[petsc-users] compiler related error (configuring Petsc)
maitri ksh maitri.ksh at gmail.com
Wed Aug 2 08:22:44 CDT 2023
I could compile petsc using the newer version of gnu compiler.
However, there is some unusual error when I tried to test petsc using a
print 'hello' file. I could not interpret what the error ('*error.txt*')
is, but it says something related to MATLAB (which is not used in the '
*hello.c*' script). Any comments/suggestions?
On Wed, Aug 2, 2023 at 11:07 AM maitri ksh <maitri.ksh at gmail.com> wrote:
> Okay, thank you.
> On Tue, Aug 1, 2023 at 9:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> > gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44)
>> Is it possible for you to use a newer version GNU compilers?
>> If not - your alternative is to build PETSc with --with-cxx=0 option
>> But then - you can't use --download-superlu_dist or any pkgs that need
>> c++ [you could try building them separately though]
>> Satish
>> On Tue, 1 Aug 2023, maitri ksh wrote:
>> > I am trying to compile petsc on a cluster ( x86_64-redhat-linux, '
>> > *configure.log'*  is attached herewith) . Initially I got an error
>> related
>> > to 'C++11' flag, to troubleshoot this issue, I used 'CPPFLAGS' and
>> > 'CXXFLAGS' and could surpass the non-compliant error related to c++
>> compiler
>> >  but now it gives me another error 'cannot find a C preprocessor'. How
>> to
>> > fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230802/5f8bbe4d/attachment-0001.html>
/usr/bin/ld: warning: libut.so, needed by //usr/local/matlab/bin/glnxa64/libeng.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwengine_api.so, needed by //usr/local/matlab/bin/glnxa64/libeng.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfl.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwservices.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfoundation_matlabdata_matlab.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfoundation_matlabdata.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwmvm.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwm_dispatcher_interfaces.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwm_dispatcher.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwi18n.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfoundation_filesystem.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwmlutil.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfoundation_usm.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwgenerate_diag_message.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwmcos.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwfoundation_log.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwcpp11compat.so, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwboost_chrono.so.1.75.0, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwboost_filesystem.so.1.75.0, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwboost_log.so.1.75.0, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwboost_thread.so.1.75.0, needed by //usr/local/matlab/bin/glnxa64/libmex.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwmfl_permute.so, needed by //usr/local/matlab/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwindexingapimethods.so, needed by //usr/local/matlab/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libicuuc.so.69, needed by //usr/local/matlab/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwflstorageutility.so, needed by //usr/local/matlab/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwflstoragevfs.so, needed by //usr/local/matlab/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmwcppmicroservices.so, needed by //usr/local/matlab/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libCppMicroServices.so.3.7.0, needed by //usr/local/matlab/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libhdf5-1.8.so.8, needed by //usr/local/matlab/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::Dispatcher::HasBuiltinName(foundation::core::except::IUserException const&)'
//usr/local/matlab/bin/glnxa64/libeng.so: undefined reference to `utFree'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_ustring_to_wstring::do_get_destination_size(char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::isPackageFunction() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::Level::~Level()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::getClaimingComponent() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::MwLocale::global()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utTwoByteUIntConvert'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::SetInterfaceId(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::diag::terminate(char const*, char const*, int, char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::Array(foundation::matlabdata::Array&&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mlutil::cmddistributor::EDIDataWrapper::EDIDataWrapper(mlutil::cmddistributor::EDIDataWrapper const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_DOUBLE_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::diag::terminate(std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int, char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::findWithinFileFunction(char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::status(fl::filesystem::basic_path<char, char16_t, fl::filesystem::detail::path_traits<char, char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Fflush at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `enc_to_utf16_n'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::~Mlm_file()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_USHORT_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `omDoesClassImplementSubsref(mxArray_tag*, bool&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aget_space at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<matlab::data::GetReturnType<std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > >::type> foundation::matlabdata::ArrayFactory::createScalar<std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > >(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch_mf(int, mxArray_tag**, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pset_deflate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::get_aspects(int&, int&, bool&, bool&, bool&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::aux::stream_provider<char>::allocate_compound(mwboost::log::v2_mt_posix::record&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sget_simple_extent_dims at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::getExecutionStatus() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::add_rebind_event_subscriber(mwboost::signals2::slot<void (), mwboost::function<void ()> > const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::IsConvertibleTo(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utInterruptMode::utInterruptMode(InterruptMode)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::MessageCatalog::GetFormattedMessage(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::vector<std::variant<long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > >, std::allocator<std::variant<long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > > > > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::log::basic_diagnostic_logger<char>::~basic_diagnostic_logger()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utMalloc'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceObjectsBase::~ServiceObjectsBase()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<foundation::matlabdata::Array> foundation::matlabdata::ArrayFactory::createArray<foundation::matlabdata::Array>(std::vector<unsigned long, std::allocator<unsigned long> >)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::PromiseDelegate'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utInterruptMode::~utInterruptMode()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::isBreakPointFreezed() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utDoubleConvert'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::AlreadyCancelledException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::matlab::ServerArrayFactory::createMxArray(foundation::matlabdata::Array const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::log::basic_diagnostic_logger<char>::basic_diagnostic_logger(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::to_string(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_string_to_ustring::do_convert[abi:cxx11](char const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_construct(unsigned long, char16_t)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceObjectsBase::ServiceObjectsBase(std::shared_ptr<cppmicroservices::BundleContextPrivate> const&, cppmicroservices::ServiceReferenceBase const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_narrow_string::codecvt_ustring_to_narrow_string(bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for LoadLibraryExceptionBase'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::TransposeInPlace(void*, unsigned long, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::log::detail::terminate(std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int, char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::MessageCatalog::get_message[abi:cxx11](resource_core::BaseMsgID const&, fl::i18n::MwLocale const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_narrow_string::~codecvt_ustring_to_narrow_string()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IMsgIDException::get_error_id(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::operator[](unsigned long)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::TransposeSparse(unsigned long, unsigned long, unsigned long const*, unsigned long const*, std::complex<double> const*, unsigned long*, unsigned long*, std::complex<double>*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::to_ustring[abi:cxx11](char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::detail::get_current_thread_data()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dread at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::copy(char16_t*, unsigned long, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::~RuntimeException()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::Mlm_file(Mdispatcher*, char16_t const*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_member_type at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::is_open() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gcreate2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::mem::aligned_heap::instance'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_UCHAR_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utInterruptMode::on'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for MathWorks::System::Throwable_DEPRECATED'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::detail::get_tss_data(void const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::compute_license_restriction() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::ThrowInvalidIndexError() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Eget_auto2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tset_size at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::close()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::BundleContext::GetServiceReferences(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::diag::detail::demangle_typeid_name[abi:cxx11](char const*, bool)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::filesystem::codecvt_narrow_string_to_ustring::codecvt_narrow_string_to_ustring(bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::MwLocale::system()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utIsMultiByteLead'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::PromiseDelegate::isPromiseDone() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::ustring_to_utf8(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mvm::MVM::createRequestID()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_filesystem::codecvt_ustring_to_filesystem(bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::diag::symbolic(std::ostream&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::IODevice(foundation::storage::vfs::File, foundation::storage::provider::ByteStreamOpenOptions)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::Array()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ucnv_getNextUChar_69'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::find_last_not_of(char16_t const*, unsigned long, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::utf8_to_ustring[abi:cxx11](char const*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_nmembers at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for foundation::core::except::IException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_partial_name() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::thread_detail::commit_once_region(mwboost::once_flag&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::dispatch_mf_with_reuse(int, mxArray_tag**, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::operator=(foundation::matlabdata::Array const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dget_space at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::AbsoluteIRI::toString[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::GetMatlabIrAccessor(Mfh_MATLAB_fn const*) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::Level::Level(MathWorks::System::Level::Enum)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IUserException::ToUstringImpl[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::diag::stacktrace_base::format(std::ostream&, void const*) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IException::convert_str(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::operator=(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >&&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::setBreakPoint(int, int, char const*, bool)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_UINT_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::swap(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::matlab::ServerArrayFactory::ServerArrayFactory(foundation::matlabdata::matlab::SerializeHandles, foundation::matlabdata::ObjectFilter, foundation::matlabdata::matlab::PreferStringArray, foundation::matlabdata::matlab::OldCustomizationContext)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::add_star_based_import(char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::FEvalOutputAdapter<std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> > >::operator()(std::unique_ptr<std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> >, mlutil::cmddistributor::DataArraysDeleter>&&) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gget_info at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::set_lookup_scope(bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::hasBreakPoint() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::this_thread::interruption_point()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_ustring_to_wstring::do_convert(wchar_t*, unsigned long, char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::Array(matlab::data::impl::ArrayImpl*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch_with_reuse(int, std::unique_ptr<mxArray_tag, matrix::detail::mxDestroy_deleter>*, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::RuntimeException(mlutil::cmddistributor::inExecutionStatus, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<cmddistributor::StackFrame, std::allocator<cmddistributor::StackFrame> >, std::vector<cmddistributor::RuntimeException, std::allocator<cmddistributor::RuntimeException> >, bool, std::vector<mwboost::variant<signed char, unsigned char, short, unsigned short, int, unsigned int, long, unsigned long, float, double, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > >, std::allocator<mwboost::variant<signed char, unsigned char, short, unsigned short, int, unsigned int, long, unsigned long, float, double, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > > > >)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::thread_detail::enter_once_region(mwboost::once_flag&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5open at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IException::convert_str(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_dispose()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utFindSymbolInLibrary'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_new_ghash_table'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for Mlm_file'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_unicodefuncname[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Eset_auto2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dget_type at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::setErrSink(mwboost::shared_ptr<mlutil::io::MLSink>)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `svIsTasksMode'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utInstallHandler'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::set_public(bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::CanBeCalledBy(Mfh_MATLAB_fn const*) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::FEvalResult'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_narrow_string::do_convert[abi:cxx11](char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::getNextID(std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::lxe::IndexInfo::MatchAndResizeIndicesToRHSDimensions()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequestTraits<cmddistributor::CmdRequest>::extractResult(cmddistributor::IIPResult&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::Unix::SegvCleanup::~SegvCleanup()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for cmddistributor::RuntimeException'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::write(char const*, long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::operator=(foundation::matlabdata::Array&&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utGetWarningStatus'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<foundation::matlabdata::Array>::operator[](unsigned long)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::unload()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sset_extent_simple at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utSingleConvert'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::ensure_loading_of_load_module() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::setDequeueMode(mlutil::cmddistributor::WhenToDequeue::WhenToDequeue)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IUserException::GetMessageTxt[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::UnicodeConverterX::getThreadSpecific(char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch_file_with_reuse(int, mxArray_tag**, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::ForEachImport(std::function<void (char const*)> const&) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tequal at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::Resource::~Resource()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::TransposeSparse(unsigned long, unsigned long, unsigned long const*, unsigned long const*, double const*, unsigned long*, unsigned long*, double*)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::filesystem::get_install_path[abi:cxx11]()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mlutil::except::IMExceptionEnvelope::~IMExceptionEnvelope()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tvlen_create at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mlutil::io::SinkTraits::~SinkTraits()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `void foundation::matlabdata::detail::setElement<foundation::matlabdata::TypedArray<int> >(std::shared_ptr<matlab::data::detail::ReferenceImpl>, foundation::matlabdata::TypedArray<int>)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gunlink at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tinsert at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `svRegisterFeature(char const*, int, void (*)(int), void (*)(int, mxArray_tag**, int, mxArray_tag**))'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utf16_strlen_lim'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::aux::stream_provider<char>::release_compound(mwboost::log::v2_mt_posix::aux::stream_provider<char>::stream_compound*)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_wstring_to_ustring::~codecvt_wstring_to_ustring()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::findOrFail(unsigned long, std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::Array(foundation::matlabdata::Array const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utLastLibraryError_u()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_STD_REF_OBJ_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Fopen at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::FEvalInputAdapter<std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> > >::operator()(std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::must_retry_license() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::FromUTF16Converter::_do_conversion(char*, int) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utC2fstr'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceException::~ServiceException()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::cppmicroservices::getFramework()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for mlutil::except::INamedFuncException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::clear_breakpoint(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::is_lookup_scope() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `typeinfo for foundation::usm::DoesNotExistTypeError'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::~ServiceReferenceBase()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl_diag_terminate'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pset_chunk at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::getDDUXFullName[abi:cxx11](Mfh_MATLAB_fn const*) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utLoadLibrary(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, int*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_ustring_to_string::~codecvt_ustring_to_string()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_ascii_to_ustring::~codecvt_ascii_to_ustring()'
//usr/local/matlab/bin/glnxa64/libeng.so: undefined reference to `utCalloc'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utLoadLibraryWithLocalSymbolVisibilityAndDiagnosticMsg(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utf16_strncpy'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::GetInterfaceId[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_complete_unicode_name[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::AbsoluteIRI::AbsoluteIRI(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_wstring_to_ustring::do_convert[abi:cxx11](wchar_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utFlipEightBytes'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_string_to_ustring::do_convert(char16_t*, unsigned long, char const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_ascii_to_ustring::do_convert[abi:cxx11](char const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::StorageSystem::~StorageSystem()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ucnv_reset_69'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::except::bad_alloc()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::detail::extract_extension(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::Dispatcher::AnnotateWithBuiltinName(foundation::core::except::IUserException&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utUnloadLibrary'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::Mfh_file(Mdispatcher*, Mlm_file*, Mfh_file*, int, int, bool, bool, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mvm::MVM::feval(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> > const&, unsigned long, cmddistributor::RunOptions, bool, foundation::msg_svc::exchange::IDType)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch(int, mxArray_tag**, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::MessageID::MessageID(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::getOwningClassName[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Acreate2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch_with_reuse(int, mxArray_tag**, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sget_simple_extent_npoints at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for foundation::matlabdata::Array'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for MathWorks::System::SimpleException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::diag::terminate(mwboost::basic_format<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int, char const*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dset_extent at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::get_dirIRI() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_wstring_to_ustring::do_convert(char16_t*, unsigned long, wchar_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::filesystem::codecvt_narrow_string_to_ustring::do_convert[abi:cxx11](char const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tcopy at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::add_import(char const*)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::TransposeSparse(unsigned long, unsigned long, unsigned long const*, unsigned long const*, bool const*, unsigned long*, unsigned long*, bool*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utFourByteIntConvert'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::i18n::detail::get_module_path_from_address[abi:cxx11](void*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::~Array()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::operator==(cmddistributor::RuntimeException const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::isEmpty() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_C_S1_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dopen2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_ULONG_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sget_simple_extent_ndims at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aget_name at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_ghash_remove_element'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::erase(unsigned long, std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::getBuiltinFcn() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::diag::stacktrace_base::capture(unsigned long)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ucnv_fromUnicode_69'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::detail::make_native_form(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, bool)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aopen at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Awrite at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::MessageCatalog::get_message[abi:cxx11](fl::i18n::MessageID const&, fl::i18n::MwLocale const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mvm::detail::CmdDistributorTaskReference::CmdDistributorTaskReference(mwboost::shared_ptr<cmddistributor::CmdDistributor>, foundation::msg_svc::exchange::IDType)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::CmdRequest'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::get_fullPathIRI() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::unload_mf()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Screate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5check_version at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::IncrementSubscript()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sget_simple_extent_type at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_sign at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::getStackFrames() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::ArrayFactory::createCharArray(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_symtab_add'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `vtable for fl::i18n::codecvt_ustring_to_wstring'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::core::open_record(mwboost::log::v2_mt_posix::attribute_set const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::ThrowIndexTooLargeError() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::findOrInsert(unsigned long, std::type_info const&, std::unique_ptr<void, void (*)(void*)>&&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_complete_name() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utf16_strlen'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utPrintf'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::find(unsigned long, std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::matlab::ServerArrayFactory::createArrayFromMxArray(std::unique_ptr<mxArray_tag, matrix::detail::mxDestroy_deleter>&&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_star_based_imports() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::detail::GetDemangledName[abi:cxx11](std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::removeListener(IMlmUnloadEventListener*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::filesystem::fopen(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::lxe::CreateDimensionString[abi:cxx11](unsigned long, unsigned long const*)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_member_offset at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `vtable for fl::i18n::codecvt_wstring_to_ustring'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::clearBreakPoint(int, int, char const*, bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::except::detail::bad_alloc_impl::internal::what() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utTwoByteIntConvert'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utGetMemoryContext'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::isMathWorksCode() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `typeinfo for cppmicroservices::ServiceException'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::AbsoluteIRI::~AbsoluteIRI()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::CmdRequest(cmddistributor::IqmStreamID, mwboost::shared_ptr<mlutil::io::MLSink> const&, mwboost::shared_ptr<mlutil::io::MLSink> const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::lcctype::isalpha_ascii(char32_t)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::mem::manager::instance()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::access(fl::filesystem::basic_path<char, char16_t, fl::filesystem::detail::path_traits<char, char16_t> > const&, unsigned int)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_replace(unsigned long, unsigned long, char16_t const*, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_class at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::Bundle::GetBundleContext() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::insert(unsigned long, std::type_info const&, std::unique_ptr<void, void (*)(void*)>&&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::getOutSink() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::MessageCatalog::MessageCatalogInit(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::get_which(char16_t const*&, char16_t const*&, char16_t const*&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for mlutil::except::IMExceptionEnvelope'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::set_breakpoint(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_imports(bool) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for foundation::core::except::IMsgIDException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utVSNprintf'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::core::get_logging_enabled() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Rcreate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pcreate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::setQueueName(mwboost::optional<std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > >)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::load_mf()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::clearAllBreakPoints()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::PromiseDelegate::waitTillReady() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mvm::Factory::getCurrentLocalMVM()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::detail::addIndex(std::shared_ptr<matlab::data::detail::ReferenceImpl>&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tlock at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<matlab::data::GetReturnType<double>::type> foundation::matlabdata::ArrayFactory::createScalar<double>(double)'
//usr/local/matlab/bin/glnxa64/libeng.so: undefined reference to `sendEngineDduxInfo'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_SCHAR_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_ghash_insert'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dwrite at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::findOrThrow(unsigned long, std::type_info const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aget_num_attrs at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::notify_rebind_event_subscribers()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for foundation::core::except::IUserException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::PromiseDelegate::PromiseDelegate()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::GetID[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::detail::validateInput(std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> > const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Lexists at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::lxe::IndexInfo::IndexInfo(unsigned long, bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_delete_ghash_table'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_wstring_to_ustring::do_get_destination_size(wchar_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aget_type at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::FromUTF16Converter::FromUTF16Converter(char16_t const*, int, char const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::narginout(int*, int*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `services::state::RevertImpersonationGuard::~RevertImpersonationGuard()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::getOutputSink() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<matlab::data::GetReturnType<unsigned long>::type> foundation::matlabdata::ArrayFactory::createScalar<unsigned long>(unsigned long)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_filesystem::do_convert[abi:cxx11](char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::Unix::SegvCleanup::continuable()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for MathWorks::System::SimpleException'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::erase_imports()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::future_category()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::set_typeidx(int)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::thread_detail::rollback_once_region(mwboost::once_flag&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dvlen_reclaim at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_ustring_to_string::do_convert[abi:cxx11](char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sselect_hyperslab at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_LONG_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gget_objname_by_idx at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::getCauses() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utSetLastPrintedWarningId'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gget_objinfo at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::setOutSink(mwboost::shared_ptr<mlutil::io::MLSink>)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::get_hidden(int) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::utility::normalizeURL(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::detail::set_tss_data(void const*, void (*)(void (*)(void*), void*), void (*)(void*), void*, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::FEvalIIP::FEvalIIP(mwboost::variant<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::shared_ptr<foundation::matlabdata::Array> >, unsigned long, mwboost::shared_ptr<cmddistributor::FEvalIIP::Data>, cmddistributor::IqmStreamID, mwboost::shared_ptr<mlutil::io::MLSink> const&, mwboost::shared_ptr<mlutil::io::MLSink> const&, mlutil::contextmgr::MvmID const&, mlutil::contextmgr::MvmID const&, bool, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::cast(MathWorks::I18N::UnicodeConverterX*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IException::what() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::get_private(int)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `u_strFromUTF8_69'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::File::fileExists() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_ustring_to_wstring::do_convert[abi:cxx11](char16_t const*, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::file_status::file_not_found'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IUserException::convert_str(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::FEvalResult::FEvalResult(foundation::msg_svc::exchange::IDType const&, std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> >&&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::FromUTF16Converter::copy_to(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utIsValidMessageIdentifier'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utFlipFourBytes'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::except::IException::ToUstringImpl[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for Mfh_file'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `util::LibSyms::LibSyms(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_member_name at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_INT_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_create(unsigned long&, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::isMathWorksCode() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `void foundation::matlabdata::detail::setElement<foundation::matlabdata::Array>(std::shared_ptr<matlab::data::detail::ReferenceImpl>, foundation::matlabdata::Array)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::filesystem::codecvt_narrow_string_to_ustring::~codecvt_narrow_string_to_ustring()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::~CmdRequest()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::dispatch(int, std::unique_ptr<mxArray_tag, matrix::detail::mxDestroy_deleter>*, int, mxArray_tag**)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::lcctype::isalnum_ascii(char32_t)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::Unix::SegvCleanup::SegvCleanup()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_string_to_ustring::~codecvt_string_to_ustring()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::filesystem::freopen(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, _IO_FILE*)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::I18N::FromUTF16Converter::~FromUTF16Converter()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utTmpnam'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::lxe::IndexInfo::MatchIndicesToRHSDimensions() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceObjectsBase::GetService() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utPrintfIsHot()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ucnv_toUChars_69'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `vtable for foundation::storage::vfs::File'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::LDAPFilter::~LDAPFilter()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::filesystem::codecvt_ustring_to_filesystem::~codecvt_ustring_to_filesystem()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `omDoesClassImplementSubsasgn(mxArray_tag*, bool&, bool&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::EvalCmdRequest::EvalCmdRequest(bool, cmddistributor::IqmStreamID, mwboost::shared_ptr<mlutil::io::MLSink> const&, mwboost::shared_ptr<mlutil::io::MLSink> const&, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::mem::get_total_random_access_memory()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ucnv_fromUChars_69'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::createSink(mwboost::shared_ptr<std::basic_streambuf<char16_t, std::char_traits<char16_t> > >, mlutil::io::SinkTraits)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::AbsoluteIRI::getScheme[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sselect_elements at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `vtable for foundation::storage::vfs::StorageSystemReference'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utIsWarningModeOn'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::File::createFile() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::try_load()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::getErrSink() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IMsgIDException::GetUnicodeMessageTxt[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mdFunctionCallProtectedDispatcher::~mdFunctionCallProtectedDispatcher()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `foundation::core::except::detail::legacy(foundation::core::except::detail::bad_alloc_impl const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `services::state::RevertImpersonationGuard::RevertImpersonationGuard()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `void foundation::matlabdata::detail::setElement<foundation::matlabdata::TypedArray<foundation::matlabdata::Array> >(std::shared_ptr<matlab::data::detail::ReferenceImpl>, foundation::matlabdata::TypedArray<foundation::matlabdata::Array>)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for fl::i18n::codecvt_ascii_to_ustring'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_ghash_replace'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RunOptions::RunOptions(mwboost::shared_ptr<std::basic_streambuf<char16_t, std::char_traits<char16_t> > >, mwboost::shared_ptr<std::basic_streambuf<char16_t, std::char_traits<char16_t> > >, mlutil::io::SinkTraits, mlutil::io::SinkTraits)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_ustring_to_string::codecvt_ustring_to_string(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utLogWarning(utWarningManagerContext*, mwboost::optional<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&, resource_core::BaseMsgID const&, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::IIPResult::getExecutionStatus() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::addListener(IMlmUnloadEventListener*)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::~BadSubscriptHandler()'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utGetWarningManagerContextSafe'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::core::push_record_move(mwboost::log::v2_mt_posix::record&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::getFunctionName[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Rdereference at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::getErrorSink() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_partial_unicode_name[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `fl::i18n::detail::compare(char16_t const*, unsigned long, char16_t const*, unsigned long, fl::i18n::case_sensitive const&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_SHORT_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::InitializeIndexExceedsBoundsHandler(unsigned long, unsigned long, unsigned long const*, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::getIIP() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::usm::Detail<foundation::usm::scope::Mvm>::isRequiredContextActive()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::hasIRIPrefix(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `generateDiagnosticMsg[abi:cxx11](LoadLibraryExceptionBase const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::ArrayFactory::ArrayFactory()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mlutil::cmddistributor::DataArraysDeleter::operator()(std::vector<foundation::matlabdata::Array, std::allocator<foundation::matlabdata::Array> >*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mdFunctionCallProtectedDispatcher::mdFunctionCallProtectedDispatcher(Mfh_MATLAB_fn*, bool, Mdispatcher*, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utInterruptState::ThrowIfInterruptPending()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::read(char*, long) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5P_CLS_FILE_CREATE_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::sources::aux::get_severity_level()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::IODevice::IODevice(foundation::storage::vfs::File)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::Transpose(void const*, void*, unsigned long, unsigned long, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Fcreate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::get_privates(int, std::vector<Mfh_MATLAB_fn*, std::allocator<Mfh_MATLAB_fn*> >&, std::vector<char16_t const*, std::allocator<char16_t const*> >&) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aread at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Lmove at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::add_clear_event_subscriber(mwboost::signals2::slot<void (), mwboost::function<void ()> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::get_license_restriction() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::matlab::ServerArrayFactory::releaseMxArray(foundation::matlabdata::Array&&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pset_userblock at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceException::ServiceException(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, cppmicroservices::ServiceException::Type const&)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::ThrowIndexExceedsDimensionsError(MathWorks::indexing::utilities::IndicesType) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5P_CLS_DATASET_CREATE_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IUserException::convert_str(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&) const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `vtable for foundation::core::except::detail::bad_alloc_impl::internal'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Scopy at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::record_view::public_data::destroy(mwboost::log::v2_mt_posix::record_view::public_data const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_MATLAB_fn_impl::load()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::Array::getType() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `fl::i18n::codecvt_string_to_ustring::codecvt_string_to_ustring(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utf16_to_lcp_n'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::ServiceReferenceBase(cppmicroservices::ServiceReferenceBase const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::GetUserVisibleFullFunctionName[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `foundation::storage::vfs::File::~File()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::find(char16_t const*, unsigned long, unsigned long) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_hfuncname() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_assign(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::getBreakpointCondition() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::PromiseDelegate::~PromiseDelegate()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Screate_simple at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdRequest::getStreamID() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Rget_obj_type2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tcreate at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::ServiceReferenceBase::operator=(decltype(nullptr))'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::PromiseDelegate::tryRunTask()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::report_breakpoints(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, std::vector<mwboost::shared_ptr<IBreakpointReporter>, std::allocator<mwboost::shared_ptr<IBreakpointReporter> > >&)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Aopen_by_idx at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `void foundation::matlabdata::detail::setElement<foundation::matlabdata::CharArray>(std::shared_ptr<matlab::data::detail::ReferenceImpl>, foundation::matlabdata::CharArray)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `void foundation::matlabdata::detail::setElement<foundation::matlabdata::TypedArray<double> >(std::shared_ptr<matlab::data::detail::ReferenceImpl>, foundation::matlabdata::TypedArray<double>)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_UINT64_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::RuntimeException'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::CvtExceptionBase::~CvtExceptionBase()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utGetFormatEndian'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::IsThrowIndexExceedsDimension() const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >::_M_append(char16_t const*, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::LDAPFilter::ToString[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::aux::code_convert_impl(char16_t const*, unsigned long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, unsigned long, std::locale const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::getFunctionInLexicalScope(MathWorks::Dispatcher::FunctionName const&) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Sclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utStrdup'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `utPutFourByteInt'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Tget_size at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pset_fill_value at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libeng.so: undefined reference to `utF2cstr'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utLoadLibraryWithLocalSymbolVisibility(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, int*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utIsSignalThread'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::RuntimeException::GetUnicodeMessageTxt[abi:cxx11]() const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `utVprintf'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::lxe::IndexInfo::IndexInfo(unsigned long, MathWorks::lxe::RHSInfo const&, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::basic_record_ostream<char>::detach_from_record()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Fclose at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for mlutil::io::SinkTraits'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utLogWarning(utWarningManagerContext*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, __va_list_tag*, std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> > const&, bool)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::TypedArray<matlab::data::GetReturnType<int>::type> foundation::matlabdata::ArrayFactory::createScalar<int>(int)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::ArrayFactory::createStructArray(std::vector<unsigned long, std::allocator<unsigned long> >, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >)'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `cppmicroservices::LDAPFilter::LDAPFilter()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_FLOAT_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for foundation::core::except::IException'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Pset_layout at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `typeinfo for foundation::storage::vfs::InvalidIRIException'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `ut_ghash_query'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utFinite'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mlm_file::checkout_license()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for cmddistributor::IIPResult'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `cmddistributor::CmdDistributor::RequestTrackingDeleter::operator()(cmddistributor::CmdDistributor::RequestTracking*) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Dcreate2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::get_hiddens(int, std::vector<Mfh_MATLAB_fn*, std::allocator<Mfh_MATLAB_fn*> >&, std::vector<char16_t const*, std::allocator<char16_t const*> >&) const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `mfl_permute::Permute(void const*, void*, unsigned long, unsigned long const*, unsigned long const*, unsigned long, long const*, long const*)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::core::except::IMsgIDException::get_error_id[abi:cxx11](resource_core::BaseMsgID const&) const'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `typeinfo for Mfh_MATLAB_fn'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `vtable for cmddistributor::EvalCmdRequest'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `utIsMultiByteCharSet'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `fl::i18n::codecvt_ustring_to_wstring::~codecvt_ustring_to_wstring()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::filterSyntheticName(std::__cxx11::basic_string<char16_t, std::char_traits<char16_t>, std::allocator<char16_t> >&) const'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5T_NATIVE_INT64_g at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_file::~Mfh_file()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `Mfh_MATLAB_fn_impl::get_complete_external_name() const'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `MathWorks::indexing::utilities::BadSubscriptHandler::InitializeInvalidIndexHandler(unsigned long, unsigned long)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `MathWorks::System::report(MathWorks::System::Externalizable const&, MathWorks::System::Level const&)'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `foundation::matlabdata::matlab::ServerArrayFactory::~ServerArrayFactory()'
//usr/local/matlab/bin/glnxa64/libmex.so: undefined reference to `mwboost::log::v2_mt_posix::basic_record_ostream<char>::init_stream()'
//usr/local/matlab/bin/glnxa64/libmat.so: undefined reference to `H5Gopen2 at MWHDF51.8.12'
//usr/local/matlab/bin/glnxa64/libmx.so: undefined reference to `typeinfo for util::detail::legacy_bad_alloc_impl'
collect2: error: ld returned 1 exit status
#include <petsc.h>
int main(int argc, char* argv[]) {
    PetscInitialize(&argc, &argv, NULL, NULL);
    PetscPrintf(PETSC_COMM_WORLD, "Hello, PETSc!\n");
    PetscFinalize();
    return 0;
