[petsc-users] How to use f2py on a PETSc/SLEPc-based fortran code
Gaetan Kenway gaetank at gmail.com
Tue Mar 28 14:31:40 CDT 2017
You only get that file if you have wrapped a module explicitly in the .pyf
file. If you haven't wrapped a module, that doesn't get created.
Gaetan
On Tue, Mar 28, 2017 at 12:28 PM, Austin Herrema <aherrema at iastate.edu>
wrote:
> Gaetan,
> Thank you for this. With your help, I think I am getting close to getting
> this to work for my case. At the moment, I am hung up on the line of your
> makefile which reads "$(FF90) $(FF90_ALL_FLAGS) -I$(MAIN_DIR)/mod -c
> warpustruct-f2pywrappers2.f90". Am I correct that
> warpustruct-f2pywrappers2.f90 should be generated by f2py? If so, do you
> (or does anyone else) know the command for telling f2py to do so? At the
> moment I am using:
> f2py run_analysis.f90 -m run_analysis -h run_analysis.pyf
> to get the requisite .pyf and .c files, but no .f90 file. If I am wrong
> about the origin of this file, please do tell me!
> Thank you,
> Austin
> On Mon, Mar 27, 2017 at 5:13 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
>> Austin
>> Here is the full makefile for a code we use. The variables defined
>> externally in a separate config file are:
>> $(FF90)
>> $(FF90_FLAGS)
>> $(LIBDIR)
>> $(PETSC_LINKER_FLAGS)
>> $(LINKER_FLAGS)
>> $(CGNS_LINKER_FLAGS)
>> $(PYTHON)
>> $(PYTHON-CONIFG)
>> $(F2PY)
>> (These are usually use python, python-config and f2py. You can overwrite
>> as necessary)
>> $(CC)
>> $(CC_ALL_FLAGS)
>> This essentially just mimics what f2py does automatically but we found it
>> easier to control exactly what is going on. Essentially you are just
>> compiling exactly as you normally an executable, but instead make a .so
>> (with the -shared option) and including the additional .o files generated
>> by compiling the f2py-generated wrappers.
>> Hope this helps,
>> Gaetan
>> On Sat, Mar 25, 2017 at 5:38 AM, Lisandro Dalcin <dalcinl at gmail.com>
>> wrote:
>>> On 22 March 2017 at 20:29, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Lisandro,
>>>>     We've had a couple questions similar to this with f2py; is there a
>>>> way we could add to the PETSc/SLEPc makefile rules something to allow
>>>> people to trivially use f2py without having to make their own (often
>>>> incorrect) manual command lines?
>>>>    Thanks
>>> Barry, it is quite hard and hacky to get f2py working in the general
>>> case. I think the email from Gaetan in this thread proves my point.
>>> IMHO, it is easier to write a small Fortran source exposing the API to
>>> call using ISO_C_BINDINGS, then wrap that code with the more traditional
>>> C-based "static" tools (SWIG, Cython) or even "dynamically" with ctypes or
>>> cffi (which use dlopen'ing).
>>> Lisandro Dalcin
>>> Research Scientist
>>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>>> Extreme Computing Research Center (ECRC)
>>> King Abdullah University of Science and Technology (KAUST)
>>> http://ecrc.kaust.edu.sa/
>>> 4700 King Abdullah University of Science and Technology
>>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>>> http://www.kaust.edu.sa
>>> Office Phone: +966 12 808-0459 <+966%2012%20808%200459>
> *Austin Herrema*
> PhD Student | Graduate Research Assistant | Iowa State University
> Wind Energy Science, Engineering, and Policy | Mechanical Engineering
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170328/8fcdb3d3/attachment.html>
