[petsc-users] block ILU(K) is slower than the point-wise version?
Tue Mar 7 20:37:10 CST 2017
> On Mar 7, 2017, at 4:35 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> I found one issue on my side. The preallocation is not right for the BAIJ matrix.  Will this slow down MatLUFactor and MatSolve?
  No, but you should still fix it.
> How to converge AIJ to BAIJ using a command-line option?
   Instead of using MatCreateSeq/MPIAIJ() at the command line you would use
   MatCreate()
   MatSetSizes()
   MatSetBlockSize()
   MatSetFromOptions()
   MatMPIAIJSetPreallocation()
   MatMPIBAIJSetPreallocation() and any other preallocations you want
   MatSetValues.....MatAssemblyBegin/End()
   Then you can use -mat_type baij or aij to set the type.
   Barry
> Fande,
> On Tue, Mar 7, 2017 at 3:26 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Kong, Fande" <fande.kong at inl.gov> writes:
> > On Tue, Mar 7, 2017 at 3:16 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> Hong <hzhang at mcs.anl.gov> writes:
> >> > Fande,
> >> > Got it. Below are what I get:
> >> Is Fande using ILU(0) or ILU(k)?  (And I think it should be possible to
> >> get a somewhat larger benefit.)
> > I am using ILU(0). Will it be much better to use ILU(k>0)?
> It'll be slower, but might converge faster.  You asked about ILU(k) so I
> assumed you were interested in k>0.
