[petsc-users] a question about PetscSectionCreate
Sun May 28 06:35:11 CDT 2017
On Sun, May 28, 2017 at 6:02 AM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> > On 28 May 2017, at 09:16, leejearl <leejearl at 126.com> wrote:
> > Hi, Dave: I want to store a PetscInt tag for every cell of the dmplex
> with the struct. Thanks,
> You probably want to use a DMLabel to store these ids. Unless you have a
> different I'd for every cell.
Several things to think about:
1) If you want to store a tag for EVERY cell, then just use an IS. Cell
numberings are guaranteed to be
    contiguous and start from 0.
2) If you want to tag only SOME cells, then use a DMLabel as Lawrence
suggests. This uses hash tables
    for fast construction, and sorted lists for fast search and retrieval.
3) If you want to store a VARIABLE number of data items per cell, then use
a Section and an array that you allocate.
   Matt
> Lawrence
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170528/788f5874/attachment.html>
