[petsc-users] PCFactorSetShiftType does not work in code but -pc_factor_set_shift_type works
Hong hzhang at mcs.anl.gov
Thu May 25 09:49:59 CDT 2017
Danyang:
You must access inner pc, then set shift. See
petsc/src/ksp/ksp/examples/tutorials/ex7.c
For example, I add following to petsc/src/ksp/ksp/examples/tutorials/ex2.c,
line 191:
  PetscBool isbjacobi;
  PC        pc;
  ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
  ierr =
PetscObjectTypeCompare((PetscObject)pc,PCBJACOBI,&isbjacobi);CHKERRQ(ierr);
  if (isbjacobi) {
    PetscInt nlocal;
    KSP      *subksp;
    PC       subpc;
    ierr = KSPSetUp(ksp);CHKERRQ(ierr);
    /* Extract the array of KSP contexts for the local blocks */
    ierr = PCBJacobiGetSubKSP(pc,&nlocal,NULL,&subksp);CHKERRQ(ierr);
    printf("isbjacobi, nlocal %D, set option to subpc...\n",nlocal);
    for (i=0; i<nlocal; i++) {
      ierr = KSPGetPC(subksp[i],&subpc);CHKERRQ(ierr);
      ierr = PCFactorSetShiftType(subpc,MAT_SHIFT_NONZERO);CHKERRQ(ierr);
Dear Hong and Barry,
> I have implemented this option in the code, as we also need to use
> configuration from file for convenience. When I run the code using options,
> it works fine, however, when I run the code using configuration file, it
> does not work. The code has two set of equations, flow and reactive, with
> prefix been set to "flow_" and "react_". When I run the code using
> mpiexec -n 4 ../executable -flow_sub_pc_factor_shift_type nonzero
> -react_sub_pc_factor_shift_type nonzero
> it works. However, if I run using
> and let the executable file read the options from file, it just does not
> work at "call PCFactorSetShiftType(pc_flow,MAT_SHIFT_NONZERO, ierr)  or
> none, positive_definite ...". Do I miss something here?
> Below is the pseudo code I have used for flow equations, similar for
> reactive equations.
>           call MatCreateAIJ(Petsc_Comm_World,nndof,nndof,nngbldof,     &
>                             nngbldof,d_nz,PETSC_NULL_INTEGER,o_nz,     &
>                             PETSC_NULL_INTEGER,a_flow,ierr)
>           CHKERRQ(ierr)
>         call MatSetFromOptions(a_flow,ierr)
>         CHKERRQ(ierr)
>         call KSPCreate(Petsc_Comm_World, ksp_flow, ierr)
>         CHKERRQ(ierr)
>         call KSPAppendOptionsPrefix(ksp_flow,"flow_",ierr)
>         CHKERRQ(ierr)
>         call KSPSetInitialGuessNonzero(ksp_flow,                       &
>                 b_initial_guess_nonzero_flow, ierr)
>         CHKERRQ(ierr)
>         CHKERRQ(ierr)
>         call KSPSetDM(ksp_flow,dmda_flow%da,ierr)
>         CHKERRQ(ierr)
>         call KSPSetDMActive(ksp_flow,PETSC_FALSE,ierr)
>         CHKERRQ(ierr)
>         !!!!*********CHECK IF READ OPTION FROM FILE*********!!!!
>         if (read_option_from_file) then
>           call KSPSetType(ksp_flow, KSPGMRES, ierr)    !or KSPBCGS or
> others...
>           CHKERRQ(ierr)
>           call KSPGetPC(ksp_flow, pc_flow, ierr)
>           CHKERRQ(ierr)
>           call PCSetType(pc_flow,PCBJACOBI, ierr)       !or PCILU or
> PCJACOBI or PCHYPRE ...
>           CHKERRQ(ierr)
>           CHKERRQ(ierr)
>         end if
>         call PCFactorGetMatSolverPackage(pc_flow,solver_pkg_flow,ierr)
>         CHKERRQ(ierr)
>         call compute_jacobian(rank,dmda_flow%da,                       &
>                               a_flow,a_in,ia_in,ja_in,nngl_in,         &
>                               row_idx_l2pg,col_idx_l2pg,               &
>                               b_non_interlaced)
>         call KSPSetFromOptions(ksp_flow,ierr)
>         CHKERRQ(ierr)
>         call KSPSetUp(ksp_flow,ierr)
>         CHKERRQ(ierr)
>         call KSPSetUpOnBlocks(ksp_flow,ierr)
>         CHKERRQ(ierr)
>         call KSPSolve(ksp_flow,b_flow,x_flow,ierr)
>         CHKERRQ(ierr)
> Thanks and Regards,
> Danyang
> On 17-05-24 06:32 PM, Hong wrote:
> Remove your option '-vecload_block_size 10'.
> Hong
> On Wed, May 24, 2017 at 3:06 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Dear Hong,
>> I just tested with different number of processors for the same matrix. It
>> sometimes got "ERROR: Arguments are incompatible" for different number of
>> processors. It works fine using 4, 8, or 24 processors, but failed with
>> "ERROR: Arguments are incompatible" using 16 or 48 processors. The error
>> information is attached. I tested this on my local computer with 6 cores 12
>> threads. Any suggestion on this?
>> Thanks,
>> Danyang
>> On 17-05-24 12:28 PM, Danyang Su wrote:
>> Hi Hong,
>> Awesome. Thanks for testing the case. I will try your options for the
>> code and get back to you later.
>> Regards,
>> Danyang
>> On 17-05-24 12:21 PM, Hong wrote:
>> Danyang :
>> I tested your data.
>> Your matrices encountered zero pivots, e.g.
>> petsc/src/ksp/ksp/examples/tutorials (master)
>> $ mpiexec -n 24 ./ex10 -f0 a_react_in_2.bin -rhs b_react_in_2.bin
>> -ksp_monitor -ksp_error_if_not_converged
>> [15]PETSC ERROR: Zero pivot in LU factorization:
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
>> [15]PETSC ERROR: Zero pivot row 1249 value 2.05808e-14 tolerance
>> 2.22045e-14
>> Adding option '-sub_pc_factor_shift_type nonzero', I got
>> -ksp_monitor -ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero
>> -mat_view ascii::ascii_info
>> Mat Object: 24 MPI processes
>>   type: mpiaij
>>   rows=450000, cols=450000
>>   total: nonzeros=6991400, allocated nonzeros=6991400
>>   total number of mallocs used during MatSetValues calls =0
>>     not using I-node (on process 0) routines
>>   0 KSP Residual norm 5.849777711755e+01
>>   1 KSP Residual norm 6.824179430230e-01
>>   2 KSP Residual norm 3.994483555787e-02
>>   3 KSP Residual norm 6.085841461433e-03
>>   4 KSP Residual norm 8.876162583511e-04
>>   5 KSP Residual norm 9.407780665278e-05
>> Number of iterations =   5
>> Residual norm 0.00542891
>> Hong
>>> Hi Matt,
>>> Yes. The matrix is 450000x450000 sparse. The hypre takes hundreds of
>>> iterates, not for all but in most of the timesteps. The matrix is not well
>>> conditioned, with nonzero entries range from 1.0e-29 to 1.0e2. I also made
>>> double check if there is anything wrong in the parallel version, however,
>>> the matrix is the same with sequential version except some round error
>>> which is relatively very small. Usually for those not well conditioned
>>> matrix, direct solver should be faster than iterative solver, right? But
>>> when I use the sequential iterative solver with ILU prec developed almost
>>> 20 years go by others, the solver converge fast with appropriate
>>> factorization level. In other words, when I use 24 processor using hypre,
>>> the speed is almost the same as as the old sequential iterative solver
>>> using 1 processor.
>>> I use most of the default configuration for the general case with pretty
>>> good speedup. And I am not sure if I miss something for this problem.
>>> Thanks,
>>> Danyang
>>> On 17-05-24 11:12 AM, Matthew Knepley wrote:
>>> On Wed, May 24, 2017 at 12:50 PM, Danyang Su <danyang.su at gmail.com>
>>> wrote:
>>>> Hi Matthew and Barry,
>>>> Thanks for the quick response.
>>>> I also tried superlu and mumps, both work but it is about four times
>>>> slower than ILU(dt) prec through hypre, with 24 processors I have tested.
>>> You mean the total time is 4x? And you are taking hundreds of iterates?
>>> That seems hard to believe, unless you are dropping
>>> a huge number of elements.
>>>> When I look into the convergence information, the method using ILU(dt)
>>>> still takes 200 to 3000 linear iterations for each newton iteration. One
>>>> reason is this equation is hard to solve. As for the general cases, the
>>>> same method works awesome and get very good speedup.
>>> I do not understand what you mean here.
>>>> I also doubt if I use hypre correctly for this case. Is there anyway to
>>>> check this problem, or is it possible to increase the factorization level
>>>> through hypre?
>>> I don't know.
>>>   Matt
>>>> Thanks,
>>>> Danyang
>>>> On 17-05-24 04:59 AM, Matthew Knepley wrote:
>>>> On Wed, May 24, 2017 at 2:21 AM, Danyang Su <danyang.su at gmail.com>
>>>> wrote:
>>>>> Dear All,
>>>>> I use PCFactorSetLevels for ILU and PCFactorSetFill for other
>>>>> preconditioning in my code to help solve the problems that the default
>>>>> option is hard to solve. However, I found the latter one, PCFactorSetFill
>>>>> does not take effect for my problem. The matrices and rhs as well as the
>>>>> solutions are attached from the link below. I obtain the solution using
>>>>> hypre preconditioner and it takes 7 and 38 iterations for matrix 1 and
>>>>> matrix 2. However, if I use other preconditioner, the solver just failed at
>>>>> the first matrix. I have tested this matrix using the native sequential
>>>>> solver (not PETSc) with ILU preconditioning. If I set the incomplete
>>>>> factorization level to 0, this sequential solver will take more than 100
>>>>> iterations. If I increase the factorization level to 1 or more, it just
>>>>> takes several iterations. This remind me that the PC factor for this
>>>>> matrices should be increased. However, when I tried it in PETSc, it just
>>>>> does not work.
>>>>> Matrix and rhs can be obtained from the link below.
>>>>> https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R
>>>>> Would anyone help to check if you can make this work by increasing the
>>>>> PC factor level or fill?
>>>> We have ILU(k) supported in serial. However ILU(dt) which takes a
>>>> tolerance only works through Hypre
>>>>   http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>>> I recommend you try SuperLU or MUMPS, which can both be downloaded
>>>> automatically by configure, and
>>>> do a full sparse LU.
>>>>   Thanks,
>>>>     Matt
>>>>> Thanks and regards,
>>>>> Danyang
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> http://www.caam.rice.edu/~mk51/
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170525/f5e7b712/attachment-0001.html>
