[petsc-users] GAMG scaling
Hong hzhang at mcs.anl.gov
Wed May 3 11:17:22 CDT 2017
Mark,
Below is the copy of my email sent to you on Feb 27:
I implemented scalable MatPtAP and did comparisons of three implementations
using ex56.c on alcf cetus machine (this machine has small memory,
1GB/core):
- nonscalable PtAP: use an array of length PN to do dense axpy
- scalable PtAP:       do sparse axpy without use of PN array
- hypre PtAP.
The results are attached. Summary:
- nonscalable PtAP is 2x faster than scalable, 8x faster than hypre PtAP
- scalable PtAP is 4x faster than hypre PtAP
- hypre uses less memory (see job.ne399.n63.np1000.sh)
Based on above observation, I set the default PtAP algorithm as
'nonscalable'.
When PN > local estimated nonzero of C=PtAP, then switch default to
'scalable'.
User can overwrite default.
For the case of np=8000, ne=599 (see job.ne599.n500.np8000.sh), I get
MatPtAP                   3.6224e+01 (nonscalable for small mats, scalable
for larger ones)
scalable MatPtAP     4.6129e+01
hypre                        1.9389e+02
This work in on petsc-master. Give it a try. If you encounter any problem,
let me know.
Hong
On Wed, May 3, 2017 at 10:01 AM, Mark Adams <mfadams at lbl.gov> wrote:
> (Hong), what is the current state of optimizing RAP for scaling?
> Nate, is driving 3D elasticity problems at scaling with GAMG and we are
> working out performance problems. They are hitting problems at ~1.5B dof
> problems on a basic Cray (XC30 I think).
> Thanks,
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170503/dc4f5eec/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170503/dc4f5eec/attachment.obj>
