[petsc-users] Python PETSc performance vs scipy ZVODE
Stefano Zampini stefano.zampini at gmail.com
Wed Aug 9 10:51:16 CDT 2023
TSRK is an explicit solver. Unless you are changing the ts type from
command line,  the explicit  jacobian should not be needed. On top of
Barry's suggestion, I would suggest you to write the explicit RHS instead
of assembly a throw away matrix every time that function needs to be
sampled.
On Wed, Aug 9, 2023, 17:09 Niclas Götting <ngoetting at itp.uni-bremen.de>
wrote:
> Hi all,
> I'm currently trying to convert a quantum simulation from scipy to
> PETSc. The problem itself is extremely simple and of the form \dot{u}(t)
> = (A_const + f(t)*B_const)*u(t), where f(t) in this simple test case is
> a square function. The matrices A_const and B_const are extremely sparse
> and therefore I thought, the problem will be well suited for PETSc.
> Currently, I solve the ODE with the following procedure in scipy (I can
> provide the necessary data files, if needed, but they are just some
> trace-preserving, very sparse matrices):
> import numpy as np
> import scipy.sparse
> import scipy.integrate
> from tqdm import tqdm
> l = np.load("../liouvillian.npy")
> pump = np.load("../pump_operator.npy")
> state = np.load("../initial_state.npy")
> l = scipy.sparse.csr_array(l)
> pump = scipy.sparse.csr_array(pump)
> def f(t, y, *args):
>      return (l + 0.5 * (5 < t < 10) * pump) @ y
>      #return l @ y # Uncomment for f(t) = 0
> dt = 0.1
> NUM_STEPS = 200
> res = np.empty((NUM_STEPS, 4096), dtype=np.complex128)
> solver =
> scipy.integrate.ode(f).set_integrator("zvode").set_initial_value(state)
> times = []
> for i in tqdm(range(NUM_STEPS)):
>      res[i, :] = solver.integrate(solver.t + dt)
>      times.append(solver.t)
> Here, A_const = l, B_const = pump and f(t) = 5 < t < 10. tqdm reports
> about 330it/s on my machine. When converting the code to PETSc, I came
> to the following result (according to the chapter
> https://petsc.org/main/manual/ts/#special-cases)
> import sys
> import petsc4py
> petsc4py.init(args=sys.argv)
> import numpy as np
> import scipy.sparse
> from petsc4py import PETSc
> comm = PETSc.COMM_WORLD
> def mat_to_real(arr):
>      return np.block([[arr.real, -arr.imag], [arr.imag,
> arr.real]]).astype(np.float64)
> def mat_to_petsc_aij(arr):
>      arr_sc_sp = scipy.sparse.csr_array(arr)
>      mat = PETSc.Mat().createAIJ(arr.shape[0], comm=comm)
>      rstart, rend = mat.getOwnershipRange()
>      print(rstart, rend)
>      print(arr.shape[0])
>      print(mat.sizes)
>      I = arr_sc_sp.indptr[rstart : rend + 1] - arr_sc_sp.indptr[rstart]
>      J = arr_sc_sp.indices[arr_sc_sp.indptr[rstart] :
> arr_sc_sp.indptr[rend]]
>      V = arr_sc_sp.data[arr_sc_sp.indptr[rstart] : arr_sc_sp.indptr[rend]]
>      print(I.shape, J.shape, V.shape)
>      mat.setValuesCSR(I, J, V)
>      mat.assemble()
>      return mat
> l = mat_to_real(l)
> pump = mat_to_real(pump)
> state = np.hstack([state.real, state.imag]).astype(np.float64)
> l = mat_to_petsc_aij(l)
> pump = mat_to_petsc_aij(pump)
> jac = l.duplicate()
> for i in range(8192):
>      jac.setValue(i, i, 0)
> jac.assemble()
> jac += l
> vec = l.createVecRight()
> vec.setValues(np.arange(state.shape[0], dtype=np.int32), state)
> vec.assemble()
> dt = 0.1
> ts = PETSc.TS().create(comm=comm)
> ts.setFromOptions()
> ts.setProblemType(ts.ProblemType.LINEAR)
> ts.setEquationType(ts.EquationType.ODE_EXPLICIT)
> ts.setType(ts.Type.RK)
> ts.setRKType(ts.RKType.RK3BS)
> ts.setTime(0)
> print("KSP:", ts.getKSP().getType())
> print("KSP PC:",ts.getKSP().getPC().getType())
> print("SNES :", ts.getSNES().getType())
> def jacobian(ts, t, u, Amat, Pmat):
>      Amat.zeroEntries()
>      Amat.aypx(1, l, structure=PETSc.Mat.Structure.SUBSET_NONZERO_PATTERN)
>      Amat.axpy(0.5 * (5 < t < 10), pump,
> ts.setRHSFunction(PETSc.TS.computeRHSFunctionLinear)
> #ts.setRHSJacobian(PETSc.TS.computeRHSJacobianConstant, l, l) #
> ts.setRHSJacobian(jacobian, jac)
> NUM_STEPS = 200
> res = np.empty((NUM_STEPS, 8192), dtype=np.float64)
> times = []
> rstart, rend = vec.getOwnershipRange()
>      time = ts.getTime()
>      ts.setMaxTime(time + dt)
>      ts.solve(vec)
>      res[i, rstart:rend] = vec.getArray()[:]
>      times.append(time)
> I decomposed the complex ODE into a larger real ODE, so that I can
> easily switch maybe to GPU computation later on. Now, the solutions of
> both scripts are very much identical, but PETSc runs about 3 times
> slower at 120it/s on my machine. I don't use MPI for PETSc yet.
> I strongly suppose that the problem lies within the jacobian definition,
> as PETSc is about 3 times *faster* than scipy with f(t) = 0 and
> therefore a constant jacobian.
> Thank you in advance.
> All the best,
> Niclas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230809/33968410/attachment-0001.html>
