[petsc-users] compiler related error (configuring Petsc)
maitri ksh maitri.ksh at gmail.com
Wed Aug 2 03:07:13 CDT 2023
Okay, thank you.
On Tue, Aug 1, 2023 at 9:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44)
> Is it possible for you to use a newer version GNU compilers?
> If not - your alternative is to build PETSc with --with-cxx=0 option
> But then - you can't use --download-superlu_dist or any pkgs that need
> c++ [you could try building them separately though]
> Satish
> On Tue, 1 Aug 2023, maitri ksh wrote:
> > I am trying to compile petsc on a cluster ( x86_64-redhat-linux, '
> > *configure.log'*  is attached herewith) . Initially I got an error
> related
> > to 'C++11' flag, to troubleshoot this issue, I used 'CPPFLAGS' and
> > 'CXXFLAGS' and could surpass the non-compliant error related to c++
> compiler
> >  but now it gives me another error 'cannot find a C preprocessor'. How to
> > fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230802/1135c7e1/attachment.html>
