[petsc-users] How to use f2py on a PETSc/SLEPc-based fortran code
Austin Herrema aherrema at iastate.edu
Tue Mar 28 14:28:05 CDT 2017
Gaetan,
Thank you for this. With your help, I think I am getting close to getting
this to work for my case. At the moment, I am hung up on the line of your
makefile which reads "$(FF90) $(FF90_ALL_FLAGS) -I$(MAIN_DIR)/mod -c
warpustruct-f2pywrappers2.f90". Am I correct that
warpustruct-f2pywrappers2.f90 should be generated by f2py? If so, do you
(or does anyone else) know the command for telling f2py to do so? At the
moment I am using:
f2py run_analysis.f90 -m run_analysis -h run_analysis.pyf
to get the requisite .pyf and .c files, but no .f90 file. If I am wrong
about the origin of this file, please do tell me!
Thank you,
Austin
On Mon, Mar 27, 2017 at 5:13 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
> Austin
> Here is the full makefile for a code we use. The variables defined
> externally in a separate config file are:
> $(FF90)
> $(FF90_FLAGS)
> $(LIBDIR)
> $(PETSC_LINKER_FLAGS)
> $(LINKER_FLAGS)
> $(CGNS_LINKER_FLAGS)
> $(PYTHON)
> $(PYTHON-CONIFG)
> $(F2PY)
> (These are usually use python, python-config and f2py. You can overwrite
> as necessary)
> $(CC)
> $(CC_ALL_FLAGS)
> This essentially just mimics what f2py does automatically but we found it
> easier to control exactly what is going on. Essentially you are just
> compiling exactly as you normally an executable, but instead make a .so
> (with the -shared option) and including the additional .o files generated
> by compiling the f2py-generated wrappers.
> Hope this helps,
> Gaetan
> On Sat, Mar 25, 2017 at 5:38 AM, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
>> On 22 March 2017 at 20:29, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Lisandro,
>>>     We've had a couple questions similar to this with f2py; is there a
>>> way we could add to the PETSc/SLEPc makefile rules something to allow
>>> people to trivially use f2py without having to make their own (often
>>> incorrect) manual command lines?
>>>    Thanks
>> Barry, it is quite hard and hacky to get f2py working in the general
>> case. I think the email from Gaetan in this thread proves my point.
>> IMHO, it is easier to write a small Fortran source exposing the API to
>> call using ISO_C_BINDINGS, then wrap that code with the more traditional
>> C-based "static" tools (SWIG, Cython) or even "dynamically" with ctypes or
>> cffi (which use dlopen'ing).
>> Lisandro Dalcin
>> Research Scientist
>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
>> 4700 King Abdullah University of Science and Technology
>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>> http://www.kaust.edu.sa
>> Office Phone: +966 12 808-0459 <+966%2012%20808%200459>
*Austin Herrema*
PhD Student | Graduate Research Assistant | Iowa State University
Wind Energy Science, Engineering, and Policy | Mechanical Engineering
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170328/8f52be0a/attachment.html>
