[petsc-users] Advice on setting up Schur complement based field-split preconditioner
Mon Aug 7 20:17:05 CDT 2023
On Mon, Aug 7, 2023 at 7:41 PM superjimbo via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello PETSc team,
> I am trying to solve the coupled incompressible navier-stokes equations,
> discretizedby a
> finite volume method. The discretization includes a 'stabilized-pressure'
> equation. After reading through the mailing list archives (and the
> mentioned literature),  the advice
> was to use the Schur complement based block preconditioner for the saddle
> point problem.
> My setup looks like this: (lid-driven cavity at Re=3200),
> "-ksp_type fgmres -ksp_gmres -ksp_rtol 1e-04 -ksp_pc_side right"\
>                         " -pc_type fieldsplit"\
>                         " -pc_fieldsplit_0_fields 1,2,3"\
>                         " -pc_fieldsplit_1_fields 0"\
>                         " -pc_fieldsplit_type schur"\
>                         " -pc_fieldsplit_schur_fact_type diag"\
>                         " -pc_fieldsplit_schur_precondition a11"\
We need to know what equations you actually have. I don't know if A11 is a
good preconditioner
for the Schur complement in your problem. It looks like you are taking a
million iterates in the
Schur complement solve, so I am guessing that it is not.
The first step is getting a good Schur solve, no matter how expensive it
is. I would use LU
factorization on it. If it is not < 10 iterates, it is not a great
preconditioner. I do not know much
about stabilized formulations. For stable finite elements, the pressure
mass matrix is a good
preconditioner. That is what I use in SNES ex62 and ex69. I recommend
finding a good PC
from papers on your formulation and then reproducing it in PETSc (hopefully
fairly easy).
     MAtt
>                         " -fieldsplit_0_ksp_type gmres
> -fieldsplit_0_ksp_pc_side right"\
>                         " -fieldsplit_0_ksp_rtol 1e-02"\
>                         " -fieldsplit_0_pc_type hypre"\
>                         " -fieldsplit_0_pc_hypre_type boomeramg"\
> -fieldsplit_0_pc_hypre_boomeramg_strong_threshold 0.50"\
>                         " -fiedlsplit_0_pc_hypre_boomeramg_agg_nl 4"\
>                         " -fieldsplit_0_pc_hypre_boomeramg_max_levels 6"\
> -fieldsplit_0_pc_hypre_boomeramg_relax_weight_all 0.8"\
>                         " -fieldsplit_0_pc_hypre_boomeramg_max_iter 1"\
>                         " -fieldsplit_1_ksp_type gmres
> -fieldsplit_1_ksp_pc_side right"\
>                         " -fieldsplit_1_ksp_rtol 1e-02"\
>                         " -fieldsplit_1_pc_type hypre"\
>                         " -fieldsplit_1_pc_hypre_type boomeramg"\
> -fieldsplit_1_pc_hypre_boomeramg_strong_threshold 0.5"\
>                         " -fieldsplit_1_pc_hypre_boomeramg_smooth_type
> euclid"\
>                         " -fiedlsplit_1_pc_hypre_boomeramg_agg_nl 4"\
>                         " -fieldsplit_1_pc_hypre_boomeramg_max_levels 6"\
> -fieldsplit_1_pc_hypre_boomeramg_relax_weight_all 0.7"\
>                         " -fieldsplit_1_pc_hypre_boomeramg_max_iter 4"\
>                         " -fieldsplit_ksp_converged_reason"\
>                         " -ksp_converged_reason"
> Here, the pressure variable index is 0, and the velocity components are
> 1,2 and 3. This setup technically runs.
> However, as the simulation progresses, the number of linear iterations
> for  pc_fieldsplit_1 (pressure variable)
> increases. Am I setting the preconditioner correctly, Could you please
> advise?
> Thanks and best regards,
> Jim.
> KSP Object: 1 MPI process
>   type: fgmres
>     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=0.0001, absolute=1e-50, divergence=10000.
>   right preconditioning
>   using DEFAULT norm type for convergence test
> PC Object: 1 MPI process
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, blocksize = 4, factorization DIAG
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>     Split number 0 Fields  1, 2, 3
>     Split number 1 Fields  0
>     KSP solver for A00 block
>       KSP Object: (fieldsplit_0_) 1 MPI process
>         type: gmres
>         tolerances:  relative=0.01, absolute=1e-50, divergence=10000.
>       PC Object: (fieldsplit_0_) 1 MPI process
>         type: hypre
>         PC has not been set up so information may be incomplete
>           HYPRE BoomerAMG preconditioning
>             Cycle type V
>             Maximum number of levels 6
>             Maximum number of iterations PER hypre call 1
>             Convergence tolerance PER hypre call 0.
>             Threshold for strong coupling 0.5
>             Interpolation truncation factor 0.
>             Interpolation: max elements per row 0
>             Number of levels of aggressive coarsening 0
>             Number of paths for aggressive coarsening 1
>             Maximum row sums 0.9
>             Sweeps down         1
>             Sweeps up           1
>             Sweeps on coarse    1
>             Relax down          symmetric-SOR/Jacobi
>             Relax up            symmetric-SOR/Jacobi
>             Relax on coarse     Gaussian-elimination
>             Relax weight  (all)      0.8
>             Outer relax weight (all) 1.
>             Using CF-relaxation
>             Not using more complex smoothers.
>             Measure type        local
>             Coarsen type        Falgout
>             Interpolation type  classical
>             SpGEMM type         cusparse
>         linear system matrix = precond matrix:
>         Mat Object: (fieldsplit_0_) 1 MPI process
>           type: seqaij
>           rows=196608, cols=196608, bs=3
>           total: nonzeros=2939904, allocated nonzeros=2939904
>           total number of mallocs used during MatSetValues calls=0
>             using I-node routines: found 65536 nodes, limit used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object: (fieldsplit_1_) 1 MPI process
>         type: gmres
>       PC Object: (fieldsplit_1_) 1 MPI process
>         type: hypre
>             Cycle type V
>             Sweeps down         1
>             Sweeps up           1
>             Sweeps on coarse    1
>             Relax weight  (all)      0.3
>             Using CF-relaxation
>             Smooth type          Euclid
>             Smooth num levels    25
>             Euclid ILU(k) levels 0
>             Euclid ILU(k) drop tolerance 0.
>             Euclid ILU use Block-Jacobi? 0
>             Measure type        local
>         linear system matrix followed by preconditioner matrix:
>         Mat Object: (fieldsplit_1_) 1 MPI process
>           type: schurcomplement
>           rows=65536, cols=65536
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>                 total: nonzeros=326656, allocated nonzeros=326656
>                   not using I-node routines
>             A10
>               Mat Object: 1 MPI process
>                 type: seqaij
>                 rows=65536, cols=196608
>                 total: nonzeros=979968, allocated nonzeros=979968
>             KSP of A00
>                 type: gmres
> divergence=10000.
>                 type: hypre
>                     Cycle type V
>                     Sweeps down         1
>                     Sweeps up           1
>                     Sweeps on coarse    1
>                     Using CF-relaxation
>                     Measure type        local
>                   type: seqaij
> is 5
>             A01
>                 type: seqaij
>                 rows=196608, cols=65536, rbs=3, cbs=1
>           type: seqaij
>     type: seqaij
>     rows=262144, cols=262144, bs=4
>     total: nonzeros=5226496, allocated nonzeros=5226496
> [0] Iteration 0: 1 1 1 1
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 2
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 16
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 13
> Linear solve converged due to CONVERGED_RTOL iterations 10
> [0] Iteration 1: 0.260452 1.79947 1.97071 0.338806
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 21
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
> [0] Iteration 2: 0.0623281 0.221591 0.233678 0.0802229
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 24
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 25
> [0] Iteration 3: 0.0435829 0.0267908 0.0120759 0.017118
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 3
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 39
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 44
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 36
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 46
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 47
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 45
> [0] Iteration 4: 0.0134479 0.0127978 0.00651386 0.0035045
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 4
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 5
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 57
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 54
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 59
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 62
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 56
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 74
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 63
> [0] Iteration 5: 0.00385315 0.00686313 0.00592293 0.000710284
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 6
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 91
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 93
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 79
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 86
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 72
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 102
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 70
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 71
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 88
> Linear solve converged due to CONVERGED_RTOL iterations 12
> [0] Iteration 6: 0.00131378 0.00417556 0.00563892 0.000143316
> Best,
> Jim
> Sent with Proton Mail <https://proton.me/> secure email.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230807/d1f0ae60/attachment-0001.html>
