[petsc-users] PCFactorSetShiftType does not work in code but -pc_factor_set_shift_type works
Danyang Su danyang.su at gmail.com
Thu May 25 15:18:39 CDT 2017
Hi Hong,
It works like a charm. I really appreciate your help.
Danyang
On 17-05-25 07:49 AM, Hong wrote:
> Danyang:
> You must access inner pc, then set shift. See
> petsc/src/ksp/ksp/examples/tutorials/ex7.c
> For example, I add following to
> petsc/src/ksp/ksp/examples/tutorials/ex2.c, line 191:
>   PetscBool isbjacobi;
>   PC        pc;
>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>   ierr =
> PetscObjectTypeCompare((PetscObject)pc,PCBJACOBI,&isbjacobi);CHKERRQ(ierr);
>   if (isbjacobi) {
>     PetscInt nlocal;
>     KSP      *subksp;
>     PC       subpc;
>     ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>     /* Extract the array of KSP contexts for the local blocks */
>     ierr = PCBJacobiGetSubKSP(pc,&nlocal,NULL,&subksp);CHKERRQ(ierr);
>     printf("isbjacobi, nlocal %D, set option to subpc...\n",nlocal);
>     for (i=0; i<nlocal; i++) {
>       ierr = KSPGetPC(subksp[i],&subpc);CHKERRQ(ierr);
>       ierr = PCFactorSetShiftType(subpc,MAT_SHIFT_NONZERO);CHKERRQ(ierr);
>     Dear Hong and Barry,
>     I have implemented this option in the code, as we also need to use
>     configuration from file for convenience. When I run the code using
>     options, it works fine, however, when I run the code using
>     configuration file, it does not work. The code has two set of
>     equations, flow and reactive, with prefix been set to "flow_" and
>     "react_". When I run the code using
>     mpiexec -n 4 ../executable -flow_sub_pc_factor_shift_type nonzero
>     -react_sub_pc_factor_shift_type nonzero
>     it works. However, if I run using
>     and let the executable file read the options from file, it just
>     does not work at "call
>     PCFactorSetShiftType(pc_flow,MAT_SHIFT_NONZERO, ierr)  or none,
>     positive_definite ...". Do I miss something here?
>     Below is the pseudo code I have used for flow equations, similar
>     for reactive equations.
>               call MatCreateAIJ(Petsc_Comm_World,nndof,nndof,nngbldof, &
>                                 nngbldof,d_nz,PETSC_NULL_INTEGER,o_nz, &
>                                 PETSC_NULL_INTEGER,a_flow,ierr)
>               CHKERRQ(ierr)
>             call MatSetFromOptions(a_flow,ierr)
>             CHKERRQ(ierr)
>             call KSPCreate(Petsc_Comm_World, ksp_flow, ierr)
>             CHKERRQ(ierr)
>             call KSPAppendOptionsPrefix(ksp_flow,"flow_",ierr)
>             CHKERRQ(ierr)
>             call KSPSetInitialGuessNonzero(ksp_flow, &
>                     b_initial_guess_nonzero_flow, ierr)
>             CHKERRQ(ierr)
>             CHKERRQ(ierr)
>             call KSPSetDM(ksp_flow,dmda_flow%da,ierr)
>             CHKERRQ(ierr)
>             call KSPSetDMActive(ksp_flow,PETSC_FALSE,ierr)
>             CHKERRQ(ierr)
>             !!!!*********CHECK IF READ OPTION FROM FILE*********!!!!
>             if (read_option_from_file) then
>               call KSPSetType(ksp_flow, KSPGMRES, ierr) !or KSPBCGS or
>     others...
>               CHKERRQ(ierr)
>               call KSPGetPC(ksp_flow, pc_flow, ierr)
>               CHKERRQ(ierr)
>               call PCSetType(pc_flow,PCBJACOBI, ierr)       !or PCILU
>     or PCJACOBI or PCHYPRE ...
>               CHKERRQ(ierr)
>               call PCFactorSetShiftType(pc_flow,MAT_SHIFT_NONZERO,
>     ierr)  or none, positive_definite ...
>               CHKERRQ(ierr)
>             end if
>             call
>     PCFactorGetMatSolverPackage(pc_flow,solver_pkg_flow,ierr)
>             CHKERRQ(ierr)
>             call compute_jacobian(rank,dmda_flow%da, &
>     a_flow,a_in,ia_in,ja_in,nngl_in,         &
>     row_idx_l2pg,col_idx_l2pg,            &
>                                   b_non_interlaced)
>             call KSPSetFromOptions(ksp_flow,ierr)
>             CHKERRQ(ierr)
>             call KSPSetUp(ksp_flow,ierr)
>             CHKERRQ(ierr)
>             call KSPSetUpOnBlocks(ksp_flow,ierr)
>             CHKERRQ(ierr)
>             call KSPSolve(ksp_flow,b_flow,x_flow,ierr)
>             CHKERRQ(ierr)
>     Thanks and Regards,
>     Danyang
>     On 17-05-24 06:32 PM, Hong wrote:
>>     Remove your option '-vecload_block_size 10'.
>>     Hong
>>     On Wed, May 24, 2017 at 3:06 PM, Danyang Su <danyang.su at gmail.com
>>     <mailto:danyang.su at gmail.com>> wrote:
>>         Dear Hong,
>>         I just tested with different number of processors for the
>>         same matrix. It sometimes got "ERROR: Arguments are
>>         incompatible" for different number of processors. It works
>>         fine using 4, 8, or 24 processors, but failed with "ERROR:
>>         Arguments are incompatible" using 16 or 48 processors. The
>>         error information is attached. I tested this on my local
>>         computer with 6 cores 12 threads. Any suggestion on this?
>>         Thanks,
>>         Danyang
>>         On 17-05-24 12:28 PM, Danyang Su wrote:
>>>         Hi Hong,
>>>         Awesome. Thanks for testing the case. I will try your
>>>         options for the code and get back to you later.
>>>         Regards,
>>>         Danyang
>>>         On 17-05-24 12:21 PM, Hong wrote:
>>>>         Danyang :
>>>>         I tested your data.
>>>>         Your matrices encountered zero pivots, e.g.
>>>>         petsc/src/ksp/ksp/examples/tutorials (master)
>>>>         $ mpiexec -n 24 ./ex10 -f0 a_react_in_2.bin -rhs
>>>>         b_react_in_2.bin -ksp_monitor -ksp_error_if_not_converged
>>>>         [15]PETSC ERROR: Zero pivot in LU factorization:
>>>>         http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
>>>>         <http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot>
>>>>         [15]PETSC ERROR: Zero pivot row 1249 value 2.05808e-14
>>>>         tolerance 2.22045e-14
>>>>         Adding option '-sub_pc_factor_shift_type nonzero', I got
>>>>         -sub_pc_factor_shift_type nonzero -mat_view ascii::ascii_info
>>>>         Mat Object: 24 MPI processes
>>>>         type: mpiaij
>>>>         rows=450000, cols=450000
>>>>         total: nonzeros=6991400, allocated nonzeros=6991400
>>>>         total number of mallocs used during MatSetValues calls =0
>>>>         not using I-node (on process 0) routines
>>>>           0 KSP Residual norm 5.849777711755e+01
>>>>           1 KSP Residual norm 6.824179430230e-01
>>>>           2 KSP Residual norm 3.994483555787e-02
>>>>           3 KSP Residual norm 6.085841461433e-03
>>>>           4 KSP Residual norm 8.876162583511e-04
>>>>           5 KSP Residual norm 9.407780665278e-05
>>>>         Number of iterations =   5
>>>>         Residual norm 0.00542891
>>>>         Hong
>>>>             Hi Matt,
>>>>             Yes. The matrix is 450000x450000 sparse. The hypre
>>>>             takes hundreds of iterates, not for all but in most of
>>>>             the timesteps. The matrix is not well conditioned, with
>>>>             nonzero entries range from 1.0e-29 to 1.0e2. I also
>>>>             made double check if there is anything wrong in the
>>>>             parallel version, however, the matrix is the same with
>>>>             sequential version except some round error which is
>>>>             relatively very small. Usually for those not well
>>>>             conditioned matrix, direct solver should be faster than
>>>>             iterative solver, right? But when I use the sequential
>>>>             iterative solver with ILU prec developed almost 20
>>>>             years go by others, the solver converge fast with
>>>>             appropriate factorization level. In other words, when I
>>>>             use 24 processor using hypre, the speed is almost the
>>>>             same as as the old sequential iterative solver using 1
>>>>             processor.
>>>>             I use most of the default configuration for the general
>>>>             case with pretty good speedup. And I am not sure if I
>>>>             miss something for this problem.
>>>>             Thanks,
>>>>             Danyang
>>>>             On 17-05-24 11:12 AM, Matthew Knepley wrote:
>>>>>             On Wed, May 24, 2017 at 12:50 PM, Danyang Su
>>>>>             <danyang.su at gmail.com <mailto:danyang.su at gmail.com>>
>>>>>             wrote:
>>>>>                 Hi Matthew and Barry,
>>>>>                 Thanks for the quick response.
>>>>>                 I also tried superlu and mumps, both work but it
>>>>>                 is about four times slower than ILU(dt) prec
>>>>>                 through hypre, with 24 processors I have tested.
>>>>>             You mean the total time is 4x? And you are taking
>>>>>             hundreds of iterates? That seems hard to believe,
>>>>>             unless you are dropping
>>>>>             a huge number of elements.
>>>>>                 When I look into the convergence information, the
>>>>>                 method using ILU(dt) still takes 200 to 3000
>>>>>                 linear iterations for each newton iteration. One
>>>>>                 reason is this equation is hard to solve. As for
>>>>>                 the general cases, the same method works awesome
>>>>>                 and get very good speedup.
>>>>>             I do not understand what you mean here.
>>>>>                 I also doubt if I use hypre correctly for this
>>>>>                 case. Is there anyway to check this problem, or is
>>>>>                 it possible to increase the factorization level
>>>>>                 through hypre?
>>>>>             I don't know.
>>>>>               Matt
>>>>>                 Thanks,
>>>>>                 Danyang
>>>>>                 On 17-05-24 04:59 AM, Matthew Knepley wrote:
>>>>>>                 On Wed, May 24, 2017 at 2:21 AM, Danyang Su
>>>>>>                     Dear All,
>>>>>>                     I use PCFactorSetLevels for ILU and
>>>>>>                     PCFactorSetFill for other preconditioning in
>>>>>>                     my code to help solve the problems that the
>>>>>>                     default option is hard to solve. However, I
>>>>>>                     found the latter one, PCFactorSetFill does
>>>>>>                     not take effect for my problem. The matrices
>>>>>>                     and rhs as well as the solutions are attached
>>>>>>                     from the link below. I obtain the solution
>>>>>>                     using hypre preconditioner and it takes 7 and
>>>>>>                     38 iterations for matrix 1 and matrix 2.
>>>>>>                     However, if I use other preconditioner, the
>>>>>>                     solver just failed at the first matrix. I
>>>>>>                     have tested this matrix using the native
>>>>>>                     sequential solver (not PETSc) with ILU
>>>>>>                     preconditioning. If I set the incomplete
>>>>>>                     factorization level to 0, this sequential
>>>>>>                     solver will take more than 100 iterations. If
>>>>>>                     I increase the factorization level to 1 or
>>>>>>                     more, it just takes several iterations. This
>>>>>>                     remind me that the PC factor for this
>>>>>>                     matrices should be increased. However, when I
>>>>>>                     tried it in PETSc, it just does not work.
>>>>>>                     Matrix and rhs can be obtained from the link
>>>>>>                     below.
>>>>>>                     https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R
>>>>>>                     <https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R>
>>>>>>                     Would anyone help to check if you can make
>>>>>>                     this work by increasing the PC factor level
>>>>>>                     or fill?
>>>>>>                 We have ILU(k) supported in serial. However
>>>>>>                 ILU(dt) which takes a tolerance only works
>>>>>>                 through Hypre
>>>>>>                 http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>>>>>                 <http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html>
>>>>>>                 I recommend you try SuperLU or MUMPS, which can
>>>>>>                 both be downloaded automatically by configure, and
>>>>>>                 do a full sparse LU.
>>>>>>                   Thanks,
>>>>>>                     Matt
>>>>>>                     Thanks and regards,
>>>>>>                     Danyang
>>>>>>                 What most experimenters take for granted before
>>>>>>                 they begin their experiments is infinitely more
>>>>>>                 interesting than any results to which their
>>>>>>                 experiments lead.
>>>>>>                 -- Norbert Wiener
>>>>>>                 http://www.caam.rice.edu/~mk51/
>>>>>>                 <http://www.caam.rice.edu/%7Emk51/>
>>>>>             What most experimenters take for granted before they
>>>>>             begin their experiments is infinitely more interesting
>>>>>             than any results to which their experiments lead.
>>>>>             -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170525/a17faf3d/attachment-0001.html>
