[petsc-users] DMPlex distribution with FVM adjacency
Thu May 25 12:05:53 CDT 2017
On Thu, May 25, 2017 at 11:27 AM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> On 25/05/17 16:25, Matthew Knepley wrote:
> > On Thu, May 25, 2017 at 9:27 AM, Lawrence Mitchell
> > <lawrence.mitchell at imperial.ac.uk
> > <mailto:lawrence.mitchell at imperial.ac.uk>> wrote:
> >     Dear petsc-users,
> >     I am trying to distribute a triangle mesh with a cell halo defined by
> >     FVM adjacency (i.e. if I have a facet in the initial (0-overlap)
> >     distribution, I want the cell on the other side of it).
> >     Reading the documentation, I think I do:
> >     DMPlexSetAdjacencyUseCone(PETSC_TRUE)
> >     DMPlexSetAdjacencyUseClosure(PETSC_FALSE)
> >     and then
> >     DMPlexDistribute(..., ovelap=1)
> >     If I do this for a simple mesh and then try and do anything on it, I
> >     run into all sorts of problems because I have a plex where I have
> some
> >     facets, but not even one cell in the support of the facet.  Is this
> to
> >     be expected?
> > Hmm. I don't think so. You should have at least one cell in the
> > support of every facet.
> > TS ex11 works exactly this way.
> > When using that adjacency, the overlap cells you get will not have
> > anything but the
> > facet connecting them to that partition. Although, if you have
> > adjacent cells in that overlap layer,
> > you can get ghost faces between those.
> > With the code below, do you get an interpolated mesh when you create
> > it there. That call in C
> > has another argument
> >   http://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/
> DMPlexCreateFromCellList.html
> The mesh is interpolated.
> OK, so let's see if I can understand what the different adjacency
> relations are:
> usecone=False, useclosure=False:
> adj(p) => cone(p) + cone(support(p))
> usecone=True, useclosure=False:
> adj(p) => support(p) + support(cone(p))
> usecone=False, useclosure=True
> adj(p) => closure(star(p))
> usecone=True, useclosure=True
> adj(p) => star(closure(p))
> So let's imagine I have a facet f, the adjacent points are the
> support(cone(f)) so the support of the vertices in 2D, so those are
> some new facets.
If you want that, is there a reason you cannot use the FEM style FALSE+TRUE?
If you already want the closure, usually the star is not really adding
anything new.
   Matt
> So now, following https://arxiv.org/pdf/1506.06194.pdf, I need to
> complete this new mesh, so I ask for the closure of these new facets.
> But that might mean I won't ask for cells, right?  So I think I would
> end up with some facets that don't have any support.  And empirically
> I observe that:
> e.g. the code attached:
> $ mpiexec -n 3 python bar.py
> [0] 7 [0]
> [0] 8 [0]
> [0] 9 [0 1]
> [0] 10 [1]
> [0] 11 [1]
> [0] 12 []
> [1] 10 [0 2]
> [1] 11 [0 1]
> [1] 12 [0]
> [1] 13 [1]
> [1] 14 [2]
> [1] 15 [2]
> [1] 16 [1 3]
> [1] 17 [3]
> [1] 18 [3]
> [2] 7 [0 1]
> [2] 8 [0]
> [2] 9 [0]
> [2] 10 [1]
> [2] 11 []
> [2] 12 [1]
> What I would like (although I'm not sure if this is supported right
> now), is the overlap to contain closure(support(facet)) for all shared
> facets.  I think that's equivalent to closure(support(p)) \forall p.
> That way on any shared facets, I have both cells and their closure.
> Is that easy to do?
> Lawrence
> import sys, petsc4py
> petsc4py.init(sys.argv)
> from petsc4py import PETSc
> import numpy as np
> Lx = Ly = 1
> nx = 1
> ny = 2
> xcoords = np.linspace(0.0, Lx, nx + 1, dtype=PETSc.RealType)
> ycoords = np.linspace(0.0, Ly, ny + 1, dtype=PETSc.RealType)
> coords = np.asarray(np.meshgrid(xcoords, ycoords)).swapaxes(0,
> 2).reshape(-1, 2)
> # cell vertices
> i, j = np.meshgrid(np.arange(nx, dtype=PETSc.IntType), np.arange(ny,
> dtype=PETSc.IntType))
> cells = [i*(ny+1) + j, i*(ny+1) + j+1, (i+1)*(ny+1) + j+1,
> (i+1)*(ny+1) + j]
> cells = np.asarray(cells, dtype=PETSc.IntType).swapaxes(0,
> 2).reshape(-1, 4)
> idx = [0, 1, 3, 1, 2, 3]
> cells = cells[:, idx].reshape(-1, 3)
> comm = PETSc.COMM_WORLD
> if comm.rank == 0:
>     dm = PETSc.DMPlex().createFromCellList(2, cells, coords,
> interpolate=True, comm=comm)
> else:
>     dm = PETSc.DMPlex().createFromCellList(2, np.zeros((0,
> cells.shape[1]), dtype=PETSc.IntType),
>                                            np.zeros((0, 2),
> dtype=PETSc.RealType),
>                                            interpolate=True,
>                                            comm=comm)
> dm.setAdjacencyUseClosure(False)
> dm.setAdjacencyUseCone(True)
> dm.distribute(overlap=1)
> sf = dm.getPointSF()
> for p in range(*dm.getDepthStratum(dm.getDepth()-1)):
>     PETSc.Sys.syncPrint("[%d] %d %s" % (comm.rank, p, dm.getSupport(p)))
> PETSc.Sys.syncFlush()
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170525/47cc0d45/attachment.html>
