[petsc-users] OpenMPI 2.0.1 and PETSC 3.7.5
Fri Jan 27 14:29:59 CST 2017
Can do a clean build - and see if this problem persists?
rm -rf arch-linux2-c-debug
[and rebuild]
If the problem persists - please run the following - and send us the generated verboseinfo.i file
make -f gmakefile V=1 CFLAGS=-save-temps arch-linux2-c-debug/obj/src/sys/info/verboseinfo.o
Satish
On Fri, 27 Jan 2017, H. Vukman wrote:
> Hello!
> When I try to compile PETSC after running ./configure with
> make PETSC_DIR=/home/guntah/Downloads/petsc-3.7.5
> PETSC_ARCH=arch-linux2-c-debug all
> I get the error:
> /home/guntah/Downloads/petsc-3.7.5/include/petscsys.h:150:6: error: #error
> "PETSc was configured with OpenMPI but now appears to be compiling using a
> non-OpenMPI mpi.h"
>  #    error "PETSc was configured with OpenMPI but now appears to be
> compiling using a non-OpenMPI mpi.h"
> I have used the newest OpenMpi 2.0.1 and PETSC 3.7.5
> The platform is Linux Mint 17. Attached is the make.log
> Thanks
