently, I solve the ODE with the following procedure in scipy
>     (I can
>     provide the necessary data files, if needed, but they are just some
>     trace-preserving, very sparse matrices):
>     import numpy as np
>     import scipy.sparse
>     import scipy.integrate
>     from tqdm import tqdm
>     l = np.load("../liouvillian.npy")
>     pump = np.load("../pump_operator.npy")
>     state = np.load("../initial_state.npy")
>     l = scipy.sparse.csr_array(l)
>     pump = scipy.sparse.csr_array(pump)
>     def f(t, y, *args):
>          return (l + 0.5 * (5 < t < 10) * pump) @ y
>          #return l @ y # Uncomment for f(t) = 0
>     dt = 0.1
>     NUM_STEPS = 200
>     res = np.empty((NUM_STEPS, 4096), dtype=np.complex128)
>     solver =
>     scipy.integrate.ode(f).set_integrator("zvode").set_initial_value(state)
>     times = []
>     for i in tqdm(range(NUM_STEPS)):
>          res[i, :] = solver.integrate(solver.t + dt)
>          times.append(solver.t)
>     Here, A_const = l, B_const = pump and f(t) = 5 < t < 10. tqdm reports
>     about 330it/s on my machine. When converting the code to PETSc, I
>     came
>     to the following result (according to the chapter
>     https://petsc.org/main/manual/ts/#special-cases)
>     import sys
>     import petsc4py
>     petsc4py.init(args=sys.argv)
>     import numpy as np
>     import scipy.sparse
>     from petsc4py import PETSc
>     comm = PETSc.COMM_WORLD
>     def mat_to_real(arr):
>          return np.block([[arr.real, -arr.imag], [arr.imag,
>     arr.real]]).astype(np.float64)
>     def mat_to_petsc_aij(arr):
>          arr_sc_sp = scipy.sparse.csr_array(arr)
>          mat = PETSc.Mat().createAIJ(arr.shape[0], comm=comm)
>          rstart, rend = mat.getOwnershipRange()
>          print(rstart, rend)
>          print(arr.shape[0])
>          print(mat.sizes)
>          I = arr_sc_sp.indptr[rstart : rend + 1] -
>     arr_sc_sp.indptr[rstart]
>          J = arr_sc_sp.indices[arr_sc_sp.indptr[rstart] :
>     arr_sc_sp.indptr[rend]]
>          V = arr_sc_sp.data[arr_sc_sp.indptr[rstart] :
>          print(I.shape, J.shape, V.shape)
>          mat.setValuesCSR(I, J, V)
>          mat.assemble()
>          return mat
>     l = mat_to_real(l)
>     pump = mat_to_real(pump)
>     state = np.hstack([state.real, state.imag]).astype(np.float64)
>     l = mat_to_petsc_aij(l)
>     pump = mat_to_petsc_aij(pump)
>     jac = l.duplicate()
>     for i in range(8192):
>          jac.setValue(i, i, 0)
>     jac.assemble()
>     jac += l
>     vec = l.createVecRight()
>     vec.setValues(np.arange(state.shape[0], dtype=np.int32), state)
>     vec.assemble()
>     dt = 0.1
>     ts = PETSc.TS().create(comm=comm)
>     ts.setFromOptions()
>     ts.setProblemType(ts.ProblemType.LINEAR)
>     ts.setEquationType(ts.EquationType.ODE_EXPLICIT)
>     ts.setType(ts.Type.RK)
>     ts.setRKType(ts.RKType.RK3BS)
>     ts.setTime(0)
>     print("KSP:", ts.getKSP().getType())
>     print("KSP PC:",ts.getKSP().getPC().getType())
>     print("SNES :", ts.getSNES().getType())
>     def jacobian(ts, t, u, Amat, Pmat):
>          Amat.zeroEntries()
>          Amat.aypx(1, l,
>     structure=PETSc.Mat.Structure.SUBSET_NONZERO_PATTERN)
>          Amat.axpy(0.5 * (5 < t < 10), pump,
>     ts.setRHSFunction(PETSc.TS.computeRHSFunctionLinear)
>     #ts.setRHSJacobian(PETSc.TS.computeRHSJacobianConstant, l, l) #
>     ts.setRHSJacobian(jacobian, jac)
>     NUM_STEPS = 200
>     res = np.empty((NUM_STEPS, 8192), dtype=np.float64)
>     times = []
>     rstart, rend = vec.getOwnershipRange()
>          time = ts.getTime()
>          ts.setMaxTime(time + dt)
>          ts.solve(vec)
>          res[i, rstart:rend] = vec.getArray()[:]
>          times.append(time)
>     I decomposed the complex ODE into a larger real ODE, so that I can
>     easily switch maybe to GPU computation later on. Now, the
>     solutions of
>     both scripts are very much identical, but PETSc runs about 3 times
>     slower at 120it/s on my machine. I don't use MPI for PETSc yet.
>     I strongly suppose that the problem lies within the jacobian
>     definition,
>     as PETSc is about 3 times *faster* than scipy with f(t) = 0 and
>     therefore a constant jacobian.
>     Thank you in advance.
>     All the best,
>     Niclas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230810/17c79e0a/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230810/17c79e0a/attachment-0001.bin>
