[petsc-users] Understanding inner vs outer fieldsplit convergence
Thu Jan 26 17:50:48 CST 2017
   David, with Schur complement preconditioning the nesting can be rather complicated and hard to track. We need to know exactly what monitors you have turned on and the output from -ksp_view in order to understand why you are seeing this (seemingly) strange effect. Send all command line arguments and if you are running a PETSc example.
> On Jan 26, 2017, at 1:26 PM, David Knezevic <david.knezevic at akselos.com> wrote:
> I'm exploring fieldsplit with Schur (this continues from some emails I sent a few weeks ago about this topic), and I had a quick question about the inner vs outer convergence.
> I've pasted the output below from "-ksp_monitor -fieldsplit_FE_split_ksp_monitor", and I'm just wondering about why the second outer iteration has two inner iteration loops, whereas all the other outer iterations have one inner iteration loop? I assume it is something to do with a convergence tolerance, but it's not clear to me which tolerance would control that.
> Thanks,
> David
>     Residual norms for fieldsplit_FE_split_ solve.
>     0 KSP Residual norm 4.742303891408e+01
>     1 KSP Residual norm 2.909253505630e-01
>     2 KSP Residual norm 9.891933795059e-02
>     3 KSP Residual norm 7.147789520745e-02
>     4 KSP Residual norm 1.668752967907e-02
>     5 KSP Residual norm 5.019869896662e-03
>     6 KSP Residual norm 2.848579237244e-03
>     7 KSP Residual norm 2.847897269641e-03
>     8 KSP Residual norm 2.840502392022e-03
>     9 KSP Residual norm 2.831875522381e-03
>    10 KSP Residual norm 2.688309287993e-03
>    11 KSP Residual norm 1.351494303229e-03
>    12 KSP Residual norm 1.350874246297e-03
>    13 KSP Residual norm 9.154691604943e-06
>   0 KSP Residual norm 2.254632353893e+02
>     0 KSP Residual norm 1.554697370480e-05
>     1 KSP Residual norm 1.554471967929e-05
>     2 KSP Residual norm 1.551293889691e-05
>     3 KSP Residual norm 8.031337431574e-06
>     4 KSP Residual norm 4.137185786243e-06
>     5 KSP Residual norm 4.066606123330e-06
>     6 KSP Residual norm 4.051107282928e-06
>     7 KSP Residual norm 4.047442850256e-06
>     8 KSP Residual norm 4.047129984657e-06
>     9 KSP Residual norm 4.030697964677e-06
>    10 KSP Residual norm 2.882383190940e-06
>    11 KSP Residual norm 3.325005138484e-07
>    12 KSP Residual norm 2.107354774516e-07
>    13 KSP Residual norm 2.107005548204e-07
>    14 KSP Residual norm 4.399320792736e-08
>    15 KSP Residual norm 4.236902403786e-08
>    16 KSP Residual norm 2.932877082709e-08
>    17 KSP Residual norm 3.881909203171e-09
>    18 KSP Residual norm 1.107791399514e-09
>    19 KSP Residual norm 2.645048006100e-11
>   1 KSP Residual norm 8.266776463696e-01
>     0 KSP Residual norm 9.262528453386e-08
>     1 KSP Residual norm 5.683232925010e-10
>     2 KSP Residual norm 1.915223168286e-10
>     3 KSP Residual norm 1.397893184942e-10
>     4 KSP Residual norm 1.691441435404e-11
>     5 KSP Residual norm 6.138315243419e-12
>     6 KSP Residual norm 5.576043830003e-12
>     7 KSP Residual norm 5.574440028225e-12
>     8 KSP Residual norm 5.559544964428e-12
>     9 KSP Residual norm 5.539862581746e-12
>    10 KSP Residual norm 5.258329460152e-12
>    11 KSP Residual norm 2.643581511791e-12
>    12 KSP Residual norm 2.641293392449e-12
>    13 KSP Residual norm 2.354608977643e-14
>   2 KSP Residual norm 4.450925351013e-07
>     0 KSP Residual norm 6.653681330477e-14
>     1 KSP Residual norm 6.650750698147e-14
>     2 KSP Residual norm 6.111123464526e-14
>     3 KSP Residual norm 2.026817941567e-14
>     4 KSP Residual norm 9.604999144183e-15
>     5 KSP Residual norm 9.208296307424e-15
>     6 KSP Residual norm 9.196769686859e-15
>     7 KSP Residual norm 9.185058975459e-15
>     8 KSP Residual norm 9.180207477303e-15
>     9 KSP Residual norm 8.991574890909e-15
>    10 KSP Residual norm 8.032736869820e-15
>    11 KSP Residual norm 1.536409278928e-15
>    12 KSP Residual norm 1.177374264280e-15
>    13 KSP Residual norm 1.175712092044e-15
>    14 KSP Residual norm 2.572275406087e-16
>    15 KSP Residual norm 2.548423809711e-16
>    16 KSP Residual norm 8.616505207588e-17
>    17 KSP Residual norm 7.563053994201e-18
>    18 KSP Residual norm 6.807636198601e-18
>    19 KSP Residual norm 9.747028518744e-19
>    20 KSP Residual norm 2.419807103570e-21
>   3 KSP Residual norm 2.986369469883e-09
>     0 KSP Residual norm 7.813223137340e-16
>     1 KSP Residual norm 4.793103235095e-18
>     2 KSP Residual norm 1.615526128222e-18
>     3 KSP Residual norm 1.179102504397e-18
>     4 KSP Residual norm 1.427467627551e-19
>     5 KSP Residual norm 5.177440470993e-20
>     6 KSP Residual norm 4.703763659148e-20
>     7 KSP Residual norm 4.701953228322e-20
>     8 KSP Residual norm 4.689269668869e-20
>     9 KSP Residual norm 4.672625361251e-20
>    10 KSP Residual norm 4.435174006113e-20
>    11 KSP Residual norm 2.229156843383e-20
>    12 KSP Residual norm 2.228887211080e-20
>    13 KSP Residual norm 3.492936921635e-22
>   4 KSP Residual norm 3.753341263086e-15
