[petsc-users] CG with right preconditioning supports NONE norm type only
Wed Mar 8 13:10:07 CST 2017
  We should be getting an error.
> On Mar 8, 2017, at 11:19 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 8, 2017 at 10:47 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> Thanks Barry,
> We are using "KSPSetPCSide(ksp, pcside)" in the code.  I just tried "-ksp_pc_side right", and petsc did not error out.
> I like to understand why CG does not work with right preconditioning? Mathematically, the right preconditioning does not make sense?
> cd src/snes/examples/tutorials
> knepley/feature-plasma-example $:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex5 -ksp_view -ksp_type cg -ksp_pc_side right -ksp_error_if_not_converged
> KSP Object: 1 MPI processes
>   type: cg
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   using NONE norm type for convergence test
> PC Object: 1 MPI processes
>   type: ilu
>     out-of-place factorization
>     0 levels of fill
>     tolerance for zero pivot 2.22045e-14
>     matrix ordering: natural
>     factor fill ratio given 1., needed 1.
>       Factored matrix follows:
>         Mat Object: 1 MPI processes
>           type: seqaij
>           rows=16, cols=16
>           package used to perform factorization: petsc
>           total: nonzeros=64, allocated nonzeros=64
>           total number of mallocs used during MatSetValues calls =0
>             not using I-node routines
>   linear system matrix = precond matrix:
>     type: seqaij
>     rows=16, cols=16
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR:
> [0]PETSC ERROR: KSPSolve has not converged
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3127-ge9f6087  GIT Date: 2017-02-11 13:06:34 -0600
> [0]PETSC ERROR: ./ex5 on a arch-c-exodus-master named MATTHEW-KNEPLEYs-MacBook-Air-2.local by knepley Wed Mar  8 11:17:43 2017
> [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-c-exodus-master --download-chaco --download-cmake --download-ctetgen --download-eigen --download-exodusii --download-gmp --download-hdf5 --download-metis --download-mpfr --download-mpich --download-netcdf --download-p4est --download-parmetis --download-pragmatic --download-triangle --useThreads=1 --with-cc="/Users/knepley/MacSoftware/bin/ccache gcc -Qunused-arguments" --with-cxx="/Users/knepley/MacSoftware/bin/ccache g++ -Qunused-arguments" --with-fc="/Users/knepley/MacSoftware/bin/ccache gfortran" --with-shared-libraries
> [0]PETSC ERROR: #1 KSPSolve() line 847 in /PETSc3/petsc/petsc-dev/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #2 SNESSolve_NEWTONLS() line 224 in /PETSc3/petsc/petsc-dev/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #3 SNESSolve() line 3967 in /PETSc3/petsc/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: #4 main() line 187 in /PETSc3/petsc/petsc-dev/src/snes/examples/tutorials/ex5.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -ksp_error_if_not_converged
> [0]PETSC ERROR: -ksp_pc_side right
> [0]PETSC ERROR: -ksp_type cg
> [0]PETSC ERROR: -ksp_view
> [0]PETSC ERROR: -malloc_test
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> So we are not getting an error
>   Matt
> Fande,
> On Wed, Mar 8, 2017 at 9:33 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Please tell us how you got this output.
>   PETSc CG doesn't even implement right preconditioning. If you ask for it it should error out. CG supports no norm computation with left preconditioning.
>    Barry
> > On Mar 8, 2017, at 10:26 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > The NONE norm type is supported only when CG is used with a right preconditioner. Any reason for this?
> > 0 Nonlinear |R| = 1.732051e+00
> >       0 Linear |R| = 0.000000e+00
> >       1 Linear |R| = 0.000000e+00
> >       2 Linear |R| = 0.000000e+00
> >       3 Linear |R| = 0.000000e+00
> >       4 Linear |R| = 0.000000e+00
> >       5 Linear |R| = 0.000000e+00
> >       6 Linear |R| = 0.000000e+00
> >  1 Nonlinear |R| = 1.769225e-08
> >       7 Linear |R| = 0.000000e+00
> >       8 Linear |R| = 0.000000e+00
> >       9 Linear |R| = 0.000000e+00
> >      10 Linear |R| = 0.000000e+00
> >  2 Nonlinear |R| = 0.000000e+00
> > SNES Object: 1 MPI processes
> >   type: newtonls
> >   maximum iterations=50, maximum function evaluations=10000
> >   tolerances: relative=1e-08, absolute=1e-50, solution=1e-50
> >   total number of linear solver iterations=18
> >   total number of function evaluations=23
> >   norm schedule ALWAYS
> >   SNESLineSearch Object:   1 MPI processes
> >     type: bt
> >       interpolation: cubic
> >       alpha=1.000000e-04
> >     maxstep=1.000000e+08, minlambda=1.000000e-12
> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
> >     maximum iterations=40
> >     type: cg
> >     type: hypre
> >       HYPRE BoomerAMG preconditioning
> >       HYPRE BoomerAMG: Cycle type V
> >       HYPRE BoomerAMG: Maximum number of levels 25
> >       HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> >       HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
> >       HYPRE BoomerAMG: Threshold for strong coupling 0.25
> >       HYPRE BoomerAMG: Interpolation truncation factor 0.
> >       HYPRE BoomerAMG: Interpolation: max elements per row 0
> >       HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> >       HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> >       HYPRE BoomerAMG: Maximum row sums 0.9
> >       HYPRE BoomerAMG: Sweeps down         1
> >       HYPRE BoomerAMG: Sweeps up           1
> >       HYPRE BoomerAMG: Sweeps on coarse    1
> >       HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
> >       HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
> >       HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
> >       HYPRE BoomerAMG: Relax weight  (all)      1.
> >       HYPRE BoomerAMG: Outer relax weight (all) 1.
> >       HYPRE BoomerAMG: Using CF-relaxation
> >       HYPRE BoomerAMG: Not using more complex smoothers.
> >       HYPRE BoomerAMG: Measure type        local
> >       HYPRE BoomerAMG: Coarsen type        Falgout
> >       HYPRE BoomerAMG: Interpolation type  classical
> >     linear system matrix followed by preconditioner matrix:
> >       type: mffd
> >       rows=9, cols=9
> >         Matrix-free approximation:
> >           err=1.49012e-08 (relative error in function evaluation)
> >           Using wp compute h routine
> >               Does not compute normU
> >     Mat Object:    ()     1 MPI processes
> >       type: seqaij
> >       rows=9, cols=9
> >       total: nonzeros=49, allocated nonzeros=49
> > Fande,
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
