[petsc-users] block ILU(K) is slower than the point-wise	version?
    Fande Kong
    fdkong.jd at gmail.com
    Tue Mar  7 21:41:01 CST 2017
On Tue, Mar 7, 2017 at 7:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 7, 2017, at 4:35 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > I found one issue on my side. The preallocation is not right for the
> BAIJ matrix.  Will this slow down MatLUFactor and MatSolve?
>   No, but you should still fix it.
> > How to converge AIJ to BAIJ using a command-line option?
>    Instead of using MatCreateSeq/MPIAIJ() at the command line you would use
>    MatCreate()
>    MatSetSizes()
>    MatSetBlockSize()
>    MatSetFromOptions()
 MatSetFromOptions() has to be called before "MatXXXXSetPreallocation"?
What happens if I call MatSetFromOptions() right after
>    MatMPIAIJSetPreallocation()
>    MatMPIBAIJSetPreallocation() and any other preallocations you want
>    MatSetValues.....MatAssemblyBegin/End()
>    Then you can use -mat_type baij or aij to set the type.
>    Barry
> > Fande,
> > On Tue, Mar 7, 2017 at 3:26 PM, Jed Brown <jed at jedbrown.org> wrote:
> > "Kong, Fande" <fande.kong at inl.gov> writes:
> > > On Tue, Mar 7, 2017 at 3:16 PM, Jed Brown <jed at jedbrown.org> wrote:
> > >> Hong <hzhang at mcs.anl.gov> writes:
> > >> > Fande,
> > >> > Got it. Below are what I get:
> > >> Is Fande using ILU(0) or ILU(k)?  (And I think it should be possible
> to
> > >> get a somewhat larger benefit.)
> > > I am using ILU(0). Will it be much better to use ILU(k>0)?
> > It'll be slower, but might converge faster.  You asked about ILU(k) so I
> > assumed you were interested in k>0.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170307/14f66276/attachment.html>
