[petsc-users] OpenMPI 2.0.1 and PETSC 3.7.5
H. Vukman vukmanh at googlemail.com
Fri Jan 27 15:14:41 CST 2017
Yes this did it. Thanks.
2017-01-27 21:29 GMT+01:00 Satish Balay <balay at mcs.anl.gov>:
> Can do a clean build - and see if this problem persists?
> rm -rf arch-linux2-c-debug
> [and rebuild]
> If the problem persists - please run the following - and send us the
> generated verboseinfo.i file
> make -f gmakefile V=1 CFLAGS=-save-temps arch-linux2-c-debug/obj/src/
> sys/info/verboseinfo.o
> Satish
> On Fri, 27 Jan 2017, H. Vukman wrote:
> > Hello!
> > When I try to compile PETSC after running ./configure with
> > make PETSC_DIR=/home/guntah/Downloads/petsc-3.7.5
> > PETSC_ARCH=arch-linux2-c-debug all
> > I get the error:
> > /home/guntah/Downloads/petsc-3.7.5/include/petscsys.h:150:6: error:
> #error
> > "PETSc was configured with OpenMPI but now appears to be compiling using
> a
> > non-OpenMPI mpi.h"
> >  #    error "PETSc was configured with OpenMPI but now appears to be
> > compiling using a non-OpenMPI mpi.h"
> > I have used the newest OpenMpi 2.0.1 and PETSC 3.7.5
> > The platform is Linux Mint 17. Attached is the make.log
> > Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170127/e82c58ab/attachment-0001.html>
