[petsc-users] Question about NASM initialization
Takahashi, Tadanaga tt73 at njit.edu
Thu Apr 6 09:42:39 CDT 2023
Ok, thanks for the clarification.
On Thu, Apr 6, 2023 at 10:25 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Apr 6, 2023 at 10:21 AM Takahashi, Tadanaga <tt73 at njit.edu> wrote:
>> I am following up from the last inquiry. I read the source code nasm.c
>> <https://petsc.org/release/src/snes/impls/nasm/nasm.c.html> and it looks
>> like sub-snes iteration is being initialized with a scatter call from the
>> previous solution. In other words, if I use Newton's method for the local
>> solver, then in each NASM iteration the Newton's method uses the previous
>> local solution as the initial guess. Can anyone confirm this?
> This is the intention. There are not many tests, so it is possible there
> is a bug, but it is supposed to use the existing solution.
>   Thanks,
>     Matt
>> On Sun, Apr 2, 2023 at 6:14 PM Takahashi, Tadanaga <tt73 at njit.edu> wrote:
>>> Hello PETSc devs,
>>> I am using SNES NASM with Newton LS on the sub-SNES. I was wondering how
>>> the sub-SNES chooses the initial guess during each NASM iteration. Is it
>>> using the previously computed solution or is it restarting from zero?
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230406/9029154a/attachment.html>
