[petsc-users] Setting up a matrix for Lagrange multiplier
Mon Apr 24 12:41:50 CDT 2023
On Mon, Apr 24, 2023 at 1:37 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Great to know there is an example now.
> Yes, -pc_fieldsplit_defect_saddle_point worked.
> But I would like to understand what I did wrong (and why it didn’t work).
Can you show the error? Or give something self-contained that I can run.
> After reading many posted posts, I needed to create PCFieldSplitSetIS to
> split the fields.
Yes. I would give NULL for the name here.
> I set the first N indices to the field phi and the next C indices
> (starting from N) to the field lambda.
This looks fine. However, these are global indices, so this would not work
in parallel. You would have to offset by
the first index on this process.
     Matt
> Please tell me what I did wrong and how I can fix the lines which are now
> commented?
>     PetscErrorCode ierr;
>     KSP           ksp;
>     PC            pc;
>     KSPCreate(PETSC_COMM_WORLD, &ksp);
>     KSPSetType(ksp, KSPGMRES);
>     KSPSetOperators(ksp, A[level], A[level]);
>     ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>     ierr = PCSetType(pc,PCFIELDSPLIT);CHKERRQ(ierr);
> *    for* (*int* i = 0; i < N; i++)
>       vec_zero_field_index[i] = i;
>     PetscInt * vec_first_field_index = *NULL*;
>     PetscMalloc(n * *sizeof*(PetscInt), &vec_first_field_index);
>     *for* (*int* i = 0; i < C; i++)
>         vec_first_field_index[i] = N + i;
>     IS zero_field_isx, first_field_isx;
>     CHKERRQ(ISCreateGeneral(PETSC_COMM_WORLD, N, vec_zero_field_index,
> PETSC_COPY_VALUES, &zero_field_isx));
>     CHKERRQ(ISCreateGeneral(PETSC_COMM_WORLD, C, vec_first_field_index,
> PETSC_COPY_VALUES, &first_field_isx));
>     ierr = PCFieldSplitSetIS(pc,"0",zero_field_isx);  CHKERRQ(ierr);
>     ierr = PCFieldSplitSetIS(pc,"1",first_field_isx);  CHKERRQ(ierr);
>     ierr = PetscOptionsSetValue(*NULL*,"-ksp_type", "fgmres"); CHKERRQ
> (ierr);
>     ierr = PetscOptionsSetValue(*NULL*,"-pc_type", "fieldsplit"); CHKERRQ
> (ierr);
>     ierr = PetscOptionsSetValue(NULL,"-fieldsplit_0_ksp_type", "gmres");
> CHKERRQ(ierr);
>     ierr = PetscOptionsSetValue(NULL,"-fieldsplit_0_pc_type", "jacobi");
> CHKERRQ(ierr);
>     ierr = PetscOptionsSetValue(NULL,"-fieldsplit_1_ksp_type",
> "preonly"); CHKERRQ(ierr);
>     ierr = PetscOptionsSetValue(NULL,"-fieldsplit_1_pc_type", "lu");
> CHKERRQ(ierr);*/
> "-pc_fieldsplit_detect_saddle_point", *NULL*);CHKERRQ(ierr);
>     ierr = PetscOptionsSetValue(*NULL*, "-options_left", *NULL*);CHKERRQ
> (ierr);
>     ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
>     KSPSolve(ksp, b, x);
> Best,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Monday, 24 April 2023 at 17:57
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Setting up a matrix for Lagrange multiplier
> On Mon, Apr 24, 2023 at 10:22 AM Karthikeyan Chockalingam - STFC UKRI <
> Hello,
> I was able to construct the below K matrix (using submatrices P and P^T),
> which is of type MATAIJ
> K = [A P^T
>        P   0]
> and solved them using a direct solver.
> I modified your example to create either AIJ or Nest matrices, but use the
> same assembly code:
>   https://gitlab.com/petsc/petsc/-/merge_requests/6368
> However, I was reading online that this is a saddle point problem and I
> should be employing PCFIELDSPLIT.
> Since I have one monolithic matrix K, I was not sure how to split the
> fields.
> With this particular matrix, you can use
> and it will split it automatically.
>   Thanks,
>      Matt
> Best regards,
> Karthik.
> *From: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Date: *Wednesday, 19 April 2023 at 17:52
> *To: *Matthew Knepley <knepley at gmail.com>
>  I have declared the mapping
>   ISLocalToGlobalMapping mapping;
>     ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, n, nindices,
> PETSC_COPY_VALUES, &mapping);
> But when I use MatSetValuesLocal(), how do I know the above mapping is
> employed because it is not one of the parameters passed to the function?
> Thank you.
> Kind regards,
> Karthik.
> *Date: *Tuesday, 18 April 2023 at 16:21
> On Tue, Apr 18, 2023 at 11:16 AM Karthikeyan Chockalingam - STFC UKRI <
> Thank you for your response. I spend some time understanding how
> MatSetValuesLocal and ISLocalToGlobalMappingCreate work.
> You can look at SNES ex28 where we do this with DMCOMPOSITE.
> Q1) Will the matrix K be of type MATMPIAIJ or MATIS?
> K = [A P^T
>        P   0]
> I assume MPIAIJ since IS is only used for Neumann-Neumann decompositions.
> Q2) Can I use both MatSetValues() to MatSetValuesLocal() to populate K?
> Since I have already used MatSetValues() to construct A.
> You can, and there would be no changes in serial if K is exactly the upper
> left block, but in parallel global indices would change.
> Q3) What are the advantages of using MatSetValuesLocal()? Is it that I can
> construct P directly using local indies and map the entrees to the global
> index in K?
> You have a monolithic K, so that you can use sparse direct solvers to
> check things. THis is impossible with separate storage.
> Q4) I probably don’t have to construct an independent P matrix
> You wouldn't in this case.
>   Thanks,
>      Matt
> Best regards,
> Karthik.
> *Date: *Tuesday, 18 April 2023 at 11:08
> On Tue, Apr 18, 2023 at 5:24 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I'm solving a problem using the Lagrange multiplier, the matrix has the
> form
> K = [A P^T
>        P   0]
> I am familiar with constructing K using MATMPIAIJ. However, I would like
> to know if had [A], can I augment it with [P], [P^T] and [0] of type
> MATMPIAIJ? Likewise for vectors as well.
> Can you please point me to the right resource, if it is a common operation
> in PETSc?
> You can do this at least 2 ways:
>   1) Assemble you submatrices directly into the larger matrix by
> constructing local-to-global maps for the emplacement. so that you do
>       not change your assembly code, except to change MatSetValues() to
> MatSetValuesLocal(). This is usually preferable.
>   2) Use MATNEST and VecNEST to put pointers to submatrices and subvectors
> directly in.
>   Thanks,
>      Matt
> Many thanks.
> Kind regards,
> Karthik.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230424/6f312f5b/attachment-0001.html>
