[petsc-users] GAMG scaling
Mark Adams mfadams at lbl.gov
Wed May 3 14:08:03 CDT 2017
Hong,the input files do not seem to be accessible. What are the command
line option? (I don't see a "rap" or "scale" in the source).
On Wed, May 3, 2017 at 12:17 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Mark,
> Below is the copy of my email sent to you on Feb 27:
> I implemented scalable MatPtAP and did comparisons of three
> implementations using ex56.c on alcf cetus machine (this machine has
> small memory, 1GB/core):
> - nonscalable PtAP: use an array of length PN to do dense axpy
> - scalable PtAP:       do sparse axpy without use of PN array
> - hypre PtAP.
> The results are attached. Summary:
> - nonscalable PtAP is 2x faster than scalable, 8x faster than hypre PtAP
> - scalable PtAP is 4x faster than hypre PtAP
> - hypre uses less memory (see job.ne399.n63.np1000.sh)
> Based on above observation, I set the default PtAP algorithm as
> 'nonscalable'.
> When PN > local estimated nonzero of C=PtAP, then switch default to
> 'scalable'.
> User can overwrite default.
> For the case of np=8000, ne=599 (see job.ne599.n500.np8000.sh), I get
> MatPtAP                   3.6224e+01 (nonscalable for small mats, scalable
> for larger ones)
> scalable MatPtAP     4.6129e+01
> hypre                        1.9389e+02
> This work in on petsc-master. Give it a try. If you encounter any problem,
> let me know.
> Hong
> On Wed, May 3, 2017 at 10:01 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> (Hong), what is the current state of optimizing RAP for scaling?
>> Nate, is driving 3D elasticity problems at scaling with GAMG and we are
>> working out performance problems. They are hitting problems at ~1.5B dof
>> problems on a basic Cray (XC30 I think).
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170503/a246292d/attachment.html>
