[petsc-users] Advice on setting up Schur complement based field-split preconditioner
superjimbo superjimbo at proton.me
Mon Aug 7 18:37:15 CDT 2023
Hello PETSc team,
I am trying to solve the coupled incompressible navier-stokes equations, discretizedby a
finite volume method. The discretization includes a 'stabilized-pressure' equation. After reading through the mailing list archives (and the mentioned literature), the advice
was to use the Schur complement based block preconditioner for the saddle point problem.
My setup looks like this: (lid-driven cavity at Re=3200),
"-ksp_type fgmres -ksp_gmres -ksp_rtol 1e-04 -ksp_pc_side right"\
" -pc_type fieldsplit"\
" -pc_fieldsplit_0_fields 1,2,3"\
" -pc_fieldsplit_1_fields 0"\
" -pc_fieldsplit_type schur"\
" -pc_fieldsplit_schur_fact_type diag"\
" -pc_fieldsplit_schur_precondition a11"\
" -fieldsplit_0_ksp_type gmres -fieldsplit_0_ksp_pc_side right"\
" -fieldsplit_0_ksp_rtol 1e-02"\
" -fieldsplit_0_pc_type hypre"\
" -fieldsplit_0_pc_hypre_type boomeramg"\
" -fieldsplit_0_pc_hypre_boomeramg_strong_threshold 0.50"\
" -fiedlsplit_0_pc_hypre_boomeramg_agg_nl 4"\
" -fieldsplit_0_pc_hypre_boomeramg_max_levels 6"\
" -fieldsplit_0_pc_hypre_boomeramg_relax_weight_all 0.8"\
" -fieldsplit_0_pc_hypre_boomeramg_max_iter 1"\
" -fieldsplit_1_ksp_type gmres -fieldsplit_1_ksp_pc_side right"\
" -fieldsplit_1_ksp_rtol 1e-02"\
" -fieldsplit_1_pc_type hypre"\
" -fieldsplit_1_pc_hypre_type boomeramg"\
" -fieldsplit_1_pc_hypre_boomeramg_strong_threshold 0.5"\
" -fieldsplit_1_pc_hypre_boomeramg_smooth_type euclid"\
" -fiedlsplit_1_pc_hypre_boomeramg_agg_nl 4"\
" -fieldsplit_1_pc_hypre_boomeramg_max_levels 6"\
" -fieldsplit_1_pc_hypre_boomeramg_relax_weight_all 0.7"\
" -fieldsplit_1_pc_hypre_boomeramg_max_iter 4"\
" -fieldsplit_ksp_converged_reason"\
" -ksp_converged_reason"
Here, the pressure variable index is 0, and the velocity components are 1,2 and 3. This setup technically runs.
However, as the simulation progresses, the number of linear iterations for pc_fieldsplit_1 (pressure variable)
increases. Am I setting the preconditioner correctly, Could you please advise?
Thanks and best regards,
Jim.
KSP Object: 1 MPI process
type: fgmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=0.0001, absolute=1e-50, divergence=10000.
right preconditioning
using DEFAULT norm type for convergence test
PC Object: 1 MPI process
type: fieldsplit
FieldSplit with Schur preconditioner, blocksize = 4, factorization DIAG
Preconditioner for the Schur complement formed from A11
Split info:
Split number 0 Fields 1, 2, 3
Split number 1 Fields 0
KSP solver for A00 block
KSP Object: (fieldsplit_0_) 1 MPI process
type: gmres
tolerances: relative=0.01, absolute=1e-50, divergence=10000.
PC Object: (fieldsplit_0_) 1 MPI process
type: hypre
PC has not been set up so information may be incomplete
HYPRE BoomerAMG preconditioning
Cycle type V
Maximum number of levels 6
Maximum number of iterations PER hypre call 1
Convergence tolerance PER hypre call 0.
Threshold for strong coupling 0.5
Interpolation truncation factor 0.
Interpolation: max elements per row 0
Number of levels of aggressive coarsening 0
Number of paths for aggressive coarsening 1
Maximum row sums 0.9
Sweeps down 1
Sweeps up 1
Sweeps on coarse 1
Relax down symmetric-SOR/Jacobi
Relax up symmetric-SOR/Jacobi
Relax on coarse Gaussian-elimination
Relax weight (all) 0.8
Outer relax weight (all) 1.
Using CF-relaxation
Not using more complex smoothers.
Measure type local
Coarsen type Falgout
Interpolation type classical
SpGEMM type cusparse
linear system matrix = precond matrix:
Mat Object: (fieldsplit_0_) 1 MPI process
type: seqaij
rows=196608, cols=196608, bs=3
total: nonzeros=2939904, allocated nonzeros=2939904
total number of mallocs used during MatSetValues calls=0
using I-node routines: found 65536 nodes, limit used is 5
KSP solver for S = A11 - A10 inv(A00) A01
KSP Object: (fieldsplit_1_) 1 MPI process
type: gmres
PC Object: (fieldsplit_1_) 1 MPI process
type: hypre
Cycle type V
Sweeps down 1
Sweeps up 1
Sweeps on coarse 1
Relax weight (all) 0.3
Using CF-relaxation
Smooth type Euclid
Smooth num levels 25
Euclid ILU(k) levels 0
Euclid ILU(k) drop tolerance 0.
Euclid ILU use Block-Jacobi? 0
Measure type local
linear system matrix followed by preconditioner matrix:
Mat Object: (fieldsplit_1_) 1 MPI process
type: schurcomplement
rows=65536, cols=65536
Schur complement A11 - A10 inv(A00) A01
A11
type: seqaij
total: nonzeros=326656, allocated nonzeros=326656
not using I-node routines
A10
Mat Object: 1 MPI process
type: seqaij
rows=65536, cols=196608
total: nonzeros=979968, allocated nonzeros=979968
KSP of A00
type: gmres
type: hypre
Cycle type V
Sweeps down 1
Sweeps up 1
Sweeps on coarse 1
Using CF-relaxation
Measure type local
type: seqaij
A01
type: seqaij
rows=196608, cols=65536, rbs=3, cbs=1
type: seqaij
type: seqaij
rows=262144, cols=262144, bs=4
total: nonzeros=5226496, allocated nonzeros=5226496
total number of mallocs used during MatSetValues calls=0 using I-node routines: found 65536 nodes, limit used is 5
[0] Iteration 0: 1 1 1 1
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 2
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 16
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 13
Linear solve converged due to CONVERGED_RTOL iterations 10
[0] Iteration 1: 0.260452 1.79947 1.97071 0.338806
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 21
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
[0] Iteration 2: 0.0623281 0.221591 0.233678 0.0802229
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 24
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 25
[0] Iteration 3: 0.0435829 0.0267908 0.0120759 0.017118
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 3
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 39
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 44
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 36
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 46
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 47
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 45
[0] Iteration 4: 0.0134479 0.0127978 0.00651386 0.0035045
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 4
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 5
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 57
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 54
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 59
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 62
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 56
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 74
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 63
[0] Iteration 5: 0.00385315 0.00686313 0.00592293 0.000710284
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 6
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 91
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 93
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 79
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 86
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 72
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 102
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 70
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 71
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 88
Linear solve converged due to CONVERGED_RTOL iterations 12[0] Iteration 6: 0.00131378 0.00417556 0.00563892 0.000143316
Best,
Jim
Sent with [Proton Mail](https://proton.me/) secure email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230807/ba65c6cf/attachment-0001.html>
