[petsc-users] TSAdaptSetType in fortran
Praveen C cpraveen at gmail.com
Tue Mar 21 03:39:45 CDT 2017
Thank you.
Will this fix be added to future versions or I have to apply this manually ?
Best
praveen
On Tue, Mar 21, 2017 at 1:41 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Sorry about that; since it involves character strings so it is something
> we currently need to do manually.
>   If you are
> 1) using petsc 3.7 from the tar ball I've attached a patch file, apply it
> in the petsc directory with patch -p1 < add-fortran-tsadaptsettype
> 2) if you are using petsc 3.7 from the git repository (i.e. the maint
> branch) do "git fetch; git checkout barry/add-fortran-tsadaptsettype"
> 3) if you are using petsc master from git use "git fetch; git checkout
> barry/add-fortran-tsadaptsettype; git checkout master; git merge
> In all cases after this you need to rerun ./configure and make
>    Barry
> > On Mar 21, 2017, at 1:22 AM, Praveen C <cpraveen at gmail.com> wrote:
> > Dear all
> > In my fortran code, I want to set to TSADAPTNONE by default. But it
> seems that TSAdaptSetType does not exist in fortran. Is there a solution
> for this ?
> > Thanks
> > praveen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170321/285b1997/attachment.html>
