[petsc-users] a question about PetscSectionCreate
leejearl leejearl at 126.com
Mon May 29 01:39:26 CDT 2017
Hi, all:
I have create a IS for every cell in dmplex by the following steps:
1. Creating a integer array which size is matched to the number of cells.
2. Use the routine "ISCreateGeneral" to create a corresponding IS.
Is there any routine which can create a IS for every cell in the dmplex
directly?, and what is the difference between ISCopy() and ISDuplicate()?
leejearl
On 2017年05月28日 19:35, Matthew Knepley wrote:
> On Sun, May 28, 2017 at 6:02 AM, Lawrence Mitchell
> <lawrence.mitchell at imperial.ac.uk
> <mailto:lawrence.mitchell at imperial.ac.uk>> wrote:
>     > On 28 May 2017, at 09:16, leejearl <leejearl at 126.com
>     <mailto:leejearl at 126.com>> wrote:
>     > Hi, Dave: I want to store a PetscInt tag for every cell of the
>     dmplex with the struct. Thanks,
>     You probably want to use a DMLabel to store these ids. Unless you
>     have a different I'd for every cell.
> Several things to think about:
> 1) If you want to store a tag for EVERY cell, then just use an IS.
> Cell numberings are guaranteed to be
>     contiguous and start from 0.
> 2) If you want to tag only SOME cells, then use a DMLabel as Lawrence
> suggests. This uses hash tables
>     for fast construction, and sorted lists for fast search and retrieval.
> 3) If you want to store a VARIABLE number of data items per cell, then
> use a Section and an array that you allocate.
>    Matt
>     Lawrence
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
李季
西北工业大学航空学院流体力学系
Phone: 17792092487
QQ: 188524324
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170529/f7673e56/attachment.html>
