[petsc-users] TSAdaptSetType in fortran
Tue Mar 21 03:11:34 CDT 2017
  Sorry about that; since it involves character strings so it is something we currently need to do manually.
  If you are
1) using petsc 3.7 from the tar ball I've attached a patch file, apply it in the petsc directory with patch -p1 < add-fortran-tsadaptsettype
2) if you are using petsc 3.7 from the git repository (i.e. the maint branch) do "git fetch; git checkout barry/add-fortran-tsadaptsettype"
3) if you are using petsc master from git use "git fetch; git checkout barry/add-fortran-tsadaptsettype; git checkout master; git merge barry/add-fortran-tsadaptsettype"
In all cases after this you need to rerun ./configure and make
   Barry
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170321/047f84af/attachment.obj>
> On Mar 21, 2017, at 1:22 AM, Praveen C <cpraveen at gmail.com> wrote:
> Dear all
> In my fortran code, I want to set to TSADAPTNONE by default. But it seems that TSAdaptSetType does not exist in fortran. Is there a solution for this ?
> Thanks
> praveen
