[petsc-users] CG with right preconditioning supports NONE norm type only
Wed Mar 8 11:19:15 CST 2017
On Wed, Mar 8, 2017 at 10:47 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> Thanks Barry,
> We are using "KSPSetPCSide(ksp, pcside)" in the code.  I just tried
> "-ksp_pc_side right", and petsc did not error out.
> I like to understand why CG does not work with right preconditioning?
> Mathematically, the right preconditioning does not make sense?
cd src/snes/examples/tutorials
knepley/feature-plasma-example
$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex5 -ksp_view
-ksp_type cg -ksp_pc_side right -ksp_error_if_not_converged
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  using NONE norm type for convergence test
PC Object: 1 MPI processes
  type: ilu
    out-of-place factorization
    0 levels of fill
    tolerance for zero pivot 2.22045e-14
    matrix ordering: natural
    factor fill ratio given 1., needed 1.
      Factored matrix follows:
        Mat Object: 1 MPI processes
          type: seqaij
          rows=16, cols=16
          package used to perform factorization: petsc
          total: nonzeros=64, allocated nonzeros=64
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    rows=16, cols=16
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR:
[0]PETSC ERROR: KSPSolve has not converged
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3127-ge9f6087  GIT
Date: 2017-02-11 13:06:34 -0600
[0]PETSC ERROR: ./ex5 on a arch-c-exodus-master named
MATTHEW-KNEPLEYs-MacBook-Air-2.local by knepley Wed Mar  8 11:17:43 2017
[0]PETSC ERROR: Configure options --PETSC_ARCH=arch-c-exodus-master
--download-chaco --download-cmake --download-ctetgen --download-eigen
--download-exodusii --download-gmp --download-hdf5 --download-metis
--download-mpfr --download-mpich --download-netcdf --download-p4est
--download-parmetis --download-pragmatic --download-triangle --useThreads=1
--with-cc="/Users/knepley/MacSoftware/bin/ccache gcc -Qunused-arguments"
--with-cxx="/Users/knepley/MacSoftware/bin/ccache g++ -Qunused-arguments"
--with-fc="/Users/knepley/MacSoftware/bin/ccache gfortran"
--with-shared-libraries
[0]PETSC ERROR: #1 KSPSolve() line 847 in
/PETSc3/petsc/petsc-dev/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #2 SNESSolve_NEWTONLS() line 224 in
/PETSc3/petsc/petsc-dev/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #3 SNESSolve() line 3967 in
/PETSc3/petsc/petsc-dev/src/snes/interface/snes.c
[0]PETSC ERROR: #4 main() line 187 in
/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials/ex5.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -ksp_error_if_not_converged
[0]PETSC ERROR: -ksp_pc_side right
[0]PETSC ERROR: -ksp_type cg
[0]PETSC ERROR: -ksp_view
[0]PETSC ERROR: -malloc_test
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
So we are not getting an error
  Matt
> Fande,
> On Wed, Mar 8, 2017 at 9:33 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Please tell us how you got this output.
>>   PETSc CG doesn't even implement right preconditioning. If you ask for
>> it it should error out. CG supports no norm computation with left
>> preconditioning.
>>    Barry
>> > On Mar 8, 2017, at 10:26 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>> > Hi All,
>> > The NONE norm type is supported only when CG is used with a right
>> preconditioner. Any reason for this?
>> > 0 Nonlinear |R| = 1.732051e+00
>> >       0 Linear |R| = 0.000000e+00
>> >       1 Linear |R| = 0.000000e+00
>> >       2 Linear |R| = 0.000000e+00
>> >       3 Linear |R| = 0.000000e+00
>> >       4 Linear |R| = 0.000000e+00
>> >       5 Linear |R| = 0.000000e+00
>> >       6 Linear |R| = 0.000000e+00
>> >  1 Nonlinear |R| = 1.769225e-08
>> >       7 Linear |R| = 0.000000e+00
>> >       8 Linear |R| = 0.000000e+00
>> >       9 Linear |R| = 0.000000e+00
>> >      10 Linear |R| = 0.000000e+00
>> >  2 Nonlinear |R| = 0.000000e+00
>> > SNES Object: 1 MPI processes
>> >   type: newtonls
>> >   maximum iterations=50, maximum function evaluations=10000
>> >   tolerances: relative=1e-08, absolute=1e-50, solution=1e-50
>> >   total number of linear solver iterations=18
>> >   total number of function evaluations=23
>> >   norm schedule ALWAYS
>> >   SNESLineSearch Object:   1 MPI processes
>> >     type: bt
>> >       interpolation: cubic
>> >       alpha=1.000000e-04
>> >     maxstep=1.000000e+08, minlambda=1.000000e-12
>> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>> >     maximum iterations=40
>> >     type: cg
>> >     type: hypre
>> >       HYPRE BoomerAMG preconditioning
>> >       HYPRE BoomerAMG: Cycle type V
>> >       HYPRE BoomerAMG: Maximum number of levels 25
>> >       HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>> >       HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
>> >       HYPRE BoomerAMG: Threshold for strong coupling 0.25
>> >       HYPRE BoomerAMG: Interpolation truncation factor 0.
>> >       HYPRE BoomerAMG: Interpolation: max elements per row 0
>> >       HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>> >       HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>> >       HYPRE BoomerAMG: Maximum row sums 0.9
>> >       HYPRE BoomerAMG: Sweeps down         1
>> >       HYPRE BoomerAMG: Sweeps up           1
>> >       HYPRE BoomerAMG: Sweeps on coarse    1
>> >       HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>> >       HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>> >       HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>> >       HYPRE BoomerAMG: Relax weight  (all)      1.
>> >       HYPRE BoomerAMG: Outer relax weight (all) 1.
>> >       HYPRE BoomerAMG: Using CF-relaxation
>> >       HYPRE BoomerAMG: Not using more complex smoothers.
>> >       HYPRE BoomerAMG: Measure type        local
>> >       HYPRE BoomerAMG: Coarsen type        Falgout
>> >       HYPRE BoomerAMG: Interpolation type  classical
>> >     linear system matrix followed by preconditioner matrix:
>> >       type: mffd
>> >       rows=9, cols=9
>> >         Matrix-free approximation:
>> >           err=1.49012e-08 (relative error in function evaluation)
>> >           Using wp compute h routine
>> >               Does not compute normU
>> >     Mat Object:    ()     1 MPI processes
>> >       type: seqaij
>> >       rows=9, cols=9
>> >       total: nonzeros=49, allocated nonzeros=49
>> > Fande,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170308/cdefdb33/attachment-0001.html>
