[petsc-users] Understanding inner vs outer fieldsplit convergence
David Knezevic david.knezevic at akselos.com
Thu Jan 26 21:36:08 CST 2017
On Thu, Jan 26, 2017 at 6:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    David, with Schur complement preconditioning the nesting can be rather
> complicated and hard to track. We need to know exactly what monitors you
> have turned on and the output from -ksp_view in order to understand why you
> are seeing this (seemingly) strange effect. Send all command line arguments
> and if you are running a PETSc example.
Hi Barry,
Thanks for your comments. The command line arguments I'm using are:
-ksp_view -ksp_monitor -ksp_type cg -pc_type fieldsplit -pc_fieldsplit_type
schur -fieldsplit_block_2_ksp_monitor -pc_fieldsplit_type schur
-fieldsplit_block_1_pc_type cholesky -fieldsplit_block_1_ksp_type preonly
-fieldsplit_block_2_pc_type cholesky -fieldsplit_block_2_ksp_type minres
Note that I cleaned up my code a bit (I was doing some things via code
previously, but now I'm doing it all via command line arguments) and now I
can't replicate the strange effect that I reported in my previous email, so
I guess that must have been a bug at my end, sorry about that! (I'm using
my own example here, not a PETSc example.)
I've pasted the output that I get below, and it doesn't have any repeated
inner iterations anymore, so it looks good to me now.
David
    Residual norms for fieldsplit_block_2_ solve.
    0 KSP Residual norm 4.742303891404e+01
    1 KSP Residual norm 2.909253505627e-01
    2 KSP Residual norm 9.891933795043e-02
    3 KSP Residual norm 7.147789520726e-02
    4 KSP Residual norm 1.668752975827e-02
    5 KSP Residual norm 5.020016959860e-03
    6 KSP Residual norm 2.939648855177e-03
    7 KSP Residual norm 2.847937179284e-03
    8 KSP Residual norm 2.840502402597e-03
    9 KSP Residual norm 2.831875522390e-03
   10 KSP Residual norm 2.688309294147e-03
   11 KSP Residual norm 1.364866662320e-03
   12 KSP Residual norm 1.351460340317e-03
   13 KSP Residual norm 9.154713357796e-06
  0 KSP Residual norm 2.254632359666e+02
    0 KSP Residual norm 1.562796164027e-05
    1 KSP Residual norm 1.562568942204e-05
    2 KSP Residual norm 1.559644955712e-05
    3 KSP Residual norm 4.739731314562e-06
    4 KSP Residual norm 4.099203626623e-06
    5 KSP Residual norm 4.077340563505e-06
    6 KSP Residual norm 4.069934161136e-06
    7 KSP Residual norm 4.069081720832e-06
    8 KSP Residual norm 4.056610946411e-06
    9 KSP Residual norm 4.049977739107e-06
   10 KSP Residual norm 6.930727940912e-07
   11 KSP Residual norm 2.525753277129e-07
   12 KSP Residual norm 2.490106038182e-07
   13 KSP Residual norm 2.117790443270e-07
   14 KSP Residual norm 4.278506164384e-08
   15 KSP Residual norm 4.258945198001e-08
   16 KSP Residual norm 4.229334447981e-08
   17 KSP Residual norm 4.411718412575e-09
   18 KSP Residual norm 2.538786960344e-10
   19 KSP Residual norm 1.938707294127e-11
  1 KSP Residual norm 8.266789276240e-01
    0 KSP Residual norm 9.262098141749e-08
    1 KSP Residual norm 5.654510775654e-10
    2 KSP Residual norm 1.850940554946e-10
    3 KSP Residual norm 1.215872907413e-10
    4 KSP Residual norm 3.606362942651e-11
    5 KSP Residual norm 9.320062914875e-12
    6 KSP Residual norm 5.745183182943e-12
    7 KSP Residual norm 5.567033341218e-12
    8 KSP Residual norm 5.549943035966e-12
    9 KSP Residual norm 5.535981844425e-12
   10 KSP Residual norm 5.145409580427e-12
   11 KSP Residual norm 2.666485042347e-12
   12 KSP Residual norm 2.642698026095e-12
   13 KSP Residual norm 2.351888597601e-14
  2 KSP Residual norm 4.408818087377e-07
    0 KSP Residual norm 6.995890260994e-14
    1 KSP Residual norm 6.992908711883e-14
    2 KSP Residual norm 6.975805821489e-14
    3 KSP Residual norm 3.895698269070e-14
    4 KSP Residual norm 1.087381803170e-14
    5 KSP Residual norm 9.649779038703e-15
    6 KSP Residual norm 9.639503278208e-15
    7 KSP Residual norm 9.632063248075e-15
    8 KSP Residual norm 9.628902454482e-15
    9 KSP Residual norm 9.422064141948e-15
   10 KSP Residual norm 7.978243292438e-15
   11 KSP Residual norm 1.840364998277e-15
   12 KSP Residual norm 1.313440209393e-15
   13 KSP Residual norm 1.237317810391e-15
   14 KSP Residual norm 3.450624715175e-16
   15 KSP Residual norm 2.677943917771e-16
   16 KSP Residual norm 2.477309550239e-16
   17 KSP Residual norm 2.379077634512e-16
   18 KSP Residual norm 2.195084093320e-17
   19 KSP Residual norm 3.440267981045e-18
   20 KSP Residual norm 1.678278636525e-19
  3 KSP Residual norm 2.982422976816e-09
    0 KSP Residual norm 7.797636927781e-16
    1 KSP Residual norm 4.773690049123e-18
    2 KSP Residual norm 1.562856784196e-18
    3 KSP Residual norm 1.029604947226e-18
    4 KSP Residual norm 3.077276285355e-19
    5 KSP Residual norm 7.977399411645e-20
    6 KSP Residual norm 4.916849936508e-20
    7 KSP Residual norm 4.764440575250e-20
    8 KSP Residual norm 4.678272883449e-20
    9 KSP Residual norm 4.672106002328e-20
   10 KSP Residual norm 4.395115290861e-20
   11 KSP Residual norm 2.248590969592e-20
   12 KSP Residual norm 2.226836892279e-20
   13 KSP Residual norm 3.483134646974e-22
  4 KSP Residual norm 3.713946450555e-15
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=1000, initial guess is zero
  tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from A11
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_block_1_)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_block_1_)       1 MPI processes
        type: cholesky
          Cholesky: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 5., needed 1.14458
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqsbaij
                rows=30, cols=30
                package used to perform factorization: petsc
                total: nonzeros=285, allocated nonzeros=285
                total number of mallocs used during MatSetValues calls =0
                    block size is 1
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_block_1_)         1 MPI processes
          type: seqaij
          rows=30, cols=30
          total: nonzeros=468, allocated nonzeros=468
            using I-node routines: found 10 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_block_2_)       1 MPI processes
        type: minres
      PC Object:      (fieldsplit_block_2_)       1 MPI processes
        type: cholesky
          factor fill ratio given 5., needed 23.1555
                type: seqsbaij
                rows=10512, cols=10512
                total: nonzeros=4435992, allocated nonzeros=4435992
                    block size is 1
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_block_2_)         1 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
1 MPI processes
                type: seqaij
                total: nonzeros=372636, allocated nonzeros=372636
                  using I-node routines: found 3504 nodes, limit used is 5
            A10
                type: seqaij
                rows=10512, cols=30
                total: nonzeros=1872, allocated nonzeros=1872
                  using I-node routines: found 2143 nodes, limit used is 5
            KSP of A00
1 MPI processes
                type: preonly
divergence=10000.
MPI processes
                type: cholesky
                        type: seqsbaij
                        rows=30, cols=30
calls =0
                            block size is 1
      1 MPI processes
                  type: seqaij
                  rows=30, cols=30
            A01
                type: seqaij
                rows=30, cols=10512
                  using I-node routines: found 9 nodes, limit used is 5
          type: seqaij
  Mat Object:  ()   1 MPI processes
    type: seqaij
    rows=10542, cols=10542
    total: nonzeros=376848, allocated nonzeros=377064
      using I-node routines: found 3514 nodes, limit used is 5
> > On Jan 26, 2017, at 1:26 PM, David Knezevic <david.knezevic at akselos.com>
> wrote:
> > I'm exploring fieldsplit with Schur (this continues from some emails I
> sent a few weeks ago about this topic), and I had a quick question about
> the inner vs outer convergence.
> > I've pasted the output below from "-ksp_monitor -fieldsplit_FE_split_ksp_monitor",
> and I'm just wondering about why the second outer iteration has two inner
> iteration loops, whereas all the other outer iterations have one inner
> iteration loop? I assume it is something to do with a convergence
> tolerance, but it's not clear to me which tolerance would control that.
> > Thanks,
> > David
> >     Residual norms for fieldsplit_FE_split_ solve.
> >     0 KSP Residual norm 4.742303891408e+01
> >     1 KSP Residual norm 2.909253505630e-01
> >     2 KSP Residual norm 9.891933795059e-02
> >     3 KSP Residual norm 7.147789520745e-02
> >     4 KSP Residual norm 1.668752967907e-02
> >     5 KSP Residual norm 5.019869896662e-03
> >     6 KSP Residual norm 2.848579237244e-03
> >     7 KSP Residual norm 2.847897269641e-03
> >     8 KSP Residual norm 2.840502392022e-03
> >     9 KSP Residual norm 2.831875522381e-03
> >    10 KSP Residual norm 2.688309287993e-03
> >    11 KSP Residual norm 1.351494303229e-03
> >    12 KSP Residual norm 1.350874246297e-03
> >    13 KSP Residual norm 9.154691604943e-06
> >   0 KSP Residual norm 2.254632353893e+02
> >     0 KSP Residual norm 1.554697370480e-05
> >     1 KSP Residual norm 1.554471967929e-05
> >     2 KSP Residual norm 1.551293889691e-05
> >     3 KSP Residual norm 8.031337431574e-06
> >     4 KSP Residual norm 4.137185786243e-06
> >     5 KSP Residual norm 4.066606123330e-06
> >     6 KSP Residual norm 4.051107282928e-06
> >     7 KSP Residual norm 4.047442850256e-06
> >     8 KSP Residual norm 4.047129984657e-06
> >     9 KSP Residual norm 4.030697964677e-06
> >    10 KSP Residual norm 2.882383190940e-06
> >    11 KSP Residual norm 3.325005138484e-07
> >    12 KSP Residual norm 2.107354774516e-07
> >    13 KSP Residual norm 2.107005548204e-07
> >    14 KSP Residual norm 4.399320792736e-08
> >    15 KSP Residual norm 4.236902403786e-08
> >    16 KSP Residual norm 2.932877082709e-08
> >    17 KSP Residual norm 3.881909203171e-09
> >    18 KSP Residual norm 1.107791399514e-09
> >    19 KSP Residual norm 2.645048006100e-11
> >   1 KSP Residual norm 8.266776463696e-01
> >     0 KSP Residual norm 9.262528453386e-08
> >     1 KSP Residual norm 5.683232925010e-10
> >     2 KSP Residual norm 1.915223168286e-10
> >     3 KSP Residual norm 1.397893184942e-10
> >     4 KSP Residual norm 1.691441435404e-11
> >     5 KSP Residual norm 6.138315243419e-12
> >     6 KSP Residual norm 5.576043830003e-12
> >     7 KSP Residual norm 5.574440028225e-12
> >     8 KSP Residual norm 5.559544964428e-12
> >     9 KSP Residual norm 5.539862581746e-12
> >    10 KSP Residual norm 5.258329460152e-12
> >    11 KSP Residual norm 2.643581511791e-12
> >    12 KSP Residual norm 2.641293392449e-12
> >    13 KSP Residual norm 2.354608977643e-14
> >   2 KSP Residual norm 4.450925351013e-07
> >     0 KSP Residual norm 6.653681330477e-14
> >     1 KSP Residual norm 6.650750698147e-14
> >     2 KSP Residual norm 6.111123464526e-14
> >     3 KSP Residual norm 2.026817941567e-14
> >     4 KSP Residual norm 9.604999144183e-15
> >     5 KSP Residual norm 9.208296307424e-15
> >     6 KSP Residual norm 9.196769686859e-15
> >     7 KSP Residual norm 9.185058975459e-15
> >     8 KSP Residual norm 9.180207477303e-15
> >     9 KSP Residual norm 8.991574890909e-15
> >    10 KSP Residual norm 8.032736869820e-15
> >    11 KSP Residual norm 1.536409278928e-15
> >    12 KSP Residual norm 1.177374264280e-15
> >    13 KSP Residual norm 1.175712092044e-15
> >    14 KSP Residual norm 2.572275406087e-16
> >    15 KSP Residual norm 2.548423809711e-16
> >    16 KSP Residual norm 8.616505207588e-17
> >    17 KSP Residual norm 7.563053994201e-18
> >    18 KSP Residual norm 6.807636198601e-18
> >    19 KSP Residual norm 9.747028518744e-19
> >    20 KSP Residual norm 2.419807103570e-21
> >   3 KSP Residual norm 2.986369469883e-09
> >     0 KSP Residual norm 7.813223137340e-16
> >     1 KSP Residual norm 4.793103235095e-18
> >     2 KSP Residual norm 1.615526128222e-18
> >     3 KSP Residual norm 1.179102504397e-18
> >     4 KSP Residual norm 1.427467627551e-19
> >     5 KSP Residual norm 5.177440470993e-20
> >     6 KSP Residual norm 4.703763659148e-20
> >     7 KSP Residual norm 4.701953228322e-20
> >     8 KSP Residual norm 4.689269668869e-20
> >     9 KSP Residual norm 4.672625361251e-20
> >    10 KSP Residual norm 4.435174006113e-20
> >    11 KSP Residual norm 2.229156843383e-20
> >    12 KSP Residual norm 2.228887211080e-20
> >    13 KSP Residual norm 3.492936921635e-22
> >   4 KSP Residual norm 3.753341263086e-15
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170126/3656933b/attachment-0001.html>
